Welcome to the North American Subaru Impreza Owners Club Tuesday April 13, 2021
Old 09-12-2012, 09:47 AM   #101
vision.dynamix
Member#: 139955
2015 Subaru STI
17Forester / 18Crosstrek
rennenmetal.com
Sorry, forgot to put that. They have many sizes available.
Old 09-12-2012, 09:53 AM   #102
wrxracer519
Member#: 149890
09 Forester
Green
Looks like a Rennen Metals tow hook.
Edit:beat to it
wrxracer519 is offline   Reply With Quote
Old 09-12-2012, 06:30 PM   #103
Daddy_Digital
Member#: 274205
2013 XV Crosstrek
Orange
Originally Posted by vision.dynamix View Post
rennenmetal.com
i looked around and i didnt see any 9 dollar tow hooks.
Daddy_Digital is offline   Reply With Quote
Old 09-12-2012, 06:34 PM   #104
vision.dynamix
Member#: 139955
2015 Subaru STI
$12.50. Close enough
Old 09-12-2012, 06:34 PM   #105
Daddy_Digital
Member#: 274205
2013 XV Crosstrek
Orange
Do those washers look taped together? I PMed the guy who posted this like 3 days ago and no reply. The pics are great but the small details left out make this particular write up, unfinished. can someone help me figure this out?
Old 09-12-2012, 08:05 PM   #106
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Yes45
JSchell1309 is offline   Reply With Quote
Old 10-31-2012, 07:41 PM   #107
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
sub'd for awesomeness
imma_stocker is offline   Reply With Quote
Old 11-02-2012, 02:35 PM   #108
Daddy_Digital
Member#: 274205
2013 XV Crosstrek
Orange
my write up is coming in a bit. working on it now.
Old 11-02-2012, 02:55 PM   #109
disturbed-az
Member#: 280562
2011 Impreza WRX 5dr
LOL...the reason you'd spend 10x more than doing it yourself is in under his name...'it's jersey bro!' lol
Originally Posted by 573 View Post
Seriously? You may not understand this, but some people use their car for more than a means of transportation to their next hellaflush meet. From the looks of this guys car, he likely uses it for rally-x, TSD, and maybe the occasional snow/ice race. These are things where a tow hook can actually come in handy. As shown by solidworks, this hook is more than capable of doing its job. Why should he spend 10 times the money on something that does the exact same thing? The money would have a much bigger impact on the overall performance of the car is it's spent on quality rubber, suspension bits, or basically anything other than a $200 tow hook.
disturbed-az is offline   Reply With Quote
Old 11-02-2012, 03:55 PM   #110
Daddy_Digital
Member#: 274205
2013 XV Crosstrek
Orange
I contacted a couple people on this thread about the size bolts used and materials. A lot of this project is trail and error. I spent an hour at ACE trying to find the right washers and nuts. Here is what I came up with.
Tip/Advice : The best place I found for all the bolts and washers needed was ACE Hardware. Home depot...dont waste your time at HD. ACE has everything you will need.
I had already tried doing something with my stock tow hook. I had painted it pink. BTW, Krylon makes a color called Watermelon, which looks alot like the cherry blossom red that Grimmspeed sells. Anyways, the tow hook I did purchase at Home Depot. When I purchased the tow hook, that was when I foud out Home Depot sucks for nuts and bolts. The tow hook is rated for 3,000 lbs.
I used Regal Red for the color of my tow hook.
I used 6 washer for the inside of the tow hook. The diameter of the inside circle and the bolt that goes in the washers is 12mm. (Not the threads on the tow hook. Got it?) The washers are 7/16 washers.
If you want to use a bolt instead of the rod that comes with the tow hook, the bolt is M6 x 1.0 x 20mm and the nut is m6x1.0
Old 11-02-2012, 03:55 PM   #111
Daddy_Digital
Member#: 274205
2013 XV Crosstrek
Orange
I didnt get the size of the washers I put to hold in the washers inside the tow hook. Same inside diameter, but the flat washers are bigger so to push up on the tow hook and hold the washers in securely. But since you will be at ACE, you can try a few flat washers out and make sure the fitment is right for your needs.
I didnt get a pic of the tow hook when I first put it together. I was so excited to have finally completed it. But here are some pics when I put it on after I drilled the tow hook cover and plasti dipped the tow hook matte back.
Tip/Advice: I drilled through the tow hook cover. TO be honest, I kind of messed it up. I tried using a cardboard mock up of the hole where the cover goes and eye balling where the tow hook would go. You are going to need a HUGE uni-bit. If I remember correctly, the diameter of the threads on the actual tow hook was 19mm. I used a rubber gromit to hide the error and it looks much nicer and professional looking. So make sure you have the right tools or just dont drill into the cover. If the Styrofoam in the bumper shows, spray paint it black.
Almost done!
Taped it off again and plasti dipped what had got rubbed off or needed to be touched up.
All done!
Old 02-25-2015, 05:14 PM   #112
coletrain
Member#: 408230
2013 XV Crosstrek
What size is the D ring shackle?
coletrain is offline   Reply With Quote
Old 12-29-2020, 10:29 AM   #113
WhiteZombie
Member#: 338863
PSM 05 WRX WGN 5MT
95 Caprice 6spd Track Rat
Thanks for the writeup - trying to sort a better solution for my occasionally tracked wagon and I'm fond of. I'd prefer a strap but this may work without re-engineering the wheel.
WhiteZombie is offline   Reply With Quote
Old 12-29-2020, 11:55 AM   #114
standardtranny
Member#: 450713
2017 WRX Stage 3ish
world rally blue
step 1- get oem tow hook out of trunk
step 2- screw in tow hook
/thread
standardtranny is online now   Reply With Quote
Old 01-12-2021, 11:18 AM   #115
m016324
Member#: 521623
anyone adding a rubber coating or cover on the bottom so it doesn't bang the bumper every time you start and stop?
m016324 is offline   Reply With Quote
Front tow hook w/ FMIC Vahnatai Interior & Exterior Modification 45 09-09-2008 03:35 PM
Front Tow Hook? With FMIC?? Thran Interior & Exterior Modification 8 02-05-2008 02:24 PM
front tow hook subwrx03 Interior & Exterior Modification 15 05-31-2006 11:48 AM
APS FMIC, bugeye WRX and the front tow hook. Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-19-2004 12:25 AM
Do '93-01 Impreza's have two front tow hooks? annointed Tri-State Area Forum 3 07-05-2004 11:12 PM
