#1 |
Member#: 202306
Vehicle:2000 STI TYPER COUPE BLUE |
![]() Hi guys,
Interested to see pics of your Fuel Swirl pot set ups and locations, especially on Classic Imprezas.. looking for some inspiration ![]()
#2 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Instagram | arthurlam89 |
![]() heres mine. GD chassis tho.
#3 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
![]() in the gas tank FTW!!
pics to be come shortly...or I'll just post up some solid modeling images friday ![]() |
#4 |
Member#: 109948
Vehicle:. Most famous car on Nasioc ever. :/ |
![]() ![]() He is mine un-finished. Do you want to buy it? I want to make one from scratch instead. haha It's brand new and I will powdercoat it any color you want, free. ![]() |
#5 |
Member#: 2532
South East
Vehicle:2001 2.5RS-T BRP |
![]() Mine is a bit different from others. Since my car is pretty much for street use with an occasional autocross thrown in I don't want junk hanging around in the trunk. I built mine to fit in the engine bay.
![]() ![]() The second fuel pump is under the frame rail and protected by the fender liner so it's pretty secure. Everyone always bags on my setup due to the engine heating the fuel a bit but it doesn't seem to make any difference. The fuel is constantly circulated between the surge tank and the main tank so it's not like the fuel is just sitting in the engine bay. |
#6 |
Member#: 202306
![]() GUMBY647, did you have to make tank your self?
Great pics guys, keep them coming :~) |
#7 |
Member#: 2532
South East
![]() Yes I made it myself.
#8 |
Member#: 9548
RMIC
Vehicle:2004 WRX STi 10.154 @139 @ 7,000'DA |
#9 |
Member#: 202306
![]() can the fire walls be bought for the rear set up?
#10 |
Member#: 109948
#11 |
Member#: 159315
South East
Vehicle:2009 Cadillac CTS-V |
![]() Gumby that under hood tank looks amazing. Any pics of it before/during the install? Any chance you would be willing to save me some effort and post up a how-to or dimensions of the tank?
#12 |
Member#: 33458
Vehicle:Your BOV sounds lame 93 RX7+09 Forester |
#13 |
Member#: 124282
NWIC
Vehicle:04 WRX Wagon PSM 13 STI Sedan SWP |
![]() Looks like a Canton Mecca.
#14 |
Member#: 134949
VIC
![]() Correct.
http://www.pegasusautoracing.com/pro...s.asp?RecID=95 I think it's a bit cheaper on racerpartswholesale.com |
#15 | |
Member#: 2532
South East
![]() Quote:
#16 | |
Member#: 33458
![]() Quote:
Awesome. Much cheaper than the Aeromotive ones, and it looks like it has a larger element as well. |
#17 |
Top Scoob 019
Member#: 43630
Vehicle:2004 GT40R-built 2.5 604 whp @1.8 BAR on VP109 |
#18 |
Member#: 189660
Vehicle:'02 WRX Element Tuning Race Team |
![]() ive been wondering, roughly about how much would a basic surge tank setup run?
#19 |
Member#: 33458
![]() "Complete" setups, sold as a package, often run up into the $1200 range. It can be done custom for MUCH less...
What I am doing/gathering: Aluminum tank, welded: $80 AN weld fittings: $5 (x4) Bosch 044: $189 Various fittings/hose: ~$150 Wiring kit: $30 Check Valve: $50 (http://www.jayracing.com/index.php?m...roducts_id=227) Add more money if you want to run AN line all the way to the engine bay. I plan to just use the stock hardlines, but take advantage of a surgetank as well as the headroom I need over a single walbro. EDIT: Need filters as well...forgot that. Last edited by CKxx; 03-31-2010 at 12:10 PM. |
#20 |
Member#: 167794
Vehicle:08 STI 6266 e85 DD 91 miata and 05 STI |
![]() I would be worried about a driver side wheel impact with the engine mounted one... that thing would shoot fuel everywhere.
otherwise cool setups. |
#21 |
Member#: 159315
South East
![]() Gumby, thanks for the extra pic. I should be able to figure something out with just that. When I pull the trigger on doing a surge tank I may have one made at a local shop that will fit where my stock washer tank is. Are you using a bosch 44 pump in your fender to feed from the tank to the rails?
#22 |
Member#: 33782
![]() ironic this thread is bumped as I hopped on here...I'm trying to finish my internal/drop in sump but my copy of Inventor just took a dump!!!
![]() I blame the computer. Time for a reinstall. |
#23 | |
Member#: 2532
South East
![]() Quote:
#24 |
Member#: 132978
Vehicle:2004 Mike angel tund efr 7670 1.05 Twiscroll |
![]() ![]() ![]() courtesy of kelly covertperformance... dood does amazing work |
#25 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, MPS 2.34 breaking in |
![]() Im not a fan of the engine mounted ones, subarus have too much crap in there as it is.
Surge Tank for use with Spec-C Tank based meth ket? | dexterous | Water/Methanol Injection, Nitrous & Intercooler Cooling | 1 | 06-25-2009 11:30 PM |
Sweet ass swirl pot / surge tank setup - bring kleenex! | wrxsti.l | Built Motor Discussion | 25 | 10-16-2008 03:26 AM |
WTB: Fuel Surge Tank a.k.a. Swirl Pot | StillBoostin | Private 'Wanted' Classifieds | 3 | 12-31-2007 12:27 PM |
Surge Tank/Surging Help!! | HEKTIC | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 03-15-2007 01:17 AM |
surge tank/swirl pot | lettucemanatee | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 23 | 10-16-2004 04:26 PM |
