Welcome to the North American Subaru Impreza Owners Club Tuesday April 13, 2021
Old 01-11-2021, 10:02 PM   #1
Dreed_ruu
Member#: 518500
Default Sti ecu
So I have a 2012 wrx I’m about to build I have a 257 block b25 heads and I’m about to get and sti intake manifold do I need to get and sti ecu or can I just use my wrx ecu?
Dreed_ruu is offline   Reply With Quote
Old 01-11-2021, 11:08 PM   #2
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
If you do a sti trans you'll want the sti ecu for dccd or a controller. But you can run the wrx ecu for sure. Compression was actually higher on your other engine. Why did you swap the ej255 is just as good. And the d25 cylinder head are better imo.
Old 01-13-2021, 12:44 PM   #3
Dreed_ruu
Member#: 518500
I thought I had motor problems heard a loud ticking coming from the driver side in the engine bay then it started to missfire so I changed all the spark plugs and the missfire and ticking when away cylinder 2 spark plug wasn’t even hand tight so that was the source of the ticking but I had already bought the motor and the heads but have not gotten the valve train yet
Old 01-15-2021, 12:16 AM   #4
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
If you tightened the plug and They came loose. Could habe some pre ignition going on.
