Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 03-05-2007, 07:36 PM   #1
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Default EZ30R-T Buildup..
Since I am rebuilding my H6, I thought I would post up some pictures of the build as it is progressing.
For the curious, here is the parts list:
New EZ30R case and crank.
Custom Pauter Rods (5.180 long, with smaller H6 small end)
Supertec Forged 8:1 CR H6 Pistons
Supertec High Rate Valve Springs and Retainers
Supertec Exhaust Valves
Stock EZ30R Heads with variable valve timing and lift
Case halves and crank and rods all together.
I actually got permission to do this in the dining room.
The crank (stock), with the Pauter rods attached.
I torqued them to 50 lb-ft to start with… then measured the stretch.
Case half ready to drop the crank in.
Drop the crank in.
Put the top half on and seal it up.
Cut the rings.
The pistons with rings, ready to install.
sponaugle is offline   Reply With Quote
Old 03-05-2007, 07:36 PM   #2
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
The pistons going into the block.
Wrist pin sliding into the rod and piston.
Wrist pin clip installed.
Engine on the stand with lower section gaskets installed.
Lower section installed and being torqued down.
Head installed and cams ready to bolt down.
Both heads and oil pan installed.
Rear cover and first chain installed.
Second chain installed.
Old 03-05-2007, 07:37 PM   #3
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Front cover installed.
All covers installed.
Snap on electronic torque wrench. Worth every penny of the $400.
Installed the electronic lift control modules.
Installed the coolent sections.
Oil Cooler Fittings.
Car, ready for an engine.
Exedy Carbon-Carbon Hyper Twin
Old 03-05-2007, 07:38 PM   #4
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Clutch installed.
Ready to install..
Installed in the car..
A few more shots..
The view from below.
A turbo appears.
More to come..
Jeff Sponaugle
Old 03-05-2007, 08:31 PM   #5
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
So far so good...looks nice Jeff.
MJU1983 is offline   Reply With Quote
Old 03-05-2007, 08:38 PM   #6
jdmboostfed
Member#: 131281
00 RSti
soon to be flat black
nice! looks good from what can be seen.
what snail's going to be feeding that beast?
jdmboostfed is offline   Reply With Quote
Old 03-05-2007, 09:05 PM   #7
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Your pimp hand must be strong.
Is there any reason why you're not using Total Seal gapless rings?
PeteDucati is offline   Reply With Quote
Old 03-05-2007, 09:38 PM   #8
teamslow wrx
Member#: 18986
2002 wrx
sliver i Have 4 cats!!!
What kind of paint did u use on the covers??
teamslow wrx is offline   Reply With Quote
Old 03-05-2007, 10:36 PM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Any pics of how to get wrist pins 3&4 into the block? I never realized they'd used the same method to put them in as the H4's...
Old 03-05-2007, 10:53 PM   #10
fobiawrx
Member#: 91074
04 sti
white
gt40r. good choice
fobiawrx is offline   Reply With Quote
Old 03-05-2007, 11:04 PM   #11
LastResort
Member#: 99289
What's the EM going to be?
That looks like quite the project!
LastResort is offline   Reply With Quote
Old 03-05-2007, 11:13 PM   #12
remowgn
Member#: 41149
09 FXT
SSM
No assembly lube? Just oil?
remowgn is offline   Reply With Quote
Old 03-05-2007, 11:47 PM   #13
pio!pio!
Member#: 4190
2008 Impreza WRX STi
how do you install the wristpin in the middle cylinder?
pio!pio! is offline   Reply With Quote
Old 03-06-2007, 01:16 AM   #14
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Good question. If you do the center pistons first, you can just reach down from one of the side pistons to slide the wrist pin in. Since the block case itself is pretty short, it is easy to manipulate the rod to get it in the right place.
Getting the wrist pin clip on is another story. A very long thin pair of plyers is needed, and patiences and steady hands.
All in all not that much harder if you have a few critical tools, but a bit more time consuming.
I used the Royal Purple Assembly Lube... That oil was just sitting there for some of the bolts. The assembly lube is nice and thick, and I used a lot of it. The motor had a nice smooth feel turning over once assembled.
Hydra EMS, same as I has before. (Remember this is the same setup as before, just a new motor with forged rods and new valvespring componets).
That is just the normal 'wrinkle' VHT paint, which works well on surfaces that are not perfectly smooth.
These are the stock rings, which so far have worked very very well. Jeff Perrin's H6 is running strong at 600whp on pump fuel with the same pistons and rings.
I am running a GT30R .82 for the break in, then a GT35R for the Subiefest 2 Time attack, then I will fab up the GT4094 twin scroll.
Thanks!
I fired it up today for the first time. I'll post a link to a vid in a bit. What a sweet sound it makes! It is always nice to have it fire right up after all the work getting it together. Now I just need to get some miles on it and get it on the dyno before the Subiefest 2.
Cheers!
Jeff Sponaugle
Old 03-06-2007, 01:39 AM   #15
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
I am running a GT30R .82 for the break in, the a GT35R for the Subiefest 2 Time attack, then I will fab up the GT4094 twin scroll.
Jeff Sponaugle
GT4094 twinscroll You are my hero
dan avoN7 is offline   Reply With Quote
Old 03-06-2007, 02:17 AM   #16
subie4me
Member#: 89218
Did supertech change their piston pin clips? Those look like stock ones. I compared, and found the stock around 5 thou smaller diameter wire than supertech. They could jump out, and cause a LOT of damage if not correct.
subie4me is offline   Reply With Quote
Old 03-06-2007, 02:24 AM   #17
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Those are stock ones. I worked them just a bit to make them push a bit harder. They were very close to the supertec ones, and my first failure was related to the wrist pin coming loose.
Jeff
Old 03-06-2007, 02:48 AM   #18
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Awesome Jeff! Glad to see someone is making progress with the H6.
Better get that Snap-On wrench back otherwise Dustin will be pissed.
Now I can watch this and possibly get some excitement back for my own project....
Ben
Old 03-06-2007, 09:40 AM   #19
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Ahhh, makes complete sense. I guess if you had a pair of right angle pliers, it'd make life a little easier with getting that clip in too, eh? I can't imagine trying to clip it from another cylinder width away.
Old 03-06-2007, 09:50 AM   #20
T3RMIN4L
Member#: 37434
Great work Jeff! Can't wait to see how the beast performs for the time attack.
T3RMIN4L is offline   Reply With Quote
Old 03-06-2007, 10:04 AM   #21
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Vid?
ohh....
...can I drive it?
modaddict is offline   Reply With Quote
Old 03-06-2007, 10:32 AM   #22
JWX
Member#: 28990
I'm still suprised by the fact that nobody is closing the deck... What RPM you going to run with this thing?
JWX is offline   Reply With Quote
Old 03-06-2007, 11:45 AM   #23
subie4me
Member#: 89218
Jeff
That's what I thought. The supertech clips are a lot harder to r&r as they have no tang at all. The wire size is slightly larger than the stock ones, and would be less likely to pop out on their own. I had to make a tool to install the center ones. BTW, outback motorsports in southern ca. is closing the deck on this motor.
Old 03-06-2007, 12:07 PM   #24
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
love it, can't wait for the twin scroll to go on
aps2fast4u is offline   Reply With Quote
Old 03-08-2007, 02:51 PM   #25
checque
Member#: 68562
RIP Edwin
Sexy!
checque is offline   Reply With Quote
It has begun: GC4 EJ22 to EZ30R swap. Slack Subaru Conversions 1584 01-14-2014 05:54 AM
FS: EZ30R H6 Buildup Parts.. sponaugle Engine/Power/Exhaust 4 02-24-2008 07:47 AM
H6 Turbo EZ30R tear down/build up for BE Legacy PHATsuby Subaru Conversions 2 07-04-2005 04:27 AM
Running EZ30R with Hydra? Slack Other Engine Management 16 04-07-2005 06:29 AM
B9X: EZ30R Engine, Price North of $35,000 Jon [in CT] News & Rumors 168 11-20-2004 12:32 PM
