Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Old 02-07-2007, 08:34 PM   #1
ldivinag
Member#: 13533
04 sti
black???
Default 04 STi: cluster gauge is dead... fuses?
while trying to clean the dust off the face of the cluster gauge, while engine was running, the cluster gauge suddenly dies.
all the idiot lights, though, work. ditto indicator lights like the HEADLIGHT, DCCD select, cruise control, etc.
speedo, tach, gas gauge, temp gauge, odo and outside temp is out, like when engine isnt running.
also, HVAC control lights are out.
clock is okay. light to radio is okay.
so i think it's a simple fuse. pull out the coin tray with the fuse panel markings.
#12 says ILLUMI and #13 says CLUSTER, IIRC.
so i replace them. nothing.
i buy one of those fuse checker thingees that light up. nothing.
i swap out numerous fuses on #12 and 13. still nothing.
everything else in the car works. headlights, HVAC, radio, cruise control.... everything except the guage cluster.
i check the main fuse panel under the hood too. that one checks okay.
am i missing something else?
thanks...
ldivinag is offline   Reply With Quote
Old 02-07-2007, 08:40 PM   #2
bergs
Member#: 124376
the plug behind the cluster in unplugged?
I assume the cluster was removed from the dash?
bergs is offline   Reply With Quote
Old 02-07-2007, 11:12 PM   #3
ldivinag
Member#: 13533
04 sti
black???
no.
i just started the car.
while listening to radio, i decided to wipe off the cluster guage with a micro fiber cloth.
i wiped down the face. then BOOM. everything goes dead.
nothing was unplugged or removed.
Old 02-09-2007, 01:41 PM   #4
STIStalker
Member#: 92783
2004 WRX
I think you should just sell to me and that will get rid of your headache.
STIStalker is offline   Reply With Quote
Old 02-11-2007, 01:25 PM   #5
mattxander12
Member#: 111067
2002 Old and
busted.
maybe your forceful polishing cause the cluster to unplug
mattxander12 is offline   Reply With Quote
Old 06-20-2007, 01:39 AM   #6
Nicky B.
Member#: 148261
2007 Scoopless
Bump. I have a brand new 2.5i and the same exact thing happened to me, but I wasn't dusting.
Nicky B. is offline   Reply With Quote
Old 06-20-2007, 01:46 AM   #7
ldivinag
Member#: 13533
04 sti
black???
you what happened?
stupid connector just came apart.
apparently, sometimes, they forget to tighten them or make sure the connectors SNAP together.
so pissed over this...
Old 06-20-2007, 02:18 AM   #8
Nicky B.
Member#: 148261
2007 Scoopless
ok so you took out the cluster, and snaped it together and it was good?
Old 06-20-2007, 02:19 PM   #9
ldivinag
Member#: 13533
04 sti
black???
well the dealership who charged me (i thought i was still under warranty... sheesh...) did just that.
sigh.
Old 11-22-2020, 01:41 AM   #10
cmobley92
Member#: 198824
2007 Forester
Default Dead Gauge Cluster on 2007 Forester
I'm having the same issue on my 07 forester after jumping it, is there a fuse I can check or something?
cmobley92 is offline   Reply With Quote
Old 12-03-2020, 09:46 PM   #11
Apex2000Rs
Member#: 399419
A little dab of Hot Glue on the connector-to-tab connection should prevent the issue from happening again. If you find that this was your problem, go the extra mile and add this cheap insurance.
1. Sandpaper/emerycloth/lightly file the plastic surfaces. For circuit board just skip to #2.
2. Iso alcohol to prep surfaces.
3. A little hot glue. Keep an eye on the glue for the first minute to be sure it flows where you want it.
Apex2000Rs is offline   Reply With Quote
Old 12-04-2020, 02:33 PM   #12
cmobley92
Member#: 198824
2007 Forester
Thanks, I pulled the cluster. After unplugging and re-plugging the harnesses it just worked! I may have to follow up on the insurance policy and maybe some deoxit if it dies again, I saw your response after I pulled it
WTB: 04 WRX Gauge Cluster cheaper is better Wrx_Fan_0717 MAIC Private Classifieds 2 06-22-2013 02:26 AM
WTT: 05 STI gauge cluster for 04 WRX cluster nixgame22 Interior/Dressup/Audio & Security 28 08-15-2007 03:49 AM
Identify this cluster gauge! 04 or 05 sti cluster?!?!**PICS** renda85 Electrical & Lighting 4 01-10-2006 04:26 PM
04 STi: this clunking is driving me crazy essogas Brakes, Steering & Suspension 11 06-24-2005 08:06 PM
Fuel/Gas Gauge is Dead! yeravgjoe Electrical & Lighting 2 04-09-2004 12:16 PM
