10-04-2018, 10:05 AM | #26 |
Member#: 488754
Gonna have to check to see if my '19 Limited will have the harness. If it does I'm gonna put the camera in.
10-04-2018, 12:16 PM | #27 |
Member#: 1994
Vehicle:2018 STI WRB |
Need to update my modifications list.
10-05-2018, 06:07 PM | #28 |
Member#: 400310
W. Canada
Vehicle:2017 WRX Sport Crystal White Pearl |
It would be cool if this could function as a dashcam.
10-12-2018, 04:12 AM | #29 | |||
Member#: 446616
Vehicle:2018 WRX Limited Lapis Blue Pearl |
Definitely could be done, I've seen on the Forester forum where someone utilized the factory backup cam to record the rear. However the field of view on the front cam is really wide, a car 10 feet away is like a speck in the distance. It's really just suited for stuff that's close to the front end. |
10-12-2018, 07:04 AM | #30 |
Member#: 490822
International
Vehicle:2018 WRX Pure Red |
Great work Andrew, I am very keen to do this on my 2018 WRX.
Could you PM me the details on your harness? Price etc? I just took delivery of a pure red WRX CVT w/eyesight Base MY18 here in Australia. Lucky for us even the base models have the steering responsive headlights as standard. I will check out to see if I have the wiring required on my car over the weekend and report back. cheers, Michael |
10-12-2018, 03:22 PM | #31 |
Member#: 467197
Vehicle:2018 Sti Limited White |
following
10-23-2018, 02:59 PM | #32 |
Member#: 492921
Could you PM me the details on your harness also?
thanks, Brian |
10-23-2018, 08:51 PM | #33 | |
Member#: 446616
PM'd! |
10-23-2018, 11:10 PM | #34 |
Member#: 490151
Vehicle:2018 WRX STI Limited Ice Silver Metallic |
Excellent
Now this is an excellent post. Very detailed. I’m definitely interested in this mod. I have a 2018 STI Limited. Where do I start? Thanks.
10-24-2018, 06:45 AM | #35 | |
Member#: 490822
International
Will report back. |
10-29-2018, 03:33 PM | #36 |
Member#: 492921
PMed a reply to you, thanks!
10-30-2018, 12:55 PM | #37 |
Member#: 228010
Vehicle:2019 WRX Limited Crystal White Pearl |
My camera was supposed to ship Oct 15... still hasnt. Realllly back ordered.
10-30-2018, 03:39 PM | #38 |
Member#: 424843
Vehicle:2016 WRX Limited 6MT ISM |
Does anyone know if this will work with the older MFD in the 2015-2017 WRXs?
10-30-2018, 07:06 PM | #39 |
Member#: 207263
Vehicle:2019 WRX Limited World Rally Blue |
11-06-2018, 12:31 PM | #40 |
Member#: 271457
PM sent for harness
11-07-2018, 05:48 PM | #41 |
Member#: 387467
Vehicle:2018 WRX Limited WRB Stage 2 FlexFuel |
I’m pretty sure I talked to you on FB about this once and it looks like you’ve taken it a long way! 2018 USDM Limited HK 6MT. Do I just need the front camera and your T harness?
11-07-2018, 09:02 PM | #42 |
Member#: 491727
Vehicle:2019 WRX White |
I bought the harness from Andrew and just finished my install last night!
I bought the camera from here: https://www.subarusource.com/oem-par...iew-86357va010 I also bought screws, but instead just used the ones from the blank that was already in the bumper. Gallery is here: https://imgur.com/a/yv0QbKR Last edited by motojo; 11-07-2018 at 09:04 PM. Reason: Added wrong image URL |
11-07-2018, 09:18 PM | #43 | |
Member#: 207263
11-09-2018, 07:49 AM | #44 |
Member#: 228010
Did mine last night too.. took ~1 hour. The hardest part was getting the bumper back on which wasnt even that bad. Had the car on a 2x 2x6 ramp and it lined up at the perfect height to set the bumper onto some empty pampers diaper boxes I had lying around.. did the project alone.
I ran my wire different from the post above and more in line with OPs pathway. I have a lot of pics Ill try and post later. |
11-11-2018, 12:41 AM | #45 |
Member#: 225505
Vehicle:2018 WRX Limited 6MT Lapis Blue Pearl |
Did my install today. Hardest part for me was disconnecting the connectors above the washer fluid tank. I couldn't get any leverage on it at all, so I had to remove the battery to get to the top of the clip that holds the connector to the body. Once that was free, I could rotate the connector a bit to get the leverage to disconnect them. Other than that, the rest of the install was pretty straightforward. I also had to reprogram the auto up/down buttons for the front windows since I disconnected the battery.
Thanks again, Andrew! |
11-11-2018, 06:45 PM | #46 | ||||||
Member#: 446616
11-13-2018, 09:17 AM | #47 |
Member#: 491727
Manual Transmission
11-13-2018, 09:20 AM | #48 | |
Member#: 491727
11-13-2018, 04:46 PM | #49 |
Member#: 491632
Vehicle:2018 WRX |
this is really cool! waiting for confirmation that this will work with the base model WRX without active turning headlights before i order parts
11-13-2018, 06:13 PM | #50 |
Member#: 446616
