Welcome to the North American Subaru Impreza Owners Club Saturday April 17, 2021
Old 11-19-2008, 05:16 AM   #1
jonthesloth
Member#: 184390
1999 Forester
GREEN
Cool STI Side splitter install
so I am going to use my friends dremel, I just want to know what tip/bit I should use to cut the three little sliits. Any suggestions or a step by step walkthrough or instructions would be appreciated too.
Thank you, - Jon
jonthesloth is offline   Reply With Quote
Old 11-19-2008, 10:33 AM   #2
ekw
Member#: 92141
2014 GT-NC-PRHT
Zeal Red.
why does it look like you took the picture from this thread
http://forums.nasioc.com/forums/showthread.php?t=531720
did you read the thread?
or did you randomly find the same pic & never actually see the thread?
see also
http://forums.nasioc.com/forums/show....php?t=1079477
http://forums.nasioc.com/forums/show....php?t=1010157
http://forums.nasioc.com/forums/show....php?t=1017537
http://forums.nasioc.com/forums/show...hreadid=406763
yes - my search crushes all.
ekw is offline   Reply With Quote
Old 11-19-2008, 11:04 AM   #3
WRX66
Member#: 73242
2005 WRX
I just did this about 2 months ago. Wish I would have tried using a knife/razor. Used a dremel and made the holes a little to wide. The part you make the holes in is a lip so you have to be careful and steady. Use smallest bit possible.
WRX66 is offline   Reply With Quote
Old 11-19-2008, 02:01 PM   #4
FCPremixx
Member#: 181184
2016 Forester XT
CWP
If you just use some 3M tape to hold it on will there be any issues if you ever want to take them off?
FCPremixx is offline   Reply With Quote
Old 11-19-2008, 03:00 PM   #5
jonthesloth
Member#: 184390
1999 Forester
GREEN
see also
Because i did take the picture from that thread. There wasn't any specifics on dremel size ( i pretty much have never used a dremel before).
Anyways im trying to get my car to look something like this (from the same thread):
can anyone tell me what rims these are, and if you know of any 5 star gunmetalish type rims. And what is a good brand of coilovers used or new.
anyhelp would be great!! thanks
Old 11-19-2008, 06:28 PM   #6
twizhimself
Member#: 58294
2004 WRX / 1998 Foz
SoCal F4 #20 / Area1320
what i did was put a little paint on the tabs on the splitters, placed then where i wanted them on the bumper and carved away with an exacto...worked out really well for me (didnt have access to a dremel at the time)
those look like Prodrive GC05's
as for coilovers, BC's are good adn cheap, megans are good and cheap, i personally have Tein SS-P and i think theyre excellent...esp since i dont track my car that much
twizhimself is offline   Reply With Quote
Old 11-19-2008, 07:30 PM   #7
jbwrx
Member#: 86274
. Andrewtech
Gold Club Member
I just cut all the tabs off and used 3m double sided tape just in case I want to take them off later down the road. They have been on for a few months with no issues. They are alo held on by 3 bolts to just incase the tape does fail they won't just fall off.
jbwrx is offline   Reply With Quote
Old 11-19-2008, 07:56 PM   #8
thejordan
Member#: 185374
+1 on 3M tape and not cutting the bumper.
its more clean and a better fit IMO cause of the tape.
thejordan is offline   Reply With Quote
Old 11-19-2008, 08:24 PM   #9
jonthesloth
Member#: 184390
1999 Forester
GREEN
Sooo.... I went ahead and cut into my bumper anyways. I did not use a dremel.
for those of you that havent dont this, my way is possibly the most mickey moused way of all....but it worked.
I used a small drill bit on a drill and drilled two holes just wide enough for the tabs (something like this) .=drill _=space
.______.
Then i drilled more holes in between those holes.
._._._._.
I upgraded the drill bit to a bigger one, and once all the holes connected and became one rectangle void; I popped these puppys on, and now my car looks awsome
:dis co:
The 3mTape method is good, and I do understand that if the tape fails, at least the bolts wont. I was going to do this way, but I found a drill and now thats that.
I will post pics once I get home, for now i gotta go to class. Thank you all for your help and thanks for the identification on those rims.
I kind of want thicker 5 stars, anyone have any suggestions?
Old 11-20-2008, 12:37 PM   #10
jonthesloth
Member#: 184390
1999 Forester
GREEN
Default pics
Old 11-20-2008, 02:13 PM   #11
Rodini14
Member#: 179908
2005 WRX
CGM
don't see anything ^
Rodini14 is offline   Reply With Quote
Old 11-20-2008, 03:20 PM   #12
jonthesloth
Member#: 184390
1999 Forester
GREEN
errrmmm pbase sucks whats a good image hosting site
Old 11-20-2008, 03:51 PM   #13
Rodini14
Member#: 179908
2005 WRX
CGM
i just always used photobucket
Old 12-04-2008, 10:44 PM   #14
JasonM1
Member#: 107931
2004 WRX Cobb Stg. 2
If you want to put a lip on later down the road how well will the splitters hold up if they are just taped on?
JasonM1 is offline   Reply With Quote
Old 12-05-2008, 03:19 AM   #15
Hot Wheels
Member#: 195102
04 & イン
アスペ&
buy a cusco lip , problem solved. the cusco lip actually makes STi's remove the splitters.
Hot Wheels is offline   Reply With Quote
Old 12-05-2008, 03:22 AM   #16
Hot Wheels
Member#: 195102
04 & イン
アスペ&
Old 05-02-2009, 09:11 AM   #17
SubieNeeks21
Member#: 178661
05 3500 cummins
bullydogged
cutting those taps off didn't make it too loose?
SubieNeeks21 is offline   Reply With Quote
Old 05-02-2009, 02:39 PM   #18
05_2.5
Member#: 120328
2005 Legacy wagon
RBP
I just installed these on my RS yesterday and i used a flat screwdriver to carefully pried off the tabs and then used wire cutters to cut off the plastic "rivets" that held them on. When it came to attaching them I ditched the 2 plastic body clips that held the splash guard to the underside of the bumper on each side and used the supplied clip nuts and bolts on those holes.
05_2.5 is offline   Reply With Quote
Old 05-03-2009, 03:14 PM   #19
snwboard4life69
Member#: 166788
2003 subaru wrx
stage 3 race car
rims are kyowa
snwboard4life69 is offline   Reply With Quote
Pa: Black Sti Side Splitters! Sti Side Skirts bnr34rb26dett Private 'Wanted' Classifieds 3 02-18-2009 09:50 PM
STi side splitters install Cannonbolt Interior & Exterior Modification 9 07-23-2008 04:14 PM
Some install directions for STI side splitters kit anywhere?? snobrder_ad Interior & Exterior Modification 2 09-20-2007 11:02 PM
STi Side Splitter Install Question Godfather Inc 03 Interior & Exterior Modification 21 08-15-2006 12:44 PM
proper removal/installation of STI side splitters? overdose Interior & Exterior Modification 4 02-17-2006 09:44 AM
