Welcome to the North American Subaru Impreza Owners Club Sunday April 11, 2021
Old 02-05-2021, 03:24 AM   #1
defury
Member#: 428480
2003 Jdm Forester
Default Warming up an old EJ before driving in sub Zero Temp?
I don't have a block heater but the car never fails to start. I'm getting one put in eventually but in the meantime I was curious.
On an older EJ205 (JDM 03 Forester) with piston slap in cold weather am I better off letting it idle for a few minutes? I know a lot of the discussions say just drive but those don't usually discuss old engines with 17 years of wear and tear.
The vehicle has 115,000km, I run Motul Xcess 5w40.
Should I be letting it idle? We often get down to -20/-30 here.
defury is offline   Reply With Quote
Old 02-05-2021, 07:14 AM   #2
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Midnight Black Pearl
I always let my car idle to at least a hundred degrees on the coolant before I drive it.
While it's true that tolerances in engines are a lot tighter than they used to be and warming up cars is a lot less important than in the past, especially in colder temperatures, it's still definitely makes sense to warm up your car, especially if it's not stock.
K3rm1tth3fr0g is offline   Reply With Quote
Old 02-05-2021, 07:25 AM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Idling is fine if you want to do it. I'd say give it 2 minutes for the sake of the car and up to 10 minute for the sake of your heater working and you entering a toasty car.
Old 02-05-2021, 07:33 AM   #4
rtv900
Member#: 428511
2016 STI
If I was in -20 weather I'd probably let it idle for a few minutes at least, but in reality I'd put a block heater in considering how cheap and easy they are and how great they work.
rtv900 is offline   Reply With Quote
Old 02-05-2021, 07:43 AM   #5
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Letting the car idle allows time for the oil to warm before any kind of load is put on the engine. If you don't think it's necessary (or anyone else) take some of that ultra thin Honda 0w-20 and put in your freezer and see what happens to it. We use thicker oil, then imagine what it would be like after 1500, 2000, or 3000 miles of use. If you don't want to let it idle, get a block heater. As mentioned, they are cheap
snow_bound26 is offline   Reply With Quote
Old 02-05-2021, 09:27 AM   #6
rtv900
Member#: 428511
2016 STI
letting a car idle until the oil warms is downright unrealistic, period.
the oil won't budge past it's minimum temp reading on any gauge until the coolant is fully warmed up.
So what, we're supposed to idle for a half hour?????
Yes everyone knows oil is thicker in a freezer, or in your garage for that matter.
Cars can handle that easily, that's why people who don't do the endless idle warm up have no problems.
I ran 10w30 in my last car and drove off with no warm up in single digit weather regularly. Engine ran perfectly to 280,000 miles.
My sti is at 123,000 and I do the same thing, same results.
Most diesel guys run a 15 cold weight and start up and go.
Negative 20 or 30, that's time to just use a block heater. Idling to warm up in those temps is most likely doing more harm than good because nothing is moving.
Old 02-11-2021, 05:45 PM   #7
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
I try to let coolant get up to atleast 100f any time I drive it, no matter how hot or cold it is outside
4eat05 is offline   Reply With Quote
Old 02-11-2021, 05:51 PM   #8
JP Chestnut
Member#: 504432
Block heaters exist for a reason. They're not hard to install.
JP Chestnut is offline   Reply With Quote
Old 02-15-2021, 02:32 PM   #9
mitchfishman5
Member#: 510946
2004 WRX
World Rally Blue
Even in the summer I let my cars warm up before driving them...
mitchfishman5 is offline   Reply With Quote
Old 02-15-2021, 02:43 PM   #10
rtv900
Member#: 428511
2016 STI
Facepalm!
Old 02-16-2021, 01:53 PM   #11
samb
Member#: 177235
2016 Focus RS
2002 WRX Wagon
Temps in the -20f to -30f range I always let the car warm up for a few minutes before driving. Usually I couldn't get it in gear anyway. Once my breath wasn't freezing to the windshield I was good to go. 239,000 miles and she still runs fine.
samb is offline   Reply With Quote
Old 02-16-2021, 02:05 PM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I like a block heater a lot. Highly recommend.
After a R-E-A-L-L-Y cold night (teens) the coolant temp will be mid 70s at startup. On a 30 night it will be in the 90s at startup. Either way, you can put the heat on immediately and get lukewarm heat out, and HOT air our within a couple minutes of driving.
KillerBMotorsport is offline   Reply With Quote
Old 02-16-2021, 02:12 PM   #13
Markopolo400
Member#: 452996
Sorry KillerB, teens are not cold lol. -22f air temp in MN this morning.
Markopolo400 is offline   Reply With Quote
Old 02-16-2021, 02:23 PM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
You're right. From NH, so I should have known better. Spoiled being in VA now. Either way, you're looking at a +50 temp rise with the block heater. Gets you at a much better temp to start with.
We did have a customer long ago that had us make a custom oil pan that could use a Caterpillar Engine Oil Heater. He lived on the Hudson Bay. He used that WITH an OEM block heater. His startup oil temps were ~100 IIRC.
Old 02-16-2021, 04:04 PM   #15
SoCoNoHa
Member#: 478524
1995 EZ30 Coupe
Green
I'll weigh in, since it gets pretty cold on some NH nights...
I always wait to drive until the coolant needle is at least a little above the cold line on the gauge, and I absolutely never drive hard until it's well warned up. Just because the coolant gauge has reached normal operating temp, doesn't mean the oil is all warned up yet.
I've put many many tens of thousands of miles on motors with bad head gaskets/ slapping pistons/ excessive blow by without issue, I believe letting them get to temp on their own extends longevity in these cases.
SoCoNoHa is offline   Reply With Quote
