#1 |
Member#: 176284
Vehicle:2017 WRX Premium Blue |
![]() Anyone know of any molded mud flap that would go with the 2017 WRX?
Only lead Ican find is these: https://www.shopsar.com/subaru-wrx-splash-mud-guards-p/pf-09wrx-11.htm Just hoping more options or if anyone can confirm what number of these would be. Looks like #3 might be for the car? Also would any other car's flap like forester or anything else fit?
#2 | |
Member#: 507317
Vehicle:2019 WRX Pure Red |
![]() Quote:
Also, if you want something that is closer to or flush with the body, the Rokblokz (RB) are thick plastic and IF you want to, you can trim the outer edge to bring the guard closer to the body. You could probably take an inch off the outer edge and be really close to flush. The RB guards also have a 1/8" - 1/4" (0.125" - 0.25") of lateral adjustment. If you go with the RB, and they stick down too far, well, they are plastic and you can cut/trim the to a height you want to prevent rubbing on driveway entrances. My (standard) rears rub driveways at stock height on my '19. I could probably cut a 1/4" inch off the bottom of both the front and rear to alleviate the scraping. in the end, they are plastic and its just a bit of noise for only a second or two. |
#3 |
Member#: 499784
Vehicle:2017 WRX Crystal White Pearl |
![]() I just picked up ZL1 Addon Rock guards because I wanted a more subtle look. They are also functional and have worked well with my wider wheels/tires
