Welcome to the North American Subaru Impreza Owners Club Monday November 19, 2018
Old 03-02-2018, 04:06 PM   #51
boostinsticnd
Member#: 437417
2004 Wrx
Originally Posted by stu View Post
Why only running to 6000 rpm.
Kept blowing the charge pipes off, with a meh bead and T clamps.
We have since increased bead size, folded the end of the pipe out and put hairspray on there.
boostinsticnd is offline   Reply With Quote
Old 03-02-2018, 07:23 PM   #52
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
Which brand of hairspray? I personally use L'Oréal
user1029 is offline   Reply With Quote
Old 03-03-2018, 01:42 PM   #53
boostinsticnd
Member#: 437417
2004 Wrx
The sticky kind haha.
You'd be surprised how many people use hair spray if you think i'm kidding haha.
Old 03-03-2018, 03:31 PM   #54
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
^^^Its true...
rexworx is offline   Reply With Quote
Old 03-03-2018, 10:23 PM   #55
stu
Member#: 25768
2003 GEN 2 GTX35R
OFCD Bugeye Slowbaru
What is she revving it out to now? it makes great power.
stu is offline   Reply With Quote
Old 03-04-2018, 01:05 AM   #56
boostinsticnd
Member#: 437417
2004 Wrx
Will be going to 8-8100 for sure
Old 03-04-2018, 04:34 AM   #57
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
what is this sorcery you are talking about?
Hyper is offline   Reply With Quote
Old 03-04-2018, 12:36 PM   #58
boostinsticnd
Member#: 437417
2004 Wrx
Guys have been doing this for years.
Gotta think, whats hair spray? Basically a light spray glue.
Now, if you Clamped down on spray glue it will increase the friction between pipes and coupler. Allowing a strong clamping force and less of a chance of blowing charge pipes at higher psi.
Old 03-05-2018, 05:02 PM   #59
linkubus06
Member#: 335449
07 WRX 20G 6MT
11 335i RWD 6MT
All the real racers JBweld the couplers on.
Also we fill our blocks up with cement for max stiffness.
linkubus06 is offline   Reply With Quote
Old 03-06-2018, 12:46 PM   #60
magicmike7
Member#: 396660
2015 WRX STI
Back to the original post, i've got the new gaskets with my Stage 4 block and built heads, have it together soon. Then will be waiting on a turbo kit and a few other little odds and ends to arrive to toss it all back together and get it in the car.
Hoping to have everything done and bugs worked out to get the car on the dyno in may and see what the gen 2 6266 can put down.
magicmike7 is offline   Reply With Quote
Old 03-06-2018, 02:55 PM   #61
user1029
Member#: 57064
2008 STi IAG built
cement - like viagra for your short block
Old 08-17-2018, 12:30 AM   #62
RckyMtnGT
Member#: 440549
2007 Legacy GT 5mt
Necro bump...Any more input on these gaskets? The draw seems to be the fire ring. Is there a power level where these are a better idea than a MLS gasket like the JE proseal? Or are they just better in general?
Lets say you've got both gaskets, JE and these, in hand -- On a relatively mild build, ~400hp, EFR6758, built short block, ARP625s, which gasket would you throw on there? Is there a compelling reason to use one over the other?
I contacted IAG, and was basically told 'high hp, high boost'. I'm not doing anything too crazy with my build, but that doesn't narrow it down much.
RckyMtnGT is offline   Reply With Quote
Old 08-17-2018, 02:22 AM   #63
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
Most 400-500 whp builds aren't having rampant HG failures. Guys making 1000 whp running all the boost and liftind heads while running 14mm or 1/2 headstuds are using these. IAG gave you good info.
Would it hurt to run them. Probably not.
