#1 |
Member#: 409168
Vehicle:2015 WRX Limited GBP |
![]() Today I installed JDM power folding mirrors on my 2015 WRX Limited.
Good news for those of you that were thinking of doing this mod, both doors are wired for this mod. Bad news: You have to swap (re-pin) the harness and you have to dremel a hole for the power fold switch. Not a big deal for either but I'll explain. I purchased the "POWER FOLDING MIRROR SET PAINTED VERSION" from Japanparts. I have a Galaxy Blue Pearl WRX but I went with Galaxy Blue Silica. You also need the "83061 SWITCH, REMOTE CONTROL MIRROR" from japanparts. I also bought the "DOOR MIRROR AUTO SYSTEM" but didn't install this as I haven't found instructions for it. It appears you connect it inline to the switch but I'm not sure of the other connections. Here's a pic: http://i.imgur.com/x6BRHhT.jpg First, remove the door panel from the driver's side and remove the factory USDM mirror. For a good tutorial on this, see this youtube video: https://www.youtube.com/watch?v=zp9YxVGqbi0 The JDM mirrors come with a 12 pin harness. The USDM mirrors (at least on my limited) have a 10 pin harness. Inside the door where the harness connects is of course for a 10 pin harness. So you need to remove the pins from both harnesses and re-pin the JDM mirror to the 10 pin harness. Here is the JDM harness: http://i.imgur.com/ExcEUHI.jpg The new JDM mirror will add turn signals and power folding so there will be a total of 9 wires. To remove a pin from the harness, release the locking tabs from the top and bottom and then I just used a safety pin as follows: http://i.imgur.com/L696mKT.jpg Push the safety pin under the pin in the harness and pull out. You will be re-pinning the 10 pin harness just as it was wired for the 12 pin JDM harness. The last 2 pins on the 12 pin harness were blank (no wires were attached). I took comparison pictures so you can see where the wires are supposed to go and in what order: Top of driver's side mirror harness JDM vs USDM: http://i.imgur.com/wAWzZvo.jpg Bottom of driver's side mirror harness: http://i.imgur.com/OKqm0se.jpg Once it has been re-pinned to the 10 pin harness, hook the mirror up to the driver's side and connect the switch (leave the door panel off for now). The switch folding functions and the mirror adjustments should work. Also test the turn signal. Now do the passenger's side the same way. Top of passenger side mirror harness JDM vs USDM: http://i.imgur.com/kdBh7NM.jpg And bottom of passenger side harnesses: http://i.imgur.com/WskLsRV.jpg Once re-pinned, test the mirror as before. One quick note, before testing I would make sure the other mirror is in the same position (folded or unfolded). I'm not sure it matters but just to be safe. So if you want to test your passenger mirror and it's folded currently, before connecting it, connect the switch and driver mirror and make sure the driver's side mirror is folded. Then connect the passenger side and test unfolding both mirrors at once. Just a recommendation. Once tested, bolt both mirrors back up and route and connect the harness in the door. Reattach the door panel on the passenger side (make sure you attach the door handle and door lock cables along with the power window and lock switches). On the driver side door panel, we now have to cut a hole for the folding switch to pop through. You can remove the whole switch panel from the door panel. There are 2 screws holding it in place in the back of the door panel. Then release the locking tabs and push it up through. You can now remove the USDM mirror switch by releasing the locking tabs. Using the JDM folding switch as a template, mark off where you will be cutting the hole. Measure twice, cut once: http://i.imgur.com/wUXsTzL.jpg Push the new JDM switch in to lock it into place. Now lock the entire switch panel back into the http://i.imgur.com/mpGtKCb.jpg Admittedly I did a terrible job cutting the hole and will probably take a dremel buffer wheel or something to it. There may be better options here (European market switch panel?) so any recommendations would be appreciated. Now connect all the wiring to the door panel and reconnect the lock cable and door handle cable. Reattach the door panel and you're all set. Any questions for me, please let me know. Also, if you know how to wire the auto close module, that would be greatly appreciated. Outside shot: http://i.imgur.com/lizNF7w.jpg Here's the mirror in action:
#2 |
Member#: 410602
SCIC
Vehicle:2015 WRX Rally Blue |
![]() That's awesome man! What did this cost you all in? How long for the install?
#3 |
Member#: 361107
Vehicle:2017 WRX |
![]() Awesome DIY! I'm sure this will come in handy for others.
#4 |
Member#: 247999
Vehicle:2015 WRX Limited Crystal White Pearl |
![]() Nice mod!
#5 |
Member#: 395731
SCIC
Vehicle:2015 WRX Premium DGM |
![]() Where do you find the wiring for that connector? I'm interested in figuring out the wiring for adding an auto headlight stalk to a base/premium, but don't know how to determine the wiring scheme.
#6 |
Member#: 403828
![]() Nice write up, will definitely look into this.
#7 |
Member#: 413164
#8 |
Member#: 412639
Vehicle:2015 WRX |
![]() Nice. Would be interested to see exterior pics.
#9 |
Member#: 389122
E. Canada
Vehicle:2015 WRX Sport World Rally Blue |
![]() For the wiring research, did you ever see wires designated for the JDM puddle lights? Perhaps these folding mirrors have the JDM puddle lights?
#10 | |||
Member#: 409168
![]() Quote:
https://www.japanparts.com/parts/detail/45655 https://www.japanparts.com/parts/detail/44705 https://www.japanparts.com/parts/detail/45640 I'm just happy it worked out. Quote:
Video added, thanks! I ran out of daylight yesterday since I started late but will add some shots to the main post in a bit. Quote:
Maybe if someone has a limited with keyless entry they could check to see if it's a 10 pin harness or 12 pin in the door? |
#11 |
Member#: 387113
SCIC
Vehicle:2015 Launch Edition WRB |
![]() I wish that the 2016 would come with an option that is auto folding, auto dimming, heated and welcome lighting enabled. I hope it won't cost as much as this.
#12 |
Member#: 400510
South East
Vehicle:2015 WRX Limited CVT World Rally Blue |
![]() $800!!!!
No thanks. |
#13 |
Member#: 403828
#14 |
Member#: 411320
Vehicle:2015 WRX Limited Galaxy Blue |
#15 |
Member#: 409168
#16 |
Member#: 388585
Vehicle:2015 wrx base ISM |
![]() Pretty sweet upgrade! Not cheap, but nice!
#17 |
Member#: 368649
South East
Vehicle:2020 WRX CWP |
![]() Do you really need new mirrors? I can't imagine there is any difference in the mirror itself.
#18 |
Member#: 386145
Vehicle:2015 WRX Limited CVT Crystal Pearl White |
![]() I think you have to buy them as an assembly and not just individual part numbers. Could be wrong though. I think the JDM mirrors give a wider view so they are better than USDM.
#19 | |
Member#: 409168
![]() Quote:
It would be a good idea to swap out the housings with the USDM one for best viewing angles. The JDM housings work for me because I'm short but it may not work for everyone. So as another step besides swapping the harness, I recommend swapping the housing too. |
#20 |
Member#: 72730
Vehicle:2019 Volvo S60 T6-R SPORT CHASSIS |
![]() Nice job bud! As has always been the case you can go used on the parts to save some money. I have a set of '12 JDM Impreza mirrors with no takers on buying them, perhaps anyone here might be inspired to do this if the price were right...you would be able to do this mod way cheaper, just PM me.
dibbage I'll just reply here to your PM it might help others: Auto-close module - the accessory JDM Subaru one is a bit of a mystery. I know how the aftermarket ones work as they will usually have a wiring diagram. Did you look in the door to see if there is a place for all those plugs to go hopefully it would match the JDM stuff if you are lucky! OEM Trim panel - this is a problem too as the door trim is specific to LHD you would need to find a country that has LHD and the folding mirrors on the Impreza/WRX and get the trim part from a dealer in that country. Typically Europe will be the source but not many parts sources in the LHD countries for Subarus there that can help. Its a bit of a challenge. |
#21 | ||
Member#: 368649
South East
![]() Quote:
I meant the mirror glass itself, not the housing. I know the housing has motors and whatnot that means you need the entire housing. I was questioning why you needed the JDM mirror glass. I know they'll be a wider angle but the USDM mirror glass should fit and work until someone chooses the swap to the JDM mirror glass, if at all, correct? |
#22 |
Member#: 368649
South East
![]() All of Europe is left hand drive. I'm sure some place like Germany has power-folding mirrors. Everything in Germany has power-folding mirrors.
#23 |
Member#: 409168
![]() Just to close the loop on this, DSOmegaX found the part number for the power folding switch door trim. It's: 94263VA170VH
I would love to get a LHD version of this with the cutout for the power folding mirror switch: https://www.japanparts.com/parts/detail/47926 |
#24 |
Member#: 388585
![]() For something that has absolutely nothing to do with smog regulations, I wonder why they just do not come standard...?
#25 | |
Member#: 183923
E. Canada
Vehicle:'08 EJ257 |
![]() Quote:
If not I can order it for you, just pay for the shipping/part. |
