Welcome to the North American Subaru Impreza Owners Club Saturday April 10, 2021
Old 01-26-2021, 10:19 AM   #1
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Default Ngk ruthenium spark plugs?
Hey all, its about time to replace spark plugs in my "stg 2+" 05 Wrx ej205.
Las time I replaced them I used the tried n true Ngk Iridium Ix stock heat range plugs. I went to order them again, and noticed there are now Iridium Ix, laser Iridium, and Ruthenium options.
It seems Ngk is sayong their laser iridiums are "better" than their Iridium Ix, and their Ruthenium plugs are "better" than all...
Has anyone used these? Or are Ngk Iridium Ix still the "best" go-to plugs?
4eat05 is offline   Reply With Quote
Old 01-26-2021, 09:03 PM   #2
tomacGTi
Member#: 297396
I have the Ruthenium plugs. One step colder.
New, they "feel" the same. Same power, economy, etc. I had been using the IXs but at 60k, you could tell that the gap had opened and it was time for replacement. The Rutheniums are at about 20k now so too early to compare.
-Randy
tomacGTi is online now   Reply With Quote
Old 01-26-2021, 09:54 PM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
There are no best plugs. If you use the very best plugs and get dyno tuned, then remove them and put in 4 random spark plugs from four neighbor's lawnmowers and get tuned, the dyno graphs will be within the dyno's normal error factors. Now you and other can discuss this ad nauseum, but you heard it hear first....it makes no difference.
Old 01-27-2021, 05:43 AM   #4
tomacGTi
Member#: 297396
The difference is in longevity, hence the difference in materials.
Should have stated that from the outset. They all do the same thing, the difference is how long they can continue to do it as new.
Old 01-27-2021, 10:10 AM   #5
snow_bound26
Member#: 395793
2005 92x Aero
Beige
What's the expected longevity for them? In OEM applications, iridium has a 100,000 mile change interval. I've been able to get 70,000ish on highly tuned vehicles with iridium. What's the cost difference between the 2? I can't really see the benefit of going longer intervals than what iridium already gives us unless these are far cheaper and create just as good of a spark for the same amount of miles.
snow_bound26 is online now   Reply With Quote
Old 01-27-2021, 12:25 PM   #6
tomacGTi
Member#: 297396
Cost difference: couple of dollars.
Change interval: most cases determined by the OEM as well as ease of change. Also see above. Ruthenium is supposed to be harder wearing than the Laser Plus but like I said, anecdotally, I am 20k in. I don't have an opinion just yet.
If you're buying millions of these things at a time and only ever have to do them once versus multiple times during a warranty period, you save money. Obviously as an enthusiast and someone who modifies/plays with their car, your expectations change.
I, for one, coming from the inline world to Subaru, loath a spark plug swap simply because of access. You get used to it versus easier and I would rather put in a good plug that will last awhile and cost more versus constantly swapping out as the performance degrades.
Also, newer, better materials always go to the front and cost more versus older, known ones. Technological advancement and all.
Bigger, better, more, fat free, low carb, organic....
-Randy
Old 01-27-2021, 12:52 PM   #7
Jedi03
Member#: 491095
2009 STi Blue
is it genuinely longevity or marketing?
Jedi03 is offline   Reply With Quote
Old 01-28-2021, 06:44 AM   #8
tomacGTi
Member#: 297396
That's a question for NGK. They are a reputable brand though and not known for baseless gimmicks.
https://ngksparkplugs.com/en/product...um-spark-plugs
In my motor, so far, they do their job. As I've stated earlier, it's too soon to tell you what longevity will ultimately be at 20k.
Old 01-29-2021, 02:45 AM   #9
MortonCharbo
Member#: 487057
2002 WRX Wagon
Yes
MortonCharbo is offline   Reply With Quote
Old 03-07-2021, 06:24 PM   #10
yliu14
Member#: 522835
1998 Impreza WRX STI
I believe when you gap your spark plugs based on your boost level, all spark plugs work fine.
Remember to change them regularly, carbon built up on all types of spark plugs.
yliu14 is offline   Reply With Quote
