Brakes & Suspension Forum sponsored by The Tire Rack |
08-14-2015, 10:45 PM | #26 | |
Member#: 165955
Vehicle:2015 WRX Base WRB |
08-27-2015, 02:47 AM | #27 |
Member#: 428695
South East
Vehicle:2016 WRX Silver |
What if I don't know how to rebuild the calipers.... looks complicated.
08-27-2015, 06:38 AM | #28 |
Member#: 287794
South East
Vehicle:2015 Wrx DGM |
09-16-2015, 12:31 PM | #29 |
Member#: 398962
International
Vehicle:2014 New WRX Blue Galaxy |
Hi. You know what is the torque of the nuts that support the caliper???
Thanks |
09-30-2015, 10:04 AM | #30 | |
Member#: 12029
--Dan Mach V FastWRX.com |
09-30-2015, 10:05 AM | #31 |
Member#: 12029
Sorry, we don't want to rebuild your calipers. It's too time-consuming, and at mechanic's rates the price would be too high.
09-30-2015, 03:45 PM | #32 |
Member#: 388585
Vehicle:2015 wrx base ISM |
Great information! Not exactly a step by step but all the minor details can be found in other threads with a simple search. Good stuff guys!
11-10-2015, 04:01 PM | #33 |
Member#: 388585
Question, has anyone added extended lug bolts to their 2015 WRX? Curious to know if it's worth the hassle. I am currently running Advan RG-D wheel 18x9 +45. According to Ravspec, these Advans will not clear STI Brembos and will need a 3-5mm spacer. I do not mind running spacers but I am concerned that the stock studs are not long enough.
My options as of now is to either: 1) install extended wheel studs and run small spacers (Most hassle) 2) Get new wheels (Most expensive) 3) Run my 2015 STI base wheels (Most STOCK, eh, LOL!) |
11-12-2015, 05:24 PM | #34 |
Member#: 388585
Curious to know, can we bleed the brake system as we install each corner? Or must we install all 4 corners before bleeding?
Example, install rear passenger then bleed it. Install rear driver, then bleed it. Etc... |
02-09-2016, 08:15 PM | #35 |
Member#: 412789
Vehicle:2015 WRX WRB |
messaged about this
03-18-2016, 06:46 AM | #36 |
Member#: 439846
Vehicle:2015 WRX Crystal Black Silica |
Great info! Future investment fasure!
04-07-2016, 12:37 AM | #37 |
Member#: 349616
TXIC
Vehicle:2013 Wrx OBP |
So quick question. Do the Mach v lines have to be the 08-14 ones or do the 15+ wrx ones work. Or the 2015+sti ones
04-07-2016, 12:57 AM | #38 |
Member#: 349616
TXIC
05-04-2016, 12:05 PM | #39 |
Member#: 435908
Vehicle:2015 WRX |
Great post Dan! For clarification, can anyone please confirm that the Brembos fit under 2015 OEM WRX wheels with a 10mm spacer?
05-04-2016, 02:18 PM | #40 |
Member#: 349616
TXIC
06-13-2016, 06:01 PM | #41 |
Member#: 445520
Do you know if the bigger 2016 18" factory wheels will clear these brakes?
06-13-2016, 08:04 PM | #42 |
Member#: 349616
TXIC
06-22-2016, 02:44 AM | #43 |
Member#: 445520
06-22-2016, 10:27 AM | #44 | |
Member#: 349616
TXIC
You can get spacers to flush your wheels with fender line but not needed to clear brembos. From my understanding the 2015 wrx brakes are better brakes than all earlier years of Subaru before upgrading to brembos. But to answer your question I'm not sure if it's a direct swap or not |
06-22-2016, 10:32 AM | #45 | |
Member#: 125739
South East
Vehicle:2007 1500HD Need Brakes? 919.420.0021 |
Yes the smaller WRX 4 Pots and the rear WRX 2 Pots will clear the stock 17" 2015+ WRX wheels. The fronts are a direct bolt on but they will require our front gravel rotors because your hub is 5x114.3 The rear calipers require our rear V2.0 caliper bracket and will use a rear BRZ rotor that is redrilled to 5x114.3 Full car kits can be found here: http://knsbrakes.com/c/car-series/26...k+HPS+5.0+Pads |
06-22-2016, 01:26 PM | #46 |
Member#: 445520
Awesome thanks
06-26-2016, 04:55 PM | #47 |
Member#: 447850
Vehicle:16 wrx blue |
Has anyone tried or found anything about possibly swapping the 15/16 STI Brembos onto the 15/16 WRX? Just a thought, been trying to see if they will work or even fit but so far very little information has been found.
06-26-2016, 06:55 PM | #48 | |
Member#: 349616
TXIC
Buddy of mine found some off a wrecked 15 and slapped them on his 15 wrx so I'd say yes. Though your better off finding an older set quicker |
06-27-2016, 02:34 PM | #49 | |
Member#: 125739
South East
04-07 STI Brembo calipers will also fit on the 15+ WRX but it will need a rear calipe bracket. -Nick |
06-29-2016, 08:41 PM | #50 |
Member#: 447850
Thank you, I actually did find a totaled 11 sti so now i should be good!!
