Welcome to the North American Subaru Impreza Owners Club Friday April 16, 2021
Old 11-20-2017, 12:46 AM   #1
Kaykay
Member#: 409353
2018 WRX STI
Default 2018 STi and fog lights?
Hello everyone,
I know it's still a bit early for this car, but I was wondering if anyone has found a kit or anything for fog lights on the new 2018 STi? I know Subaru was saying they were removed to provide ventilation or whatever, but Ford seems to do it fine with ventilation there and fog lights too (or so I was told). So has anyone found something for this car?
I did find this:
https://www.prolightz.com/fog-lights...t-package.html
Which says it's for this car but based on the pictures it looks like it would impede or entirely block any airflow that area is supposed to allow.
Any thoughts?
Kaykay is offline   Reply With Quote
Old 11-20-2017, 08:19 AM   #2
SycsFinest
Member#: 411320
2015 WRX Limited
Galaxy Blue
The opening in the fog covers for the STI looks like it would be perfect for a set of fogs. I'm curious what it would look like to install a set and let the light shine through the perforations in the fog cover.
SycsFinest is offline   Reply With Quote
Old 11-20-2017, 12:06 PM   #3
transmutation
Member#: 467769
2018 STI Limited
Originally Posted by Kaykay View Post
Hello everyone,
I did find this:
Any thoughts?
I got this kit for the fogs and they work great. I also paired it with the JDM S4 bezels. Subbiespeed has a kit which also includes an interior switch but it doesn't work with the Limited trim as the blind spot monitoring switch is in the same spot as the fog light button.
The factory "air intakes" don't go anywhere as has been documented by several members here so the choice to add fogs is personal preference.
transmutation is offline   Reply With Quote
Old 11-20-2017, 03:53 PM   #4
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
The front bumper-cover for the WRX STI is the same for the WRX. The provision for fog-lamps exists, however on the WRX STI they are covered by the solid bezels.
You can get OEM WRX bezels with fog-lamp openings or the JDM bezels both the fog-lamp openings and the DRL light-strip and then you can get OEM or LED fog-lamps.
I do not know whether the harness is in place from the factory for the fog-lamps.
Big-E is offline   Reply With Quote
Old 11-20-2017, 05:19 PM   #5
Kaykay
Member#: 409353
2018 WRX STI
Okay this is interesting to know. One of my only complaints about this car was that it had no fog lights and I was told that fog lights were not a thing because of the "air intakes". But if that's a load of junk then that changes things...
Now I'm not sure how the models equate US vs Canada, but I do have the blind spot monitoring on mine so if I use the subispeed kit it might be an issue then yes? So the prolightz kit is a decent one then?
Old 11-20-2017, 05:49 PM   #6
Big-E
Member#: 123843
2016 STI LTD CWP
I would remove a bezel and inspect it as well as for the bumper-cover and anything behind it for any kind of ducting.
While I do not own your model nor have I had the opportunity to take a look at one in any kind of detail, I would say that more likely than not that there is no ducting and that the bezel, while it has open grille work to it, does nothing.
Subaru lists the front bumper cover for the following models:
Subaru STI 2.5L TURBO 6MT Premium 2018, 2019, 2020
Subaru STI 2.5L TURBO 6MT STI 2018
Subaru STI 2.5L TURBO 6MT STI Limited 2018
Subaru STI 2.5L TURBO 6MT TYPE RA 2018, 2019, 2020
Subaru WRX 2.0L 6MT Base 2018, 2019, 2020
Subaru WRX 2.0L 6MT Limited 2018, 2019, 2020
Subaru WRX 2.0L 6MT Premium 2018, 2019, 2020
Subaru WRX 2.0L CVT Base 2018, 2019, 2020
Subaru WRX 2.0L CVT Limited 2018, 2019, 2020
Subaru WRX 2.0L CVT Limited w/EyeSight 2018, 2019, 2020
Subaru WRX 2.0L CVT Premium 2018, 2019, 2020
Subaru WRX 2.5L TURBO 6MT S209 2018, 2019, 2020
Subaru WRX 2.5L TURBO 6MT STI TYPE RA 2018
Subaru WRX 2.5L TURBO 6MT STI w/Spoiler 2018
Subaru WRX 2.5L TURBO 6MT WRX STI 2018
Subaru WRX 2.5L TURBO 6MT WRX STI Limited w/Spoiler 2018
Subaru WRX 2.5L TURBO 6MT WRX STI Premium w/Spoiler 2018
VA = WRX
VAB = WRX STI
Applied model A,B,C = 2015, 2016, 2017
Applied model D,E,F = 2018, 2019, 2020
Old 11-20-2017, 06:05 PM   #7
Sarcoughaguy
Member#: 472039
2018 STi Limited
LBP
There is no ducting, see here
http://allwelldrive.blogspot.com/201...i-changes.html
I wish they would have given us a DRL bezel like they did the JDM S4.
However, since we have steering responsive headlights, the USDM version had their fog lights removed. There is no harness there either, so you'll need to have the quick tap wires or use the kit like was mentioned before. You have several options
Sarcoughaguy is offline   Reply With Quote
Old 11-20-2017, 09:11 PM   #8
RussianTiny
Member#: 387467
2018 WRX Limited
WRB Stage 2 FlexFuel
My 18 WRX Limited with steering responsive headlights has fog lights. Hopefully you can easily swap in the WRX or S4 fog king bezel into your STI and the wiring is there.
RussianTiny is offline   Reply With Quote
Old 11-20-2017, 11:56 PM   #9
transmutation
Member#: 467769
2018 STI Limited
I think the Prolightz kit is fine. The fogs are Morimoto LEDs and extremely bright with a sharp cutoff. The only downside is that there is no interior switch if that is important to you. I looked around to see if i could source a switch for the Subbiespeed kit but apparently the 2018s have slightly different interior panels and there is not an OEM switch available. I'm sure someone could fab something up but i decided not to mess with it for now.
Old 11-20-2017, 11:33 PM   #10
transmutation
Member#: 467769
2018 STI Limited
There is no fog light wiring in the 2018 STI in either trim.
Old 11-21-2017, 04:24 AM   #11
ajsti24
Member#: 345666
2019 S209,GLC43
Hello everyone,
I did find this:
Any thoughts?
Fog lights is possible to add on a 2018 STi, there is a provision for mounting the fog lamp lens on the bumper. There is no ducting of whatsoever behind the bumper bezel. I attached some pics of my 2018 STi front bumper bezel opening.
Behind the front fender liner, no ducting, hole...same as the 15-17 WRX/STi fender liner
ajsti24 is online now   Reply With Quote
Old 11-21-2017, 05:08 PM   #12
transmutation
Member#: 467769
2018 STI Limited
AJ, sorry i know I've already asked you questions in other threads but your JDM LEDs come on when either the parking lights or headlights are on correct? Not when just the C-Light DRLs are on?
Old 11-22-2017, 12:21 PM   #13
IndecisiveS12
Member#: 463349
2017 WRX Sport
maybe we've been looking at this all wrong and those covers and air ducts are for cooling the headlights
or....cooling the bottom of the sealed airbox and the battery...lol
[/sarcasm]
IndecisiveS12 is offline   Reply With Quote
Old 11-22-2017, 05:49 PM   #14
Kaykay
Member#: 409353
2018 WRX STI
I just wonder what the purpose of them saying the ducts are for brake cooling only to have them do nothing at all. Either it's a blatant gimmick that they might take some major flack for, or it's "in case the owner wants to put it in."
Old 11-25-2017, 10:41 PM   #15
transmutation
Member#: 467769
2018 STI Limited
I don't think I've ever seen Subaru claim there is ducting. Some reviews have said so but lets face it - reviewers get things wrong all the time. For the 2018s it seems the lack of fogs is purely a cost/weight saving move.
I highly suspect that the 2019 model will have them in order to offer something more for the final year.
Old 11-25-2017, 11:12 PM   #16
Kaykay
Member#: 409353
2018 WRX STI
Well I guess the main thing I wanted to know was whether or not putting fogs in would hurt anything. Given the proven absence of ducting...I'm gonna say it looks like I'm good to go! lol. ^^;
Old 11-29-2017, 12:15 AM   #17
transmutation
Member#: 467769
2018 STI Limited
haha, yeah i get it i went through the same thought process but i really like the look of the car a lot more with fogs and the JDM S4 bezels so as soon as i verified there were no actual brake ducts i ordered parts and didn't look back!
Old 11-29-2017, 12:36 AM   #18
Kaykay
Member#: 409353
2018 WRX STI
I appreciate all the help and info thank you ^^
Old 11-30-2017, 11:28 AM   #19
shoots808
Member#: 370541
2008 Subaru WRX
you could always convert it to an actual duct.
http://www.subispeed.com/2015-subaru...i#.WiAxYErtw_w
shoots808 is offline   Reply With Quote
Old 12-01-2017, 11:46 AM   #20
transmutation
Member#: 467769
2018 STI Limited
Hmm, that is a pricey option but looks like it would work. Us 18s don't have the blinkers down there though so additional back plating or something like that would need to be done to clean up the look (if that is important).
Old 02-25-2019, 11:50 AM   #21
jrseda
Member#: 497894
2018 WRX STI Limited
WR Blue
Did you ever installed the fog lights? Share pics
jrseda is offline   Reply With Quote
Old 02-26-2019, 12:28 AM   #22
transmutation
Member#: 467769
2018 STI Limited
Old thread bump and not sure who you are asking but yes, many of us have. Its not difficult if you utilize one of the kits mentioned. Prolightz is easy to install but Subispeed has interior switches which work for limited's now. All will look like a WRX with factory fogs equipped.
Different topic but there are pics in this thread: https://forums.nasioc.com/forums/sho....php?t=2858439
Old 02-26-2019, 02:24 PM   #23
apkarian100
Member#: 207053
2018 WRX
PR
I installed some OEM fog lights with the OEM fog light kit. I additionally added a wiring harness for the fog lights and tapped into the turn signals.
apkarian100 is offline   Reply With Quote
Old 04-10-2019, 11:03 PM   #24
Series.GraySTI
Member#: 493354
How difficult was wiring the turn signals. Im really close to picking up the subispeed kit, but they actually tried to talk me out of adding turn signals because of difficulties wiring it. Id like to do it all myself, so any tips are welcome.
Series.GraySTI is offline   Reply With Quote
Old 04-13-2019, 11:20 PM   #25
chevbo
Member#: 500342
what?
chevbo is offline   Reply With Quote
