Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Old 01-27-2009, 11:59 PM   #1
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Default Nasty cam journal
Just tore down my ej22g hybrid block in preparation for the new cams and rods, and I came across this:
Looks like particulate damage to me... but the real question is, are the heads garbage? I'd rather not have to try and source new heads, but I'll do whatever it takes.
I'm trying to max out my TD06H-20G, so 450-480chp, and up to 7800rpm.
Splinter is offline   Reply With Quote
Old 01-28-2009, 12:20 AM   #2
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
You can have a machine shop line bore the cam journals. They remove a small bit of material from the cap base and then line bore back to proper bore. Its expensive but it works. For what its worth that pic isnt too bad, I have seen way worse. The load is much less than what a engine bearing sees on the rods and mains. It does see some load from the valve springs but not comparable.
Honestly I would just use a very fine croachas cloth and hand polish it. If you really concearned take it to a machine sop and have them mic the bore and check what the max tolerence is...
Sinister redlines is offline   Reply With Quote
Old 01-28-2009, 12:48 AM   #3
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
We have a machine shop at the auto parts store I work out, one of the only ones in the city, but they mostly do factory rebuilds and SBC builds, I'm pretty sure I've supplied them with half the subaru motors they've worked on
Maybe I'll fire off a pic to Jon at delta... he did my cams afterall.
Old 01-28-2009, 12:06 PM   #4
[email protected] Auto
Member#: 189490
Get a new head. The info given above is false and you will damage your engine if you will reuse them. How are the other bearings(main, rods) look like?
Artie
Artie@Agile Auto is offline   Reply With Quote
Old 01-28-2009, 12:30 PM   #5
kingsubi
Member#: 19239
2011 WRX
Jon at Delta had to line bore my head as well after a failed rod bearing. Material gets into the oil pathways and then eats the journal. The only real way to do it however is to undersize the journal and then weld on extra material to the cam.
This mates the cam to the head forever...
kingsubi is offline   Reply With Quote
Old 01-28-2009, 12:48 PM   #6
ryan_west06
Member#: 139045
05 STI SnowmanTune
for us noobs, can you please explain what is damaged... I like to learn things everyday.
ryan_west06 is offline   Reply With Quote
Old 01-28-2009, 01:47 PM   #7
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Artie
The other cam journals are fine, so my guess is there was some junk in the oil journal right under there that got into the cam journal.
Haven't gotten into the shortblock yet.
Ryan West: The cam journal is the oiling surface for the cams, cams in subaru engines dont ride in bearings, they're not generally much of a wear surface.
Old 01-28-2009, 02:03 PM   #8
BallPeenHamr
Member#: 126526
2007 STi Limited
#339 UGM -SOLD
Your head might not be toast. Look at the underside of the cam cap that goes over that journal... because its the cap that bears all of the load. If it is worse than the bottom half, then it might be questionable.. in which case I'd look into having it repaired by a competent machine shop.
Polish up the marking by hand with grey scotch brite... don't dig in much; just remove the high spots. Then dab some oil in the lournals, install the cam (torque it up with the other cam caps too) while it's completely disassembled. Check to make sure the cam spins freely by hand. Setup a dial indicator on the top of the cam, then move the cam up and down. If there is more than .002" of deflection, the head needs to be repaired or replaced. If not, i'd say run it. There should also be .003" to .005" of cam end play as well.
It would be a good idea to remove all of the oil galley plugs on the head(s) and make sure the oil galleys are clean/free of debris before you think about re-using them. I'd get an upgraded oil pump while you are at it too..
.02
It would also help to upgrade the oil pump while the engine is apart too..
BallPeenHamr is offline   Reply With Quote
Old 01-28-2009, 02:38 PM   #9
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
I'm running a 10mm oil pump, I dont think it's necessary to run bigger than that for my setup (no avcs)
I'm bringing it to a machine shop this afternoon for them to look at.
Old 01-28-2009, 05:29 PM   #10
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
machine shop says its repairable
Old 01-28-2009, 05:48 PM   #11
ryan_west06
Member#: 139045
05 STI SnowmanTune
since im new at this, id still like to know what im looking at that needs to be fixed. can someone school me please?
Old 01-28-2009, 06:46 PM   #12
Member#: 189490
It's actually very simple. Cams are kept in place by cam journals. Cams are rotating parts in the head and to reduce friction they are lubricated by oil. Cam journals should have a very smooth, mirror type surface. Journals are part of the head casting. Subaru recommends to keep oil clearances (difference between inside diameter of cam journal and outside diameter of cam) somewhere between 0.037 0.072 mm. If the clearance is too big, oil will have less resistance on it's path and oil pressure will drop as a result. If the oil clearance is too small, the parts will not get enough oil to keep them lubricated.
Hope this will help
Old 01-28-2009, 08:31 PM   #13
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Yes we know artie, You said the process I described above wont work yet I have seen MANY reline bored and look good as a new head because it will be machined and its the same process the factory uses and the finish dia will be in spec.....
http://www.enginebuildermag.com/Arti...g_subject.aspx
A good read for you to educate yourself...
And yes I have worked in a machine shop that did the process. Its the same setup as reline boring a block for a crank just in a smaller scale and ra has to be finer...
Old 01-28-2009, 08:59 PM   #14
charliew
Member#: 125304
If it was trash in the gallerie it would also be scuffed in line with the oil feed holes. The area past the feed holes looks ok. It seems to me that the head may be warped. That looks like it will take .010 cut to clean it up minimum. Maybe .020 that means the cam will be .010 or .020 closer to the valve stems. That means either all the stems will need to be shortened or new .010 or .020 thinner buckets. That also means the cams will rotate a little in the advanced position. Has anyone tried welding the journal up and putting it back to original? I would rather do that than have a perminately crummy head.
When you line bore a vw and I think a v8 there are replacement oversize bearings that fill the new gap and the crank or cam stays in the same place, not so on the suby the cam is now closer to the valves forever.
A line bore on the cam bores can look great to the eye as it's now nice and shiney but that doesn't make it a good repair. That will also limit the amount of lift that cam can run before coil or seal bind on the valve. If they are 1500.00 heads I would try to get the journal welded and re bored to stock. If they are 250.00 heads do the cheapest repair.
charliew is offline   Reply With Quote
Old 01-28-2009, 09:53 PM   #15
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
I really don't think it's warped heads for a couple reasons... You can see where grains of something caught and pulled on the aluminum.
The reason that there is a clear line around the oil grove is that on the cam surface, there is a matching machined groove. There is no contact in that area.
Old 01-28-2009, 10:05 PM   #16
charliew
Member#: 125304
Sorry I was looking at the cams in the pictures above. I didn't remember any grooves in the cams I've worked with. It seems that the cap would also be rough. It's like the bore wasn't round. Maybe it was put together real dirty. Do you think plastigage could have been left in it? Usually you would lay the plastigage on top of the cam and put the cap on though.
Old 01-28-2009, 10:09 PM   #17
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
V4 STI cams
Old 01-29-2009, 07:24 AM   #18
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Other than the change to the cam timing, I can't see how any of the other issues you mentioned would be a problem if you properly set the valve clearance after the line bore. You could even correct the timing issue with adjustable sprockets.
bluescoobywagon is offline   Reply With Quote
Old 01-29-2009, 10:04 AM   #19
Thomas Ruble
Member#: 12694
02 WRX/JDM EJ207RA
Unabomber Eeee-thug
Here is what I would do based on my own hands on experiences with rebuilding ej20 motors (my personal motors)...
First establish a baseline by measuring the cam/journal clearances of the non damaged journals. Line hone the subtracted difference from the factory absolute limit and then see what you have. After line honing, if the journal surface still looks quite rough, I would then trash the head as previously suggested by Artie rather than continuing to remove more material. Why take the chance with a "high reving application?"
Personally, I would be worried about the excentric forces and early wear issues created by excess clearances within the journals, not only to the journals surfaces, but also to the cam lobes and buckets.
Hidesight can be a real beotch..
Good luck,
Tom.
Thomas Ruble is offline   Reply With Quote
Old 01-29-2009, 10:26 AM   #20
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Well the shop says that they can machine rod bearings into the cam caps if necessary, which is expensive but it's better than stock, because after that, it becomes dead easy to replace them down the road.
Old 01-29-2009, 10:43 AM   #21
Thomas Ruble
Member#: 12694
02 WRX/JDM EJ207RA
Unabomber Eeee-thug
That is an interesting alternative if the cost ends up being reasonable, especially if you have previously invested in having some headwork done in the past like I have.
Please keep this thread updated because I would love to add your experience to my memory banks for future reference.
Tom
Old 01-29-2009, 02:33 PM   #22
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
I haven't had any headwork yet, I'm running the 98 DOHC/V4 STi heads, which outflow any of the north american turbo heads by a margin from the factory.
The problem is tho, if the machine work is $400, and another set of used heads is $300, I might end up just inheriting someone elses problem, plus all the work of setting up the DOHC NA heads for turbo
Old 01-29-2009, 04:06 PM   #23
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
The managed to repair it, oil clearances are now at .055mm across the board.
They took about half a thou off the bottom of the caps, so the journals are very, very slightly elliptical, but these guys ahve been building high revving engines for years and they said it won't be a problem, especially with the super short subaru cams.
Old 01-29-2009, 09:17 PM   #24
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
I guess what alot of people are missing is that the caps will be slightly machined at thier base to close the bore, then it will be relined to oe specs. Now yes the cam will sit closer to the valves but it will be half of whatever is removed. So if you close the bore by .020" then after reline the cam will be effectively .010" closer to the valve (this is only in the ballpark as thier are machining tolerences that can effect the final measurement).
Now on to the other issue, the valves on most aftermarket suppliers ship thier valves long to be machined to the use on the head. Plus thier are different bucket sizes to help setup clearences.. This is how most subie heads undamaged are setup with aftermarket valves..
This end result is basicly all in the machinist and engine builders hands and can be made good as new with an experienced machinist...
Old 12-21-2019, 12:20 PM   #25
Techninety9
Member#: 509999
Default 07 outback xt
.02
So like said in the thread above subarus don't have cam bearings. The aluminum surface is what the cams ride on. That being said, how long have you guys gotten out of your welded and shaved journals?
Techninety9 is offline   Reply With Quote
Boring cam journals for bearings Splinter Built Motor Discussion 36 10-01-2012 05:38 PM
cam journals? Ds baruuuuu Built Motor Discussion 7 09-12-2010 11:00 PM
closed subydude02 Engine/Power/Exhaust 41 08-11-2010 08:29 AM
Cam Journals Victor1620 Built Motor Discussion 0 09-17-2009 05:56 PM
bolts that hold cam journal caps on, ej205 erice1984 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-12-2005 01:13 PM
