#1 |
Member#: 159057
Vehicle:2004 ts wagon aspen white |
![]() *so yeah, diy GR front seats in a GD/GG body...it's really not too hard...cliff notes: use GR seat parts on GD/GG base...below are references for my diy...enjoy
![]() -GR seats into FXT (same procedure as my diy): http://www.subaruforester.org/vbulletin/f77/20GR-sti-seat-facts-info-install-05-fxt-53052/ -how to remove seats: http://www.iwsti.com/forums/how-inst...wap-seats.html and http://www.northursalia.com/modifica.../stiseats.html but first, some useful info - GR seats are not a direct bolt on because only the front 2 mounting points are perfect; one of the rear mounting points is close, but the other is about 2" off (see pics below) - so the only other feasible option is a custom seat rail ![]() ![]() ![]()
#2 |
Member#: 159057
![]() - passenger seat
cliff notes: use GR seats parts on GD/GG seat base and rails 1. remove all trim 2. disassemble GD seat back and bottom from GD base (remove 2 x 12mm bolts on each side) ![]() 3. disassemble GR seat back and bottom from GR base (unhook the seat bottom skin from under) ![]() 4. assemble GR bottom onto GD base, then assemble GR seat back 5. use GR trim (no pop clip required for front most part of trim) - driver seat cliff notes: use GR seat frame on GD rails, modification required 1. disassemble GD rails from GD base (3 x 12mm bolts and 1 gold torx-50 bolt), and disassemble GR rails from GR base (4 x 12mm bolts) * make sure you raise your seat to the highest position; top bolt in front, bottom bolt in rear ![]() ![]() 2. modify rear outside bolt on GR frame (where the gold torx-50 bolt goes on the GD rails) * use a dremel to cut welds and remove bolt - this allows the gold torx-50 bolt to connect the GR frame to GD rails ![]() 3. use a rubber mallet to make the necessary adjustments to fit all mounting points (about 1/4" too narrow) Last edited by antho!; 04-20-2010 at 11:22 AM. |
#3 |
Member#: 159057
![]() ![]() Last edited by antho!; 04-20-2010 at 11:14 AM. |
#4 |
Member#: 159057
![]() final pics
#5 |
Member#: 213288
Vehicle:2007 SWP VF39 WRX Sti Mikey Tuned |
![]() those are some nice looking seats... hrrrmmm
#6 |
Member#: 86459
Vehicle:2013 BRZ SWP |
![]() i almost bought a set of these before my evo X's. looks good. thats the rear seat in there, they fit? (obv for a wagon like yours lol) kinda looks odd without the headrests... but nice job man.
#7 |
Member#: 103068
SCIC
Vehicle:11 STI sedan SWP |
![]() The rears bolt right in?? Where in SoCal are you? I'd like to check this out if I could.
#8 |
Member#: 239620
Vehicle:2003 WRX Wagon Aspen White |
![]() meh, they're alright.
but props for the diy skills! wagonswagonswagons! ![]() |
#9 |
Member#: 136358
NESIC
Vehicle:2006 WRX Limited 6mt/5x114/vf43/S204 |
#10 | |||
Member#: 159057
![]() Quote:
located in garden grove...sent you a pm |
#11 |
Member#: 147065
![]() ooh, let us know about the rears, if it is easy enough, I want some blue sti rear seats =O
anyone know about GD carpet fitting in GR? |
#12 |
Member#: 171611
BAIC
Vehicle:2014 FiST Blk |
![]() what'd you do about the passenger seat passenger detection system module?
#13 |
Member#: 214331
Vehicle:99 BMW M3 FOR SALE |
![]() thats sick id love to do this!!
#14 | |
Member#: 159057
![]() sorry everyone - i got super lazy on writing about the rears, but i'm also not 100% happy with them. here's the basics of what i did:
- rewrapped the seat backs with the GR seat foam and skin - used the GR seat bottom (not 100% happy with) - fabricated front mounting hooks - modified rear mounting hook - added foam underneath so i'm gonna figure out a way to redo them and keep everyone updated...16 days left in iraq ![]() Quote:
#15 |
Member#: 231774
![]() wow that a nice guide. thanks..
#16 |
Member#: 36842
Vehicle:2008 2007 Exige S AW, Black |
![]() Question, do you think this would work going the other way? So taking a seat out of the GD and making it fit the GR? I am thinking of undertaking a project like this for my 08 STI with 02/03 WRX seats rewrapped.
#17 |
Member#: 185716
SCIC
Vehicle:2008 Outback Black |
![]() anyone know if this would work out for a GF body (2000 imp wagon)?
or really... are all impreza front seats interchangeable would be a better question. since we can see pretty much the bugeye and newer is.. |
#18 |
Member#: 171611
BAIC
#19 |
Member#: 36842
![]() haha Not happening
![]() ![]() Good try though ![]() |
#20 |
Member#: 197108
Vehicle:2003 Ford Mustang GT White |
![]() nice guide
#21 | |
Member#: 159057
![]() Quote:
![]() so i would think that you would just do the reverse of what i did - GR rails on GD seat. the only issue that i see is on the driver side, where gold torx bolt is on the GD seat - you might have to modify the GR rail to allow the gold torx bolt to fit. that's my best guess |
#22 |
Member#: 159057
![]() p.s. rear seat redux coming soon
#23 |
Member#: 159983
![]() I can't wait for progress on the rear
#24 |
Member#: 4149
SCIC
Vehicle:MY93 Impreza 6MT GC8.6 Aspen White |
![]() Nice post, thanks for sharing.
#25 |
Member#: 44695
NESIC
Vehicle:2005 WRX Red |
![]() Nice work, how long did the job take to do?
FS clear jdm fogs, enduratech front strut tower bar, GR front seat rails | antho! | SCIC Private Classifieds | 16 | 04-21-2010 07:40 PM |
GC rear seats in a GD? | erich | Interior & Exterior Modification | 6 | 06-11-2009 06:44 PM |
It is possible? | stilover | Texas Impreza Club Forum -- TXIC | 3 | 07-31-2004 10:30 PM |
Is it possible to switch front seats left <-> right ? | il96 | Interior & Exterior Modification | 5 | 01-22-2003 12:46 PM |
just fyi, it IS possible to have traction problems, even with AWD and Azenis tires | jmott | Texas Impreza Club Forum -- TXIC | 13 | 03-27-2002 08:14 PM |
