Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Old 05-23-2006, 03:23 AM   #1
Godfather Inc 03
Member#: 84050
Default STi Side Splitter Install Question
Anyone have experience installing on 05 WRX? There are little clamps that are supposed to go into the bumper...but my wrx bumper doesnt have a spot for them. Im pretty sure if i break the clips off and use some 3m tape and fasten the clips on bottom and the sides it will work...but i was just wondering if anyone else had this experience....thanx
Mike
Godfather Inc 03 is offline   Reply With Quote
Old 05-23-2006, 03:26 AM   #2
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
i didn't shave the 3 upper clips. i drilled 3 small slits into the bumper. but i did shave the ones on the inner side of the splitters down. i didn't use double sided tape. you can if you'd like though.
Bishop is offline   Reply With Quote
Old 05-23-2006, 04:49 AM   #3
Dragicon
Member#: 112323
I used a dremel for the slots on the top of the bumper which you speak of... fits like a dream.
Dragicon is offline   Reply With Quote
Old 05-23-2006, 02:20 PM   #4
kyuu
Member#: 99856
It's better if you go and cut the holes in the bumper but since I don't trust myself with a dremel I just cut the tabs off and used 3M doublesided tape
kyuu is offline   Reply With Quote
Old 05-23-2006, 03:30 PM   #5
nate.the.great
Member#: 72031
2017 SS 1LE
btw j*bishop, your wagon looks great. it has a very clean look. i also see that you can still clear rhino ramps. are you still on stock suspension?
nate.the.great is offline   Reply With Quote
Old 05-23-2006, 03:40 PM   #6
Bishop
Member#: 59993
Ass, grass or cash
thx mang. unfortunately i can no longer clear the ramps. if you look at the last pic i installed a replica v-limited lip from e-auto. w/out the lip yes. the wagon is lowered on STi wagon specs. if you do a search under my name you'll see a few more pics of the wagon at different angles.
Old 05-23-2006, 06:40 PM   #7
Godfather Inc 03
Member#: 84050
thanx...i took the clips off and those things on the inside...thanks alot.
Mike
Old 05-23-2006, 07:47 PM   #8
Bishop
Member#: 59993
Ass, grass or cash
mike,
let's see the pics man!!
Old 05-24-2006, 02:49 AM   #9
Godfather Inc 03
Member#: 84050
alrite...im getting a car wash tommorrow...ill try to get some pics up
Old 05-24-2006, 08:09 AM   #10
nate.the.great
Member#: 72031
2017 SS 1LE
i just installed them. omg, just cut all the tabs off. cutting your bumper is such a pain, esp. with a dremel because it melts it a little. remember that the two side tabs need to be cut off. you have to remove the white part, and then cut off the tabs.
Old 05-24-2006, 09:09 PM   #11
WRXDriftR
Member#: 65065
2004 EJ205 STi
2007 Forester STi
i used a boxcutter and screwdriver to make the 3 bumper holes for the upper tabs. its very secure, rather than taping, but i cant ever remove them now! lol
WRXDriftR is offline   Reply With Quote
Old 05-24-2006, 09:28 PM   #12
Bishop
Member#: 59993
Ass, grass or cash
boxcutter.... i should have done that.
Old 05-25-2006, 12:55 AM   #13
Godfather Inc 03
Member#: 84050
hey... here is a quick pic..i didnt have time to take a pic until now sorry...ill try to take some in day light.
http://www.putfile.com/sk8er3693
Mike
Old 05-25-2006, 11:28 PM   #14
wrXmon
Member#: 115454
My 2002 WRX Wagon
still gets compliments.
J*Bishop, your car looks awesome.
wrXmon is offline   Reply With Quote
Old 05-25-2006, 11:59 PM   #15
Bishop
Member#: 59993
Ass, grass or cash
thank you very much sir!
Old 05-26-2006, 12:37 AM   #16
yogi's wagon
Member#: 41787
2004 WRX Wagon
Would it be possible to have a close-up picture of thi area
You can show it here or by e-mail : [email protected]
BTW, nice set-up
yogi's wagon is offline   Reply With Quote
Old 05-26-2006, 12:44 AM   #17
Bishop
Member#: 59993
Ass, grass or cash
sure but i won't be able to get it to ya till this weekend. my sister has my camera at the moment. i know the peice you wanna see. you'll need to shave the splitter down just a tad at that spot so it'll sit flush.
remember guys. i'm about 90% happy w/this setup seeing that these parts are ment for the sedan. the fit is very good but not perfect.
thx!
Old 05-26-2006, 12:51 AM   #18
Bishop
Member#: 59993
Ass, grass or cash
this is all i have for now.
Old 05-26-2006, 12:51 AM   #19
yogi's wagon
Member#: 41787
2004 WRX Wagon
No prob,anyway i'm still waiting on some parts. What I really want to see, is the fitment between the lip and the splitter at that point. Is there any gaps or it sits thight.
Old 05-30-2006, 01:13 PM   #20
FelixTheCat
Member#: 86143
2005 WRX
Platinum Silver Metallic
I installed the splitters on my 05 WRX a few weeks ago. I used the dremel method and made three 3/4 inch cuts in the bumper for the three tabs on the splitters to fit into, and used the six bolts and clips to secure the bottom part of the splitter to the bumper (3 on each side). I unfortunately made the cuts on one side too large and had to use a 8-10" strip of 3M double sided tape to secure the top part of the splitter to the bumper.
I wasn't worried about cutting into the car since I wasn't ever going to take the splitters out, but I guess my advice would be to measure twice and cut once and keep test fitting the tabs into the three slits to make sure you don't make the slits too big. The three tabs should fit snuggly into the three cut slots. The problem with the dremel I found was the pastic melts and you have to burn off the plastic from the dremel bit with a flame (lighter) and wipe the plastic off from time to time.
I used this thread as my guide: http://forums.nasioc.com/forums/showthread.php?t=531720
FelixTheCat is offline   Reply With Quote
Old 05-30-2006, 01:29 PM   #21
REVNU
Member#: 82147
2005 WRX Sedan
I did NOT drill into my bumper. I dremeled off the tabs and then used 3m tape on the edges, the bottom bolts and two clips in the fender. It is on there pretty solid and isn't going anywhere. I just know that when I go to sell the car that I want to be able to return it back to stock, which would be pretty hard with holes in my bumper. Here are some pics:
~REVNU
REVNU is offline   Reply With Quote
Old 08-15-2006, 12:44 PM   #22
swhempe
Member#: 116738
2004 WRX Wgn
Installed the splitters over the weekend, cut off the two plugs, but left the three tabs. Holes didn't lineup under the bumper, but cut my own holes and the splitters fit fine. Now I have to get painted side skirts to make it look good.
swhempe is offline   Reply With Quote
STI Side splitter install jonthesloth Interior & Exterior Modification 18 05-03-2009 03:14 PM
STi side splitters install Cannonbolt Interior & Exterior Modification 9 07-23-2008 04:14 PM
05 WRX Sti Front Splitter Install Question whitecel Newbies & FAQs 7 01-21-2007 10:39 PM
proper removal/installation of STI side splitters? overdose Interior & Exterior Modification 4 02-17-2006 09:44 AM
STI Side Marker Install Question WRXURV8 Interior & Exterior Modification 1 12-01-2002 02:13 PM
