#1 |
Member#: 516369
![]() Any tools to remove the 14mm bolt oil plug with rounded hex head? Just 14mm extractor?
#2 |
Member#: 520409
![]() Not sure how bad yours is, but on my new (to me) 2016, I went under to find a rounded mess of a 17mm plug. Purchased $5 replacement at NAPA, while getting all ready for all sorts of extraction methods. First, I tapped a good 6 point socket on it, nice and square with a small hammer. It came right off, surprisingly.
Mike B |
#3 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
![]() 6-point is a good start. Sometimes you can break them free with a chisel on the side of the head. If you know anyone with a welder, wed a nut on.
#4 |
Member#: 459287
VIC
Vehicle:1998 JDM Impreza STi V4 GF8 White |
![]() I'm curious how oil drain plugs get "rounded" in the first place? It's not like they're torqued to 300 ft lbs. Is it simply the use of improper tools?
#5 |
NASIOC Storefront Vendor
Member#: 384404
SCIC
Vehicle:MANY WRX, STI, 997TT wrb |
![]() usually from using a 12 point wrench and not a 6 point wrench and it slipping, or using a 15mm wrench/socket on the drain plug and not catching it
#6 |
Member#: 459287
VIC
![]() I suspect weekend warriors are using pliers and/or vice-grips!
