#101 |
Member#: 139955
Vehicle:2015 Subaru STI 17Forester / 18Crosstrek |
![]() rennenmetal.com
Sorry, forgot to put that. They have many sizes available.
#102 |
Member#: 149890
Vehicle:09 Forester Green |
![]() Looks like a Rennen Metals tow hook.
Edit:beat to it |
#103 |
Member#: 274205
SWIC
Vehicle:2013 XV Crosstrek Orange |
#104 |
Member#: 139955
![]() $12.50. Close enough
#105 |
Member#: 274205
SWIC
![]() ![]() ![]() ![]() Do those washers look taped together? I PMed the guy who posted this like 3 days ago and no reply. The pics are great but the small details left out make this particular write up, unfinished. can someone help me figure this out? |
#106 |
Member#: 321321
Vehicle:2010 Ford SVT Raptor Tuxedo Black |
#107 |
Member#: 97043
TXIC
Vehicle:08 STI 02 Z28 - project |
![]() sub'd for awesomeness
#108 |
Member#: 274205
SWIC
![]() my write up is coming in a bit. working on it now.
#109 | |
Member#: 280562
SWIC
Vehicle:2011 Impreza WRX 5dr DGM |
![]() LOL...the reason you'd spend 10x more than doing it yourself is in under his name...'it's jersey bro!' lol
#110 |
Member#: 274205
SWIC
![]() I contacted a couple people on this thread about the size bolts used and materials. A lot of this project is trail and error. I spent an hour at ACE trying to find the right washers and nuts. Here is what I came up with.
Tip/Advice : The best place I found for all the bolts and washers needed was ACE Hardware. Home depot...dont waste your time at HD. ACE has everything you will need. I had already tried doing something with my stock tow hook. I had painted it pink. BTW, Krylon makes a color called Watermelon, which looks alot like the cherry blossom red that Grimmspeed sells. Anyways, the tow hook I did purchase at Home Depot. When I purchased the tow hook, that was when I foud out Home Depot sucks for nuts and bolts. The tow hook is rated for 3,000 lbs. ![]() I used Regal Red for the color of my tow hook. ![]() ![]() ![]() ![]() I used 6 washer for the inside of the tow hook. The diameter of the inside circle and the bolt that goes in the washers is 12mm. (Not the threads on the tow hook. Got it?) The washers are 7/16 washers. ![]() If you want to use a bolt instead of the rod that comes with the tow hook, the bolt is M6 x 1.0 x 20mm and the nut is m6x1.0 ![]() |
#111 |
Member#: 274205
SWIC
![]() I didnt get the size of the washers I put to hold in the washers inside the tow hook. Same inside diameter, but the flat washers are bigger so to push up on the tow hook and hold the washers in securely. But since you will be at ACE, you can try a few flat washers out and make sure the fitment is right for your needs.
![]() I didnt get a pic of the tow hook when I first put it together. I was so excited to have finally completed it. But here are some pics when I put it on after I drilled the tow hook cover and plasti dipped the tow hook matte back. ![]() ![]() ![]() Tip/Advice: I drilled through the tow hook cover. TO be honest, I kind of messed it up. I tried using a cardboard mock up of the hole where the cover goes and eye balling where the tow hook would go. You are going to need a HUGE uni-bit. If I remember correctly, the diameter of the threads on the actual tow hook was 19mm. I used a rubber gromit to hide the error and it looks much nicer and professional looking. So make sure you have the right tools or just dont drill into the cover. If the Styrofoam in the bumper shows, spray paint it black. Almost done! ![]() ![]() Taped it off again and plasti dipped what had got rubbed off or needed to be touched up. ![]() All done! ![]() |
#112 |
Member#: 408230
South East
Vehicle:2013 XV Crosstrek Satin White Pearl |
![]() What size is the D ring shackle?
#113 |
Member#: 338863
Vehicle:PSM 05 WRX WGN 5MT 95 Caprice 6spd Track Rat |
![]() Thanks for the writeup - trying to sort a better solution for my occasionally tracked wagon and I'm fond of. I'd prefer a strap but this may work without re-engineering the wheel.
#114 |
Member#: 450713
Vehicle:2017 WRX Stage 3ish world rally blue |
![]() step 1- get oem tow hook out of trunk
step 2- screw in tow hook /thread |
#115 |
Member#: 521623
![]() anyone adding a rubber coating or cover on the bottom so it doesn't bang the bumper every time you start and stop?
Front tow hook w/ FMIC | Vahnatai | Interior & Exterior Modification | 45 | 09-09-2008 03:35 PM |
Front Tow Hook? With FMIC?? | Thran | Interior & Exterior Modification | 8 | 02-05-2008 02:24 PM |
front tow hook | subwrx03 | Interior & Exterior Modification | 15 | 05-31-2006 11:48 AM |
APS FMIC, bugeye WRX and the front tow hook. | Kwyjibo | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 10-19-2004 12:25 AM |
Do '93-01 Impreza's have two front tow hooks? | annointed | Tri-State Area Forum | 3 | 07-05-2004 11:12 PM |
