Welcome to the North American Subaru Impreza Owners Club Sunday April 11, 2021
Old 03-01-2021, 01:01 AM   #1
mitchfishman5
Member#: 510946
2004 WRX
World Rally Blue
Default Lean caused from Leaky Valve Cover Gaskets?
So I took my car into the shop last week to have them run a smoke test and they ended up finding one bad leak and replacing the hose. Got it back from them and everything looked good, no more lean, fuel trims looked fine until about 30 minutes later. I got a P0171, was running lean and my trims were back in the 20% range. I took it back and watched them smoke it, then found 2 leaks, one little one in one of my hoses and then a pretty good amount of smoke coming from my leaky valve cover gasket. They told me that my best bet was to pay the $400 and get those replaced and that it would most likely solve my problem. To me this sounds unnecessary as the car ran fine for a while prior to taking it back into the shop but that being said I also didnít see any smoke coming out from anywhere else. From what I have read on the fourm there is a lot of conflicting information. Any ideas on what to do?
mitchfishman5 is offline   Reply With Quote
Old 03-01-2021, 03:02 AM   #2
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
you would see oil leaking out from the valve cover gaskets but I don't think it would cause the car to run lean...in any case you should probably get the gaskets fixed.
murrdogg24 is offline   Reply With Quote
Old 03-01-2021, 09:59 AM   #3
subaru_gc8
Member#: 29292
2004 WRX wagon
why do you think its a leak? most lean codes are maf related problems. inorder to have the PO171 come up its gotta be a really bad leak.
subaru_gc8 is offline   Reply With Quote
Old 03-01-2021, 11:57 AM   #4
rtv900
Member#: 428511
2016 STI
a valve cover would have less than nothing to do with a lean condition
rtv900 is offline   Reply With Quote
Old 03-01-2021, 12:08 PM   #5
mitchfishman5
Member#: 510946
2004 WRX
World Rally Blue
Ok that's what I thought. I watched the shop smoke it and didn't see any significant leaks but I had the same exact symptoms when I did have a leak. The weirdest part was that it was running fine for a while until the AFR and fuel trims got all screwed up.
Old 03-04-2021, 02:46 AM   #6
EconMitch
Member#: 522700
Sounds to me like you need a tune if you're running lean.
P.S. fix that smoke first
EconMitch is offline   Reply With Quote
Old 03-07-2021, 01:04 AM   #7
TwistedAxles101
Member#: 379235
2002 Impreza WRX
Blaze Yellow
Oil could be dripping on to the a/f sensor clogging up the little vent holes. I've seen this cause a lean reading before 100%. Not saying this is your issue, but you should go see if it's oil covered.
TwistedAxles101 is offline   Reply With Quote
