#2001 |
Member#: 176134
SCIC
Vehicle:1995 Coupe, Sedan & Wagon! |
#2002 | |
Member#: 152036
E. Canada
Vehicle:2004 Sti PSM |
![]() Quote:
![]() I know that thread read most of it I'm currantly looking for a dry ice blaster to rent to remove all the tar from below the car So how's that for hard core weight reduction [ZINGER] lol ![]() ![]() |
#2003 |
Member#: 79643
NESIC
Vehicle:2021 STI TE Terminal black pearl |
![]() If I removed all the tar from under my car it would rust away in 2 months.
#2004 |
Member#: 346388
Vehicle:2001 Ej205 Impreza L SRP |
![]() ^^ I'd give mine less than that. It would probably show surface rust instantly.
![]() I'm hoping he means the sound deadening.... |
#2005 |
Member#: 152036
E. Canada
![]() Nope the tar from the factory
I don't drive my car in the rain nor the winter month so Once removed can always just paint it instead of having that tar crap |
#2006 |
Member#: 174294
NWIC
Vehicle:02 WRX , 2013 FXT VF30 Stage 8 billion |
![]() I finally had some time to work on my car so I picked the big items to remove / change . Starting weight was 3344 with a little under a half of a tank and some coats and work junk in the car.
![]() So my plan was to put coilovers on , different rims , my Spec-C trunk , remove the light bar, remove the U-brace, lighter battery, clean the junk out of the inside, and I already have removed the front bumper ( the 2002 weight is 30#'s because it has extra protection for the fog lights. ![]() ![]() ![]() ![]() ![]() ![]() ![]() In all it was 141.4 pounds lost , and it is noticed just daily driving it. I can't wait to do more. Last edited by DamnThatRevLimiter; 07-25-2015 at 05:56 AM. |
#2007 |
Member#: 106510
VIC
Vehicle:98 Widebody 3.4L Smooth Safety Blue |
![]() Nice work!
#2008 |
Member#: 176134
SCIC
![]() ^ I just realized you are the same gent from rs25
![]() cheers |
#2009 |
Member#: 106510
VIC
#2010 |
Member#: 174294
NWIC
![]() Has anyone removed their headliners and plastic trim on the interior ? My question is what is the purpose of the metal plates under all the plastic that is just bolted on and all the under plastic stuff ? Sorry I don't even know what those parts are called . Has anyone removed them and recorded the weight of them ?
#2011 | |
Member#: 106510
VIC
![]() Quote:
#2012 |
Member#: 174294
NWIC
![]() That could be those , I just want to find out the weight of them and has anyone removed them
#2013 |
Member#: 22605
Vehicle:2002 JDM STI/WRX WRB |
![]() Anyone know the weight difference of the STi vs WRX rear windshield? I've been searching all over and have yet to find numbers other than "it's lighter".
#2014 |
Member#: 174294
NWIC
![]() I wonder if you went to the dealership and talked with the parts folks they could look up part numbers and might even have the shipping weights
#2015 |
Member#: 158864
Vehicle:2003 SOHC destroker |
![]() People really, REALLY underestimate weight reduction. Its performance I mean.
#2016 |
Member#: 176134
SCIC
![]() Free usually... sometimes.
#2017 |
Member#: 158864
![]() necropost i know, but here's how much stuff can just be REMOVED, not replaced with lighter components, just REMOVED from the car without any real effect on practicality at all:
#2018 |
Member#: 106510
VIC
![]() Reweiged my car with its new powerplant, 2880lbs with me onboard and full of all fluids. I weigh about 185lbs.
So I'm calling it a nice even 2700lbs. Not bad for a 6 cylinder turbo 6 speed car I think! |
#2019 |
Member#: 147972
Vehicle:2004 wrx hybrid 18g [email protected] dd |
![]() ^what kind of power will you be pushing??
#2020 |
Member#: 106510
VIC
![]() Right now Im just running a 20G so max is about 450hp/500ft-lbs torque
I've got a GT4094R waiting to go on, but I need to do a ton of supporting mods first. Probably will go on Winter 2016. That should net me a comfortable 700hp. Last edited by Splinter; 10-04-2015 at 03:47 PM. |
#2021 |
Member#: 147972
![]() That will be a mega beast. My problem is the poor wrx R160 rear slipping and breaking with almost 400 wheel torque
#2022 |
Member#: 328635
NWIC
Vehicle:2004 STi GTX3076R Rally Blue |
![]() Has anyone used the Summit racing duel vent heater part #SUM991102-1? Been looking at it to replace the stock unit. I know its around 7lbs and from my best guess the OEM unit is far from light.
Any input would be very helpful. - Thank you |
#2023 |
Member#: 97135
NWIC
#2024 |
Member#: 174294
NWIC
![]() Probably I got it from a guy on here , I had it on and took it off for the weight reduction, but I am going to run it for winter. I just wish it was aluminum.
Update on my car I picked up some gram lights 57F 5 spoke really light wheel + tire I am around 39/40 lbs . Total car weight is 2840 with a half tank no driver. I am in the process of doing sound deadening removal. Just curious has anyone with a lightweight GD done a 0-60 or 1/4 mile time ? Or if your car is close to my weight, my hp is 300 to the wheels. I kinda feel like I have more lag now with less weight, it doesn't feel slower just that it is not using the turbo the same way. It's only a butt dyno feeling. |
#2025 |
Member#: 174294
NWIC
Total weight reduction or F/R weight distribution more valuable? | soslow | General Community | 17 | 12-11-2007 12:40 AM |
('93-'01) Weight Reduction Questions | subarumantoo | Impreza Forum | 5 | 05-01-2001 11:02 AM |
Some interesting facts about weight reduction | Imprezer | WRX Forum Archive | 5 | 02-25-2001 10:33 PM |
2.5RS Weight Reduction info and questions. | Frank | General Forum Archive | 21 | 02-16-2001 12:53 AM |
