Welcome to the North American Subaru Impreza Owners Club Sunday April 18, 2021
Old 02-21-2021, 11:13 PM   #1
spiralsmurf
Member#: 16085
2005 STi
Default Ej207 into GD sti
Does it make more sense to buy a v10 ej207 and disable the exhaust avcs or get a v8/9 ej207 and swap the cams/sensors plus convert to DBW. The price of v10 motors is not that much more than v8/9 and with added labor it seems like a wash.
spiralsmurf is offline   Reply With Quote
Old 02-22-2021, 09:59 AM   #2
snow_bound26
Member#: 395793
2005 92x Aero
Beige
There are several things that will need to be addressed to make this work in an STi. For instance, cam position sensors and pick up points are different. JDM cams have up to 40* of advance. USDM have 30*.
Converting to DBW is simple since your car already has the wiring and sensors for it. Just swap the corresponding parts/wiring to the new engine. Probably better to do this than delete the ex AVCS. You could always plug the oil feed into the ex cam on the v10 and retain the cam designed to work at high rpm. The v10 does have thicker cyl walls than the other versions. But either way you're still stuck with altering the cam sensors and their location to work with the ECU. It would be easier to get another 2.5 long block or rebuild what you have. There's reasons why people generally don't swap 207s into cars newer than 2004/2005 (depending on which model).
snow_bound26 is offline   Reply With Quote
Old 02-22-2021, 10:35 AM   #3
spiralsmurf
Member#: 16085
2005 STi
Thanks for your response. Isnít the ďv10Ē already DBW and has the correct cam position sensors so all thatís needed is to lock the exhaust avcs and remove the air pump setup?
Old 02-22-2021, 12:37 PM   #4
motorbykemike
Member#: 273868
Absolutely v10 for the reasons you stated
I would replace the exhaust cams with non avcs
Pre makes a exhaust avcs solenoid delete kit of just abandon them in place if they donít get fouled on your header
Use your existing engine wiring harness , coils , and intake manifold
Been there , done that
motorbykemike is offline   Reply With Quote
Old 02-22-2021, 12:44 PM   #5
spiralsmurf
Member#: 16085
2005 STi
Thanks for the confirmation. Did you mean IA performance has the avcs delete?
Iím also considering to run a haltech or aem standalone with harness and just the stock ecu for smog as needed. That way I can run the dual avcs still. Bit more cash and not legal but itís gonna work 100%.
Old 02-22-2021, 02:15 PM   #6
motorbykemike
Member#: 273868
Not the ia kit
Thatís totally different
Change the exhaust cams ,gears and cam seals to non avcs
Pavels racing engines , you completely remove the exhaust avcs components from the bottom of the heads and the kit is plates with proper oil passageways and hardware
Still need to swap the cams to keep proper valve timing events
Just blockingís the oil holes to the gears is not the way I do it because avcs and non avcs cams have different timing
Old 02-22-2021, 02:23 PM   #7
motorbykemike
Member#: 273868
If you are worried about Cali smog and need to use the oem tune the v10 , modded like above or not is not the right engine for you as it will run like total ass on the usdm 2.5 tune . It will run , but it will knock and have a funky power delivery , if youíre using and ap you could build a proper tune and go back to stock for smog
Otherwise if you need to use the stock tune just put a new 2.5 in it
Old 02-22-2021, 02:26 PM   #8
spiralsmurf
Member#: 16085
2005 STi
I will definitely have the stock ECU tunes properly to run the ej207 for smog. Not planning to cut any corners. Iím not worried about the smog
Iíd just rather spend money doing it right and swap ecus than look for hot smogs. Especially since they donít even sniffer.
Old 02-24-2021, 09:54 AM   #9
subaru_gc8
Member#: 29292
2004 WRX wagon
uhh so now it they are looking for differences in the tuning and setting on your ecu for our smog program. Ie loking for tunes and you will need one on your stock udsm ecu if you plan to use it for smog here in california
Old 03-02-2021, 08:21 AM   #10
wooshwoosh
Member#: 514853
2005 GDB-E
@spiralsmurf
Does your 05 STi have secondary air injection, and is it DBW?
I have an 05 STi, AUS DM - these came with an EJ207 with single AVCS on the intake cam, no TGV's, no secondary air injection nonsense, a mechanical throttle body and a single scroll IHI VF35 turbine.
For me, swapping to a v10 is not an easy plug in swap due to the dual AVCS and compability issues with the factory v7/8 ECU / aftermarket ECU requirements. If swapping to a JDM v10 ECU, I'd have to swap over all the locks and immobilizer as the ECU, key and immobilizer are all paired together.
Blanking the AVCS oil ports out doesn't seem like a trivial task and the cam sensors are likely to be offset on the ver10 heads. I'm not even sure if my v8 intake manifolds would bolt up to the v10 block.
On a side note, I'm currently dealing with a cracked cylinder head and a knocking motor. Trying find compatible 2L cylinder heads for v8 EJ207 block is a nightmare. Everything 06' and up has secondary air injeclion, or is a 2.5L head with different head volume CC's and head dome profiles (the V-Shaped pentroof design is needed). I know of a guy with another 05' STi who eventually managed to get 2.5L EJ257 heads working on his EJ207 block, but not after messing with cam sensor positioning and went aftermarket with his ECU. I'm not sure if he lost DCCD, or had it impaired due to the aftermarket ECU.
wooshwoosh is offline   Reply With Quote
Old 03-02-2021, 08:58 AM   #11
spiralsmurf
Member#: 16085
2005 STi
Iíve not heard of any test stations doing this.
Old 03-02-2021, 09:02 AM   #12
spiralsmurf
Member#: 16085
2005 STi
Originally Posted by wooshwoosh View Post
@spiralsmurf
Sounds like you need to import a motor from Japan and sell off the short block. Different story than us in the US. But ya I'm trying to avoid opening the heads and replacing cams on either a v7-9 or v10 motor.
I found a device that converts the signal from a 2 wire cam sensor to 3 wire and I'm thinking I may just do that for emissions testing and run a stand-alone ecu the rest of the time.
