Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Old 02-27-2021, 01:49 AM   #1
Trainz
Member#: 522570
2005 STI
Default Misfire
I just installed a new turbo and replaced the spark plugs. I noticed that the coil pack nearest to the turbo, right below, had its connector clip broken. The connector still went into the coil pack but could be easily pulled out. I now have a misfire. Could it be the connector? Should I replace coil packs?
Trainz is offline   Reply With Quote
Old 02-27-2021, 07:01 AM   #2
Gucciflipflops
Member#: 521349
2005 STI
Is the misfire on that cylinder? If so, yes you should replace.
Gucciflipflops is offline   Reply With Quote
Old 02-27-2021, 06:59 PM   #3
Trainz
Member#: 522570
2005 STI
Its on the turbo side of the car, however, when i pop the hood and listen closer, it sounds like its the turbo, but symptoms of a misfire.
