Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Old 12-12-2020, 08:44 PM   #26
Scargod
Member#: 260314
2007 STI
silver gray metallic
Default 2009 Fozzy XT with remote MAP sensor I need to Upgrade
I'm in the weeds with this Fozzy and its "Plastic Fantastic" manifold. I want to make a little over 300 HP with 2014 WRX turbo/intercooler parts. I have ported W25 heads and a built SB.
I have stripped out all the emissions crap and am dieting the harness. I recently realized that the MAP is not on the throttle body!
This thread seems to address many of my concerns but a new one has popped up. Some of the three and four bar MAP's (sometimes with adapters, like the Cobb) can be expensive. I don't see the point in paying $200 for a simple pressure transducer and adapter. It doesn't seem like rocket science and I can fab about anything to adapt a sensor (pressure transducer).
If I'm going to get the Fozzy tuned, is there any reason not to buy almost any three or four BAR sensor?
Any recommendations or issues?
Why would this not work?
Or, even this, for $15!
Scargod is offline   Reply With Quote
Old 12-22-2020, 01:14 PM   #27
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
You absolutely need to filter the line pre sensor. My buddy had same issue. Added a filter and signal smoothed out. The lgt has a filter from factory as it's sensor is external. The sti has a jammed airway to sensor so it's filtered inside the throttle body channel itself. So grab a lgt map sensor filter from dealership or someplace.
Rocket science simplified! Your welcome!
Also wanted to add a hard line would be a good idea along with filter as the sensor is a dead end. And it can swell a silicone hose that's really only meant for vacuum under boost. The map sensor has no bleed off hole. Suppose one would help. Can run it in loop so it's not a vacuum leak also.. like tial should do with there bov and waste gate cough cough. The only boost leak I haven't been able to fix just yet! Lol.
Old 12-22-2020, 02:17 PM   #28
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
GM map sensors is what we have used on plenty of rally/time attack cars here with good results
I'd never put on on my street car though because of my OCD
Hyper is offline   Reply With Quote
Old 12-22-2020, 11:05 PM   #29
panel
Member#: 352704
1965 Vw panel bus
with an EJ20 Turbo Swap
I know this post is old but the current thread is still alive.
Can someone tell me where you can buy one of these or what they look like ? What year Legacy GT ?
Originally Posted by spoolinsti05 View Post
Add a filter like one found on the legacy gt boom there's your smoothing!
panel is offline   Reply With Quote
Old 12-22-2020, 11:24 PM   #30
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
22663AA010 should be what you're looking for.
Old 12-23-2020, 09:52 PM   #31
panel
Member#: 352704
1965 Vw panel bus
Thx
Where is the best place to get an Up Pipe installed in East TN? tblackgt350 South East Region Forum 8 01-05-2007 11:16 PM
[EGT,OIL]Where is the best place to install the sensors to my gauges in the engine? west Interior & Exterior Modification 2 05-06-2005 09:04 PM
Where is the best place to get STI pillow mounts. Rallyspec North West Impreza Club Forum -- NWIC 3 11-06-2001 03:46 AM
where is the best place to buy agj sway bar and solid mounts? wop Brakes, Steering & Suspension 8 06-27-2001 11:57 AM
Where is the best place to buy an Impreza? Racer X Mid West Subaru Owners Club Forum -- MWSOC 6 09-30-2000 07:56 PM
