#101 |
Member#: 97031
![]() Hey i no this is kinda old but any tricks to get them off if you goof up... i put one of the splitters on perfect and then the second one i must have rushed cuz i lined it up but when i pushed the clips in it moved back a little and its not perfectly lined up. iv been trying to get it off but im afraid of breaking the clips. anyone have a suggestion?
#102 |
Member#: 149317
Vehicle:'95 BMW M3 (E36) '05 Kawi ZX6R, '73 CB350F |
![]() good writeup
#103 |
Member#: 145233
SCIC
Vehicle:05' WRX Aspen White |
![]() how exactly are the little metal clips that come with bolts supposed to be used? i dont feel like putting them on wrong so i thought id ask before i do this tomorrow morning
#104 |
Member#: 107931
South East
Vehicle:2004 WRX Cobb Stg. 2 WRB |
![]() This is probably a dead thread, but I want to cut the slits in the bumper but my only concern is that the splitters won't fit flush with the bumper.
#105 |
Member#: 101361
NWIC
Vehicle:05 OBS Obsidian Pearl Black |
![]() The place where it does NOT line up is the fender contour, it is off where it joins the original wagon fender ~ It's no too bad, but it was enough I chose not to do it...
#106 |
Member#: 107931
South East
![]() What about on the sedans? Do they have the same problem?
#107 |
Member#: 101361
NWIC
#108 |
Member#: 107931
South East
![]() Ok, that is what I have. So they should fit like a glove then right?
#109 |
Member#: 188424
Vehicle:2012 LS6 FD RX7, Evo |
![]() how are those tape installed methods working for everyone?
im debating whether i should go with slit method or tape method. |
#110 | |
Member#: 78314
Vehicle:04 PSM WRX Audi mask the right way |
![]() Quote:
#111 | |
Member#: 175170
Vehicle:2005 WRX Wagon owl + bungee cord= my a$$ |
![]() Quote:
I used the wider tape (1" wide?). Had to "double up tape" along diagnal edge where I removed three white/black mounting tabs because I felt single layer tape wasn't thick enough. As long as surfaces are properly cleaned, Splitters are not going anywhere...period. |
#112 | |
Member#: 170245
South East
Vehicle:'11 WRX Sedan SSM |
![]() Quote:
+1 for tape |
#113 |
Member#: 107931
South East
![]() I cut the slits and I am very glad I did! Just taping them on just doesn't seem like the right way to do it.
#114 |
Member#: 170245
South East
#115 |
Member#: 107931
South East
![]() Still taping something to your car doesn't seem like the right way to do something.
But you are right to each their own. |
#116 |
Member#: 145180
NESIC
Vehicle:2018 86 2020 Nissan Versa |
![]() Bump..
So yeah, I will be installing a pair of splitters on my sedan tomorrow night. I'm still debating whether to use 3M tape or a dremel. I'll probably end up using tape though, instead of cutting into my bumper. Wish me luck. |
#117 | |
Member#: 78314
![]() Quote:
#118 |
Member#: 145180
NESIC
![]() Well, I've decided to go with the 3M tape. Just needed to know where I need to put it. Obviously the top of the splitter, where I cut the three tabs off, but is there anywhere else I should apply tape?
#119 |
Member#: 142029
Vehicle:2013 Forester 2008 350z, 1991 Miata BRG |
![]() I would also apply it to the front section (the section that wraps next to the fog light cover or fog light surround).
#120 |
Member#: 145180
NESIC
![]() I thought that was was where you bolt the rest of the splitter on. I'm going to attempt this after work and I plan on taking my time. Thanks for the replies though.
#121 |
Member#: 58294
Vehicle:2004 WRX / 1998 Foz SoCal F4 #20 / Area1320 |
![]() i put 3m tape between the bolt holes for added support...after i tore one of them off on a concrete parking lot stopper thing
#122 |
Member#: 181192
BAIC
Vehicle:2005 obp wrx stg2 tune by Clark Turner |
![]() back from the dead. so i just picked up a set of splitters for 40$ used off a member in i-club. I don't have the hardware and was reading between cutting and taping. What would others recommend. I'm leaning towards 3m tape but after that parking stopper post I'm a lil bit unsure on which method to use.
#123 |
Member#: 190454
NESIC
Vehicle:2005 wrx stage II white like my bitch |
![]() can you re use the snap clips from your stock bumper or do you have to purchase new ones?
#124 |
Member#: 90357
Vehicle:2006 Corey's EVO & 1993 Mazda RX7 |
![]() Anyone know the part number for the upper bracket (front right) that mounts inside the bumper and secure the to the upper most tabs on the splitter?
#125 |
Member#: 242253
Vehicle:2004 Wrx PSM |
![]() I just installed them myself yesterday. the method i used was cutting the 3 slits in the bumper.
STI Side splitter install | jonthesloth | Interior & Exterior Modification | 18 | 05-03-2009 03:14 PM |
STi side splitters install | Cannonbolt | Interior & Exterior Modification | 9 | 07-23-2008 04:14 PM |
STi Side Splitter Install Question | Godfather Inc 03 | Interior & Exterior Modification | 21 | 08-15-2006 12:44 PM |
Side splitter install aid | Thumper23 | Interior & Exterior Modification | 2 | 04-28-2004 07:09 PM |
Side splitters install on WRX | blackout | Interior & Exterior Modification | 12 | 03-31-2004 09:07 AM |
