Welcome to the North American Subaru Impreza Owners Club Sunday April 11, 2021
Old 02-27-2021, 09:42 AM   #1
je03672
Member#: 522375
Default JDM EJ205 TPS sensor
Hi,
So I ordered a used EJ205 with AVCS from JDMRacingMotors and I also ordered the JDM ECU and engine harness with it. My throttle body would not bolt onto the JDM intake so I swapped the upper intake manifold from my old engine onto this one.
The problem iím having is I do not have any connectors on the JDM engine harness that will match my TPMS, IAC, and the other sensor on the throttle body. Do any of you know the pin out for this 6 wire connector? I assume I should be able to repin it so that it will work. Or do you have any other ideas?
Pictures-
https://postimg.cc/gallery/F9Z9nJV
je03672 is offline   Reply With Quote
Old 02-27-2021, 10:29 AM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
subaru_gc8 is offline   Reply With Quote
Old 02-27-2021, 10:36 AM   #3
je03672
Member#: 522375
Originally Posted by subaru_gc8 View Post
Heís closed on weekends. I was hoping to have some help right now.
Old 02-27-2021, 03:58 PM   #4
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Why were you swapping throttle bodies in the first place? What car is this going into? This can make a difference. When doing swaps into 02-05 WRXs, I haven't had to change any intake parts just to be able to plug sensors or any electrical in. Makes me think you have an N/A car you're swapping this into.
snow_bound26 is offline   Reply With Quote
Old 02-27-2021, 04:02 PM   #5
je03672
Member#: 522375
Originally Posted by snow_bound26 View Post
Why were you swapping throttle bodies? I've done a couple JDM swaps and never had to do this. Everything just plugged right in.
This engine did not come with a throttle body unfortunately. The seller told me I would have to swap my upper manifold and throttle body onto this engine. It was supposed to be plug and play but you know how that goes...
I repinned the wires for the TPS but iím still in the dark on the IAC and pressure sensor. Apparently the forester used a 6 wire plunger style IAC and no pressure sensor so iím trying to figure out if I can make this work or if I need to buy a throttle body for a forester and see if that will work.
Idk iím kinda stuck at the moment.
Old 02-27-2021, 06:40 PM   #6
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
I think you need to keep your intake manifold ant throttle body. You would then need a jdm ej205 throttle by cable engine harness.
I have a complete JDM intake manifold with the correct harness.
It came off the last jdm ej205 motor I purchased last year.
I installed a complete jdm STi intake manifold on my motor for the factory oem TGV delete and because some of the wires on the jdm manifold were in poor condition.
Iíd be willing to sell you the harness, it is in working condition, I used it on my car almost 2 months without any problems. You will definitely want to inspect it and replace a couple of wires, I just wrapped them on electrical tape to drive the car while looking for TGV deletes. A complete manifold came along so I put the ej205 intake manifold on the side as spare.
IA tuning sells the harness new, itís expensive.
https://iatuning.com/products/jdm-su...wiring-harness
You could by my harness for $100 shipped.
Pm me if interested.
D-Rodman is offline   Reply With Quote
Old 02-27-2021, 06:45 PM   #7
je03672
Member#: 522375
I appreciate the thought but I have the JDM engine harness which is why I have a problem. I swapped my USDM STI manifold and throttle body onto the JDM EJ205. The JDM harness connector for IAC and TPS does not match up to my USDM harness. The pressure sensor also is not included in the JDM harness.
Old 02-27-2021, 06:47 PM   #8
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Originally Posted by je03672 View Post
I appreciate the thought but I have the JDM engine harness also which is why I have a problem. The JDM harness connector for IAC and TPS does not match up to my USDM harness. The pressure sensor also is not included in the JDM harness.
You have a harness for a drive by wire application, you need a throttle by cable harness.
Old 02-27-2021, 06:48 PM   #9
je03672
Member#: 522375
Hmm, I thought JDM was throttle by cable? I have that harness installed right now. It has AVCS and TGV delete.
Old 02-27-2021, 06:50 PM   #10
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
You have a jdm ej205 avcs motor off a forester probably, the had a drive by wire throttle body. You need a drive by cable harness.
Throttle by wire
Throttle by cable
Old 02-27-2021, 06:51 PM   #11
je03672
Member#: 522375
Gotcha ok, yeah pretty sure it came off a forester because they used the 6 wire plunger style IAC...
I was able to repin the TPS but still not sure about the IAC. I think I might just pick up a used forester TB with sensors and swap it out
Old 02-27-2021, 06:54 PM   #12
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
You need to make sure whatever route you choose is compatible with the ecu and wiring.
Google search the ecu part number.
If you plan on using the usdm ecu for some reason you canít run a throttle by wire setup. If you are only going to run on a jdm ecu then you need to find out what your ecu is for. 16 bit throttle by cable or 32 bit throttle by wire.
Your car is wired for 16 bit ecu, implementation of 32 bit is complicated.
You might be able to use the jdm harness if you can repin and get the correct plugs.
