03-31-2004, 09:06 AM | #1 |
Member#: 34474
NESIC
Vehicle:2oo4 WRX PSM Sedan 2oo3 MINI cooper RED/WHT |
04 Side Splitter Install!
OK, I was asked to post in another thread how to install the side splitters, so I figured I would start a new thread to make it easier to find for everyone.
Here goes... For the side splitters to go onto my wrx, I cut 3 holes per side for the tabs to go into. Here is a picture of the 3 holes: To cut these holes I carefully lined up the side splitters with the car to determine where the hole should go, and then used a sharp knife to cut the holes. It's more than a slit. The is actually a little bit of plastic missing... I then "adjusted" the splitters to be used on a WRX instead of an STi. In this picture you can see the 2 splitters. The top one has had the white tabs removed, as well as the black plastic pieces that held them in place. To do this I used the same sharp knife. (Actually a steak knife): You then pop the 3 tabs on each side into the hole you cut in your bumper, and use the metal tabs and bolts that came with the splitter to bolt the rest up under the car. That is the easy part. The only tricky or hard part of the whole thing is cutting the whole and more becasue you have to cut a whole in your nice car... Here are some finished pictures: Good Luck, and feel free to post any questions, or additional help in this thread. Ben |
03-31-2004, 11:46 AM | #2 |
Member#: 34436
SWIC
Vehicle:2018 Jeep Wrangler |
good writeup... should be posted on scoobymods
03-31-2004, 12:41 PM | #3 |
Member#: 34474
NESIC
Not a memeber over there, but someone who is can feel free to borrow any of this. Just post a link to this write too... I should go there and join and add it.
Ben (EDIT: It's over on scoobymods now too. I will post a link when they moe it to a forum.) Last edited by jacobsen1_; 04-01-2004 at 07:11 AM. |
03-31-2004, 02:14 PM | #4 |
Member#: 54858
NESIC
Vehicle:2004 WRX Premium Platinum Silver |
Nice work, I live in RI and I will being doing the same mod to my silver 04. Glad so see this thread, it will make it much easier for my install.
03-31-2004, 02:58 PM | #5 |
Member#: 50523
MWSOC
Vehicle:2023 GR86 Gray |
how much did those side splitters cost you?
04-15-2004, 12:33 AM | #7 |
Member#: 40736
MAIC
Vehicle:2005 WRX STI Aspen White |
Those are really nice! Wish that stuff was availbe for the 03' but just not as expensive... who is gonna pay $400 for the stock front lip/strake on each side of the front of the bumper... that's outragous!
Yours looks really nice! Should come from the factory like that other than the STI :-) -Nigel |
04-15-2004, 12:34 AM | #8 |
Member#: 5291
Vehicle:'08 Scion xB Nautical Blue Metallic |
wish they fit the wagon
04-15-2004, 08:41 AM | #9 | |
Member#: 34474
NESIC
Ben |
05-28-2004, 09:46 AM | #10 |
Member#: 62863
Vehicle:2004 WRX aspen white |
where'd u get the splitter from?
05-28-2004, 09:50 AM | #11 |
Member#: 40540
MAIC
Vehicle:2004 Impreza WRX WR Blue |
how long did it take you to do this whole process? it seems like it should only take 30 minutes to an hour IMO
05-28-2004, 12:30 PM | #12 |
Member#: 44809
W. Canada
Vehicle:2008 BMW M3 SATURDAY!!!!!!!!!!!!!!! |
VERY nice job indeed!
05-28-2004, 01:18 PM | #13 |
Member#: 32371
Vehicle:'02 t-rex wagon platinum |
is it really functional or mainly for looks?
05-28-2004, 01:24 PM | #14 | |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
looks good and cant hurt aerodynamics now can it? Jamie www.subiegal.com |
05-29-2004, 01:34 AM | #15 |
Member#: 60316
Vehicle:2004 STi WRB |
like most small subtle aerodynamic parts... it'll probably work, but only noticeable at about 2x the speed limit. =)
01-04-2005, 06:54 PM | #16 |
Member#: 75071
Tri-State
Vehicle:23 Solterra,ModelY Old: 05 08 11 WRX, 18 STI |
back from the dead.
they are supposed to increase the air flowing over the brakes, dunno tho. Question: did they come w/ the mounting brackets, cus i just got a pair and they didnt??? EDIT: i see the brackets are an option. i think im gonna do the 3M mod anyway. Last edited by Snow Drift; 01-04-2005 at 07:10 PM. |
04-26-2005, 05:08 PM | #17 |
Member#: 38224
NWIC
Vehicle:I miss my Subie. |
Bump for some uber-n00b notes that might help others like me.
I just did this install last night and I've got a few tips that may help other complete mod newbies. These are not in any particular order! 1. After doing one side, I found it was easier to remove the 3 black plastic anchors before starting. I haven't seen anyone else talk about removing and reinstalling these during the install, but I think they're intended to be used with the splitter. So in the end, you have the splitter attached by the 3 tabs on top, the 3 black plastic anchors, and the 3 bolts/clips included with the splitters. 1a. Make sure you know how to work those plastic anchors. They're made up of two parts: a center nail-like thing, and a outer molly-like anchor piece. It's easiest if you take out the center portion first, then pull out the molly-like anchor portion. 2. I found 8 places (4 on each side) that could use a bolt and clip, even though only 6 are included in the kit. It's fine though, 3 each side is enough. I put two in the two forward-most positions on the underneath and one at the top position in the wheel well. Considering the locations of the other anchors, I found this to be a good balance. 3. I used a small drill bit to get a start on the cuts in the bumper. I just had to be careful not to let the drill get away from me and chew up too much bumper... cause it kind of wanted to. 4. It would be easier if you had ramps or something, just a little more space to work with. But I did it just fine with the car on the ground. Hopefully this helps someone, I imagine most people won't need these. |
04-27-2005, 07:07 PM | #18 |
Member#: 84718
Vehicle:2005 Impreza Crystal Gray |
fitting spliiters
Hopefully this helps someone, I imagine most people won't need these. [/quote]
car still a month away from delivery and spliters should be here next week. Definete it will help more when i fit them. Thanks for the extra tips |
04-26-2005, 06:28 PM | #19 |
Member#: 61109
BAIC
Vehicle:2004 WRX Platinum Silver |
i tried the knife way when i did mine. it didnt work. unless you have like a samurai sword. so my addition is that a dremel + router tool + your steady hand is your friend.
09-13-2005, 12:26 AM | #20 |
Member#: 86849
RMIC
Vehicle:2005 GMC Savana white |
i'm about to buy some of these, but first... sleep...
09-13-2005, 12:49 AM | #21 |
Member#: 61105
Vehicle:2009 Legacy Spec.B OBP |
brought back from the dead. Have fun with the install. Real easy to do. I was indecisive on cutting the tabs off or cutting the bumper. I went with the tabs coming off. Easy to do just make sure you get the right 3M tape. I went to like 7 places before finding the right stuff at a true value. Been on for 7 months with speeds upto 110 and no problems at all.
Shane |
11-28-2005, 07:35 AM | #22 | |
Member#: 83351
Dan Last edited by darylWrX; 11-28-2005 at 07:41 AM. |
01-04-2006, 09:25 PM | #23 |
Member#: 79653
SCIC
Vehicle:2005 LGT Silver |
I'm about to install the front splittter, I'm just wondering if having the white tab mounting removed looks different with it in???
01-04-2006, 09:50 PM | #24 |
Member#: 83961
TXIC
Vehicle:2012 Cayenne 6MT '16 XC90-R | '88 944 |
no it would look the same, but youd have to drill holes in your bumper for those snap fasteners. Since they are an OEM replacement for the STI tabs, I would assume the sti bumper has those holes underneath in stock form.
01-04-2006, 11:40 PM | #25 |
Member#: 79653
SCIC
instead of removing the mounting, i'm just going to remove the white tab and put double sided tape in it...
Similar Threads | ||||
STI Side splitter install | jonthesloth | Interior & Exterior Modification | 18 | 05-03-2009 03:14 PM |
STi side splitters install | Cannonbolt | Interior & Exterior Modification | 9 | 07-23-2008 04:14 PM |
STi Side Splitter Install Question | Godfather Inc 03 | Interior & Exterior Modification | 21 | 08-15-2006 12:44 PM |
Side splitter install aid | Thumper23 | Interior & Exterior Modification | 2 | 04-28-2004 07:09 PM |
Side splitters install on WRX | blackout | Interior & Exterior Modification | 12 | 03-31-2004 09:07 AM |
