Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Old 09-09-2006, 07:38 PM   #76
tacomaprime
Member#: 70572
2018 Kona
Pulse Red
Originally Posted by J*Bishop View Post
you had to drill an extra hole underneath the bumper for the skinny portion of the splitter to seat properly. test fit! test fit! test fit! it shouldn't have been that much trouble.
Well, I had to drill two holes, cause I have a wagon instead of a sedan. The holes on the underside didn't line up AT ALL for me, so I had to drill two of them.
Not a big deal, alot of people on here removed the upper clips, and used double sided tape. I have pics too, I will post them up.
Besides once I got them in place, the slitse I had drilled were covered up again.
tacomaprime is offline   Reply With Quote
Old 11-24-2006, 07:52 PM   #77
mountjonas
Member#: 93859
2020 STI Base
LBP
i just finished putting these on my wagon. and i'll attest to adidas. i had to drill two new holes in addition to cutting slots for the tabs, which i kept. and man, those slots were a PITA. but i used to tape, only three bolts oper side and it is solid. if you pull on any part of the splitter, the whole bumper moves. if i did it again, i'd take my time. the first side we did is a tad bit sloppier than the second, but the average person can't tell that it's not stock.
overall, i'm very impressed. once i got over the fear of hacking a perfectly good bumper, it went pretty smoothly.
mountjonas is offline   Reply With Quote
Old 11-24-2006, 08:20 PM   #78
surowrxa
Member#: 102895
'12 Forester
'17 Outback
Same here. Just did my wagon and I used the slots + 3 bolts (+ extra drilling). Used a longer bolt, spacer and lock washer for the front "tip" bolt because of the gap and the splitter fits perfect. Looks more natural with the splitters (same height as the sides) and is definitely meaner. WAGON FTW!!!
surowrxa is offline   Reply With Quote
Old 11-25-2006, 02:12 PM   #79
flyinEyeball
Member#: 107870
2004 WRX Wagon
WR Bloo
I picked up a used set and installed them on my 04 wagon today.
I used a dremel to cut off the 3 top tabs & the other mounting points, sanded everything flush and drilled 3 holes on each for bolts/spacers since nothing on the underside lined up. I also used really strong automotive double sided tape for the top edge and outermost edge by the foglight. They are on tight.
Here are some (crappy) pictures. Please excuse the chips/scrapes:
flyinEyeball is offline   Reply With Quote
Old 11-25-2006, 03:03 PM   #80
dibblejr
Member#: 94070
05 LGT
Looks good man.
Jay-r
dibblejr is offline   Reply With Quote
Old 11-27-2006, 10:06 AM   #81
flyinEyeball
Member#: 107870
2004 WRX Wagon
WR Bloo
Originally Posted by dibblejr View Post
Looks good man.
Jay-r
Thanks Jay-R!
Old 12-06-2006, 06:27 PM   #82
mountjonas
Member#: 93859
2020 STI Base
LBP
here's mine
Old 04-29-2007, 07:13 PM   #83
Shift_Oversteer
Member#: 141098
2004 WRX
looks great ^ cant wait to put mine on
Shift_Oversteer is offline   Reply With Quote
Old 04-30-2007, 12:54 AM   #84
mountjonas
Member#: 93859
2020 STI Base
LBP
thanks! just take your time.
Old 05-18-2007, 04:08 PM   #85
jacobsen1
Member#: 16711
2011 forester
2015 legacy
someone was asking me about this today, so bump for the how to....
jacobsen1 is offline   Reply With Quote
Old 06-05-2007, 08:51 PM   #86
misterjoshua
Member#: 140599
'05 WRX Stg2
Just read through the thread and everyone keeps talking about the "supplied hardware". I just got mine in from SubaruGenuineParts.com and didn't get any hardware. Ah well. Guess I will have to drop by the hardware store before the install.
Only thing that is confusing me a little is the mentioned 3x3mm portion toward the skinny end of the piece that needs to be trimmed. Other than that, after my own personal mock-up, it looks pretty simple.
misterjoshua is offline   Reply With Quote
Old 06-05-2007, 08:52 PM   #87
misterjoshua
Member#: 140599
'05 WRX Stg2
Originally Posted by mountjonas View Post
here's mine
That looks tough.
Old 06-06-2007, 12:23 AM   #88
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
re-check the packaging. there should be some supplied bolts and stuff.
once you do a test fit you'll know what we're talkin about regarding the 3x3 portion.
Bishop is offline   Reply With Quote
Old 06-07-2007, 12:03 AM   #89
misterjoshua
Member#: 140599
'05 WRX Stg2
I imagine its this little bugger.
Just wanted to make sure before I started any cutting. Plus, I imagine when those 3 clips go in, they aren't coming back out very willingly. Oh and I double checked the box. I got stiffed by SubaruGenuineParts. No hardware to be found. Not a big deal.
Old 06-07-2007, 12:32 AM   #90
Rail
Member#: 38287
2005 Honda S2000
NFR
SubaruGenuineParts offers the splitters two ways - with and without the hardware. Are you sure you ordered the right kit?
Rail is offline   Reply With Quote
Old 06-07-2007, 02:45 AM   #91
misterjoshua
Member#: 140599
'05 WRX Stg2
SOB.
:::sigh:::
I didn't know they sold the "kit" with hardware. When I ordered, I only saw the per side advertisements. The kit is on the next page.
You would think they would group this stuff together.. :P
Can anyone tell me what hardware comes with the kit? Is it actually "bolts" like people keep saying or is it the rubber anchored screws?
Old 06-07-2007, 02:57 AM   #92
mountjonas
Member#: 93859
2020 STI Base
LBP
just bolts and the clips they screw into, 6 pairs total, i believe. 3 each side.
Old 06-07-2007, 10:25 PM   #93
misterjoshua
Member#: 140599
'05 WRX Stg2
Heres how it turned out for me. Hardest part was the first dremel cut. I had to look at it for a second and say a little prayer that everything works out :P. But once you get going it takes about 30 minutes to do both sides. Since I didn't have the stock hardware, I went down to Autozone and grabbed some clips and some 1/2" push lock pins (?what their called). It went on SOLID. Used two clips and 2 pins per side. I really think the two sided tape approach would have been a big mistake. I'm glad I made the cuts.
Old 07-23-2007, 11:41 PM   #94
NW OBS
Member#: 101361
05 OBS
Obsidian Pearl Black
Question Wagon Splitters & Lip?
Does anyone run the splitters AND a lip on a WAGON? Did it fit?? Pictures???
NW OBS is offline   Reply With Quote
Old 07-24-2007, 09:20 AM   #95
Bishop
Member#: 59993
Ass, grass or cash
there are a couple pics in this thread...
Old 07-24-2007, 09:46 AM   #96
NW OBS
Member#: 101361
05 OBS
There is not a single shot of a wagon with the splitters AND and after market lip. Just wagons with the splitters. My point? Will the sedan lip fit on the more narrow bumper cover of the wagon? If so, would love to see a pic of that install ~
Old 07-24-2007, 10:41 AM   #97
dibblejr
Member#: 94070
05 LGT
Sedan lips will not fit a wagon unless you want to cut and do some work on them, or unless you want to do an entire front end swap.
If you can find a source you can buy the Sti Wagon parts from Japan which are direct bolt on.
02-03 there are a few wagon kits in the states however 04+ JDM Sti wagon is the only way without modding the lips or body.
Here are my lips JDM Sti wagon.
Old 07-24-2007, 10:45 AM   #98
dibblejr
Member#: 94070
05 LGT
OBS and Wrx wagons are exactly the same width. My wife has the OBS 02 and I have the 04 Wrx wagon, the 02-03 Wrx Wagon Body Parts will fit on the OBS, they will look weird if you do not get the same model years.
All side skirts are interchangeable between model years and sedans, no problems. My pics above I have the Sti skirts on my wagon.
Jay-R
Old 07-24-2007, 10:50 AM   #99
Jstyles21
Member#: 95454
2008 STI
www.CTSUBIE.com
Nice Wagon ,
Guys,Geat Job with the splitters b/c those are definately a pain.
Jstyles21 is offline   Reply With Quote
Old 07-24-2007, 11:02 AM   #100
NW OBS
Member#: 101361
05 OBS
Thanks so much... it is what I figured!
STI Side splitter install jonthesloth Interior & Exterior Modification 18 05-03-2009 03:14 PM
STi side splitters install Cannonbolt Interior & Exterior Modification 9 07-23-2008 04:14 PM
STi Side Splitter Install Question Godfather Inc 03 Interior & Exterior Modification 21 08-15-2006 12:44 PM
Side splitter install aid Thumper23 Interior & Exterior Modification 2 04-28-2004 07:09 PM
Side splitters install on WRX blackout Interior & Exterior Modification 12 03-31-2004 09:07 AM
