Welcome to the North American Subaru Impreza Owners Club Thursday April 15, 2021
Old 02-03-2021, 02:25 PM   #1
kgozi
Member#: 489048
Post Need assistance, do I need AC PAG oil?
Currently swapped a complete EJ207 into my STI.
I was recently informed I should add the "AC Oil" to the compressor in case it is dry.
Is there any way to check the oil level inside the compressor before looking into what and how much to add?
kgozi is offline   Reply With Quote
Old 02-03-2021, 09:21 PM   #2
MafiaFrost
Member#: 522135
2017 WRX STI
Is the compressor brand new, or was it moved with the swap? Do you already have the ac system charged up? If not you could do your best to pour out any oil that is already in the compressor and then fill it to the manufactures recommendation. When I changed the ac compressor on my old car I filled it with about 7oz of oil, though the compressor was shipped with no oil in it.
MafiaFrost is offline   Reply With Quote
Old 02-04-2021, 09:17 AM   #3
kgozi
Member#: 489048
The engine was imported assembled, the ac compressor hasn't been removed, so is it basically a gamble? Better off removing it and making sure its empty before filling up I guess
Old 02-17-2021, 06:22 PM   #4
SuBBIEBrad82
Member#: 522452
2016 WRX Prem
I would definitely remove and refill
SuBBIEBrad82 is offline   Reply With Quote
Old 02-18-2021, 12:31 PM   #5
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Assuming you can't just re-use your old compressor (different mounting?), you can drain and measure the oil from it, then drain the oil from the "new" one and add back the measured amount from the old one with new oil.
And then hope that compressor is good after sitting around.
