03-16-2016, 11:10 AM | #51 |
Member#: 428946
Vehicle:2008 JDM WRX |
Hey all,
I have to bump this thread.. I have the symptoms of a blown head gasket, E.G. Bubbles in over flow tank But the bubbles only occur after boosting hard for a couple of times. I have tried flushing my coolant, changing to new radiator caps, 1.1 bar cap (with wings) top tank, 1.3 bar cap (round cap) on radiator itself, removing thermostat, but to no avail.. The thing is, this only happens after boosting hard. I was NOT overheating at all. The coolant seems to be pushed from the TOP tank to the overflow tank, after the overflow tank overflows, I open up the TOP tank and its significantly low in coolant or empty. My motor is a bone stock JDM EJ20 motor running a Twin Scroll VF turbo at 23psi I also bought the UVIEW combustion test kit and have tested extensively, when idling when revving, but the test comes up negative.. I should also mention that this came about coincidentally after my recent build which included, Turbo change (VF53 ball bearing) Downpipe change Timing belt / water pump change IAG TGV deletes Top feed rails with FIC injectors intercooler change Could any of these have affected and cause this problem?? Maybe its the turbo?? Could the water lines have been jammed up and cause lots of pressure in the TOP coolant tank, causing it to overflow to the overflow tank?? I have run out of ideas!!! Why wouldnt the test liquid just change to green??
03-16-2016, 11:33 AM | #52 |
Member#: 220629
SCIC
Vehicle:2010 White WRX Hatch 2015 White WRX Limited |
What color is the coolant that is coming out? Also, what head studs did you build your motor with?
03-16-2016, 11:44 AM | #53 |
Member#: 428946
Hey man,
Thanks for your reply The colour that is coming out is the same colour that was poured in.. There looks to be NO engine oil mixed in the coolant overflow tank that is bubbling My motor is Bone Stock it is using the stock OEM Head Studs.. |
HELP! what could the problem be? first sign is coolant pushes out of the reservoir | 949 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 02-13-2010 05:59 PM |
brake fluid overflowing out of tank | noyskie10 | Brakes, Steering & Suspension | 1 | 07-23-2009 02:19 PM |
Help!! coolant leaking out of the exhaust manifold! | blazerwrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 07-01-2009 11:33 AM |
Help: Coolant drains out of car at odd spot: near pass front wheel | greddy18 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 06-16-2009 06:48 AM |
93 Legacy Wagon lots of coolant coming out of the tail pipe all over my driveway | cky211 | Normally Aspirated Powertrain | 7 | 09-18-2008 04:42 PM |
