Welcome to the North American Subaru Impreza Owners Club Sunday April 11, 2021
Old 02-08-2021, 04:17 PM   #1
kgozi
Member#: 489048
Post Extra engine harness connectors, USDM harness on JDM EJ207
I have some extra connectors that won't be used, from memory I know one of them is TGV's, but I'm not sure which will just stay hanging or will I need to insert a wire and tape it off.
Any advice is appreciated.
kgozi is offline   Reply With Quote
Old 02-08-2021, 06:08 PM   #2
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Can't give much info without knowing which 207 you have. Those don't look like what is on my 207 for instance
snow_bound26 is offline   Reply With Quote
Old 02-08-2021, 07:28 PM   #3
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Looks like op is using a USDM harness, ej207 and no functional AVCS, sad.
D-Rodman is offline   Reply With Quote
Old 02-08-2021, 10:44 PM   #4
kgozi
Member#: 489048
Nope, I have full functional AVC's its plugged in already. I did swap some connectors like top feed from my old jdm harness and avcs as the connector style is different.
Full avcs with custom cams matched to 207 profile & USDM cam pickups
https://rogerclarkmotorsport.co.uk/s...kit-v9-sti-dbw
Old 02-08-2021, 10:49 PM   #5
kgozi
Member#: 489048
06 USDM harness on version 8 207
Old 02-08-2021, 10:57 PM   #6
MortonCharbo
Member#: 487057
2002 WRX Wagon
These are my guesses, not guaranteed to be correct.
Blue is avcs
Cover it if you'd like. No need to do anything else if you don't have AVCS (what a tragedy)
Well it's not AVCS, so maybe it's for the secondary air pump?
Black w/white clip is for MAP possibly
Again, cover it if you'd like
Black/Orange is for EGT sensor.
If it is the EGT sensor, either put a resistor across the pins, or delete the DTC.
Again, these are just my guesses. Do some more research to verify this before trusting these answers.
MortonCharbo is offline   Reply With Quote
Old 02-08-2021, 11:02 PM   #7
kgozi
Member#: 489048
Blue is avcs
Thanks, that blue does look like AVCS but its not I have it hooked up already, there's an extra profile/line on the back side of the connector for the AVCS connector.
Ill get a resistor for that EGT.
Ive just realized this harness has a bit of a 'Frankenstein' with the connectors I need to sort out. just not sure if i just leave the TGV's dangling or not
Old 02-08-2021, 11:50 PM   #8
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Default Extra engine harness connectors, USDM harness on JDM EJ207
Have you started the motor ?
Do you know for a fact your AVCS is functioning?
Why use a USDM harness?
Is your car an 06 ?
16 or 32bit ecu ?
