08-26-2015, 08:58 AM | #101 |
Member#: 368677
E. Canada
Vehicle:2013 WRX Pearly White |
1st question: any issues / worry with the side skirt rubbing the paint off the .. err... stock side skirts?
2nd question: I have replicas... does the stock "wings" have any time of padding, similar to what, I believe the 2015 ones have (based on another thread)? Thanks!
08-26-2015, 12:09 PM | #102 | |
Member#: 43310
SCIC
Vehicle:1978 Brat Silver |
No issues after a few years with paint rubbing off. The real ones have a thing rubber strip that acts as a buffer in a few key areas (which I'm sure are intended to prevent any sort of rubbing). |
08-26-2015, 05:07 PM | #103 |
Member#: 428914
looks good
08-26-2015, 05:18 PM | #104 |
Member#: 400679
Yes, the tiny rubber strip is similar to what is on the OEM front spoiler. Also, has padded double sided tape where it touches the side of the side skirt.
As for the bottom, if installed correctly, these barely touch the stock side skirts. |
08-27-2015, 09:25 AM | #105 |
Member#: 368677
E. Canada
@SpicyPeaNut - the replicas came with a t-shaped rubber strip (stick on yourself) along the edge of the 'wing'.
@walker111 - 1) Ok. I may want to invest on the padded double sided tape, or foam / weather stripping to act as a buffer between the wing and the side skirt. 2) I wish the replicas came with the rubber thing for the front skirt.. 3) your comment re: barely touching the skirt.. I can't envision how that works unless you put a washer in between (i.e. nut, washer, stock skirt, washer, side skirt, screw/bolt) |
08-29-2015, 09:41 AM | #106 | |
Member#: 400679
09-01-2015, 09:09 PM | #107 |
Member#: 423860
BAIC
Vehicle:2013 Subaru STI Tangerine orange pearl |
I just recently bought the s206 replicas they are actually pretty close to the real thing(would buy the oem if I had the money) I was wondering if yours came with those rubber things on the ends that attach to the screws or did you buy those ?
10-04-2015, 12:34 PM | #108 |
Member#: 292057
Vehicle:2014 WRX STi |
Are these the same thing for $490? http://www.avojdm.com/product_info.p...sCsid=ilnaeayc
