#1 |
Member#: 116616
South East
Vehicle:06 STi SGM |
![]() Driverside windshield wiper is makeing a click when it moves all the way to the left.
It is like it is almost sticking to the fram of the windshield. Is there a way to adjust the arm so I could keep it off the frame to avoid this VERY aggravating clicking noise?
#2 |
Member#: 112719
Vehicle:2014 Evolution X GSR 2006 TSX 6MT |
![]() Warranty... ?
#3 |
Member#: 39852
Vehicle:2010 40th Annv. 370Z 04 JBP FXTi |
![]() mine does the same thing...?
#4 |
Member#: 107312
Vehicle:06 STI Aspen White |
![]() ditto
#5 |
Member#: 76673
Vehicle:2006 Impreza WRX STi Crystal Grey Metallic |
![]() Yep, Mine too. They should be able to go to a dealer to fix it. But it pisses me off too!
#6 |
Member#: 97207
TXIC
Vehicle:2017 STI |
#7 |
Member#: 122167
Vehicle:2008 Mazda CX-9 GT Liquid Platinum Metallic |
![]() you should be able to adjust the wipers by popping off the plug that hides the screw that holds the wiper arm to the motor. Once you loosen the nut just try to pull up on the wiper and move it. When you pull up on the wiper you basically move it up from the teeth thats holding it in. When you adjust it to the desired position you can push it back into place, tighten the nut and you are done. I did it with my 06 when the wipers sat too high. It was very annoying.
#8 |
Member#: 116616
South East
![]() well this has gotten so bad I have just about stopped using my wipers. The noise makes me so mad now.
after a rainy weekend at the dragon I have to get this fixed. So you guys are saying that this will coverable by my warranty? If so I am going straight down to the subaru dealership tomorrow and getting the problem fixed. Hopefully they can figure it out in little time. |
#9 | |
Member#: 97207
TXIC
Vehicle:2017 STI |
![]() Quote:
warranty yes. "little time" may be another story. depends on what "that" means to you. ![]() |
#10 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
![]() ....sometimes the blade starts coming off the assembly and makes this kind of noise....check the assembly
#11 | |
Member#: 116616
South East
![]() Quote:
![]() Thanks for the tip! ![]() |
#12 |
Member#: 30539
Vehicle:2002 WRX... 2005 STI |
![]() Mine does this as well. It doesn't appear to be hitting anything on my car. From what I have seen, when the wiper starts moving back down, the blade sticks a bit, so the wiper assembly itself clicks against the windshield before the blade starts to move. I have only experienced this when the wipers are on the faster settings. Mine is an 05 sti.
#13 |
Member#: 22525
Vehicle:2006 Subaru WRX STI Blue |
![]() I replaced the wiper rubber only with Trico part # 45-220 since they needed to be replaced anyway and the clicking is gone now.
#14 | |
Member#: 116616
South East
![]() Quote:
Mine seemed to be the same, i dont know why but moving it over only a couple of notches at the gear really made a difference. Now i dont dread driving when it rains because i dont have to listen to my wipers making that horrible noise. |
#15 |
Member#: 20297
Vehicle:'12 WRX Ltd. Wagon B4: '02 Stg 2; '07 Stg 3 |
![]() Same issue on my 07 WRX Ltd Wagon. It is not coming from the blades themselves, but from a something under the dash. Timed to the movement of my wipers. Really effing annoying.
#16 |
Member#: 121883
E. Canada
![]() I've got this same problem. I've got the reflect wipers though, and it's definately coming from the blade. It occurs as soon as the wiper blade switches directions and bents/folds the rubber from one way to the other.
I think it's due to dry wipers, try a new one and see ! I've gotta do it also.. it's really ANNOYING. |
06 wrx cluster swap to the 06 sti cluster problems... | knighter | Electrical & Lighting | 1 | 10-07-2009 09:14 PM |
06 STI BOOST Problem - Any Suggestions? | QueensKid | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 32 | 01-04-2007 01:27 PM |
06 sti slight problem.... | kessler89 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 16 | 06-05-2006 01:20 PM |
06 STI coolant problem | TurboDXsti | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 05-25-2006 11:47 AM |
06 sti exhaust problems | 06blacksti | Newbies & FAQs | 9 | 02-06-2006 12:43 PM |
