Welcome to the North American Subaru Impreza Owners Club Tuesday April 13, 2021
Old 04-14-2012, 05:33 PM   #126
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
fixed it bump...
doubledribble is offline   Reply With Quote
Old 04-15-2012, 01:16 AM   #127
Cody
Member#: 42048
03 WRX Wagon
Sonic Yellow
Originally Posted by doubledribble View Post
Thanks. Figured it out. Buying a used linkage is the way to go. All in all a 30min job. Hopefully it holds up for a bit.
I went new. I think it was $80 or something.
Cody is offline   Reply With Quote
Old 04-16-2012, 02:01 PM   #128
doubledribble
Member#: 42912
2003 Outback Sport
I couldn't find the part new under $100 shipped so I gambled on this one from a part out...seems sturdy enough, hopefully last the remainder of this cars life.
Old 04-17-2012, 01:29 PM   #129
Speedster329
Member#: 214652
2004 STI !
Im having a problem.with my wipers if anyone can please help me !
It was about a werk ago it was raining and i was using my wipers just fine. Parked the car went in to a store came back out and now they dont work. None of the speeds work at all and the only thing working is the window washer fluid it still squirts out but dosent wipe the window.
So i bought a wiper switch/module and replaced it yesterday and it did the same exact thing. I checked the wiper fuse and it is still good. My question is should i check the wiper motor to see if its getting power at all or has anyone had this issue that can lead me to the next thing i can do
Any info or help is well appreciated ! Would love to have these done before the next rainy day comes lol
Speedster329 is offline   Reply With Quote
Old 04-29-2012, 01:57 PM   #130
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Just used this to fix my wipers. Thanks guys!
Crazykev is offline   Reply With Quote
Old 05-26-2012, 12:38 AM   #131
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
does anyone know if 02-03 wrx wiper linkage vs 04-07 wrx have the same linkage?? they both have a different part number... But I remember while back I actually bought a used motor off of a 04 sti and worked without a issue can anyone confirm?
02-03 part # 86521FE010
04-07 part # 86521FE090
taeyax82 is offline   Reply With Quote
Old 05-26-2012, 07:35 PM   #132
billzebub
Member#: 40248
2003 WRX
Midnight Pearl (black)
The 04+ have a different mount, but if your motor is ok, just swap the linkage. That's what I had to do.
The linkage is the same length. If your motor is bad, you could swap the motor as well, but the complete 04 assembly will not fit on a bugeye.
billzebub is offline   Reply With Quote
Old 05-29-2012, 04:04 PM   #133
minduka
Member#: 218696
Originally Posted by ImprezaVA View Post
Last update
I used the kit from Advance: Motormite 49447, as suggested by Roy (http://www.partsamerica.com/ProductD...rtnumber=49447). Here's a pic of the bushing I used. All 3 will work, but I broke 2 out of 3 trying to make it fit. I finally got it to fit with the help of a friend holding the linkage arm while I took two channel locks and squeezed it in. Its a tight and safe fit. My wipers work like new again.
Roy, I got this to fit without clipping the ears
-Charles-
Thanks Charles you method worked perfectly. 02 WRX
Much easier than the nissan links.
minduka is offline   Reply With Quote
Old 06-10-2012, 08:10 PM   #134
SerWendel
Member#: 322804
2002 Subaru
I have also been dealing with this problem since Dec. and decided to fix it today. The 49447 part kit worked like a charm, using the same one mentioned in this article. It is a bear to get in, but they're working like new now! 2.99 @ Advance Auto. Can't beat it(and I don't have to hang my arm out in the rain anymore! Bonus!)
I removed the whole linkage/motor system out of the car, and found the first joint bushing to be smashed. I used some vises on my toolbox to hold it, and used pliers to pinch while pushing down with a panel tool. Took a little bit of work and time(and a bloody knuckle), but it is VERY solid, especially compared to the rest of the joints in the kit.
Best of luck!
SerWendel is offline   Reply With Quote
Old 07-31-2012, 10:13 PM   #135
DenT
Member#: 201779
2003 Impreza TS
About to embark on a wiper adventure myself. I've got an 03 TS with a lot of slop. I was wondering if i could get a follow up from some of the Dorman 49447 folks to see how it held up?
DenT is offline   Reply With Quote
Old 07-31-2012, 10:43 PM   #136
Got Groceries?
Member#: 25323
2003 WRX Wagon
My first repair lasted over four years before something needed replacing.
Got Groceries? is offline   Reply With Quote
Old 10-15-2012, 01:16 AM   #137
walljer
Member#: 335125
I have a 2002 Legacy Wagon. This fix works perfect. I used the Help 49447. It was hard to get it worked in to the arm, but once it is in, it is tight as a drum! I didn't bother putting a zip tie in.
The key is putting it in the right direction. I tried putting the cap through first, and it breaks off all the clips and wont work. If you put it through the other direction, it works great. Press the base of bushing through. Had to use a screw driver and needle nose pliers, and you might think it is impossible, but it will go. Just takes a lot of finagling.
Thanks so much to Roy and ImprezaVA. You guys are life savers!
walljer is offline   Reply With Quote
Old 01-16-2013, 03:03 PM   #138
djoye
Member#: 50072
2017 STI
2003 WRX, my driver-side arm had lots of play.
I used the tabbed bushing from 49447 as it's the only one from that kit that would fit tightly. I used pliers, a flat-head screw driver, and a small pointy tool. I used the small pointy tool to get under the tabs and slightly bend them up and I used the pliers to squeeze and flex the four plastic sections at the bottom.
Using just my hands (wear gloves!) I forced one of the four sides into the linkage arm and used the pointy tool to get under the tabs and lift them so I could get the bushing lip down under the linkage. I'd turn the bushing and work the rest of the plastic under with the flat-head and the tabs over with the small pointy tool. Be patient and careful not to stab yourself. After I got 2-3 sections of the bushing in, I applied downward force on the bushing with my thumb and used the flat-head to shove the remaining section down under the linkage arm.
I didn't use a zip tie and I left the tabs since they're what keeps the arm from jumping off of the bushing.
Feels tight as ever now. Now to go buy a new wiper blade since the rubber tore while hitting the A-pillar, heh.
djoye is offline   Reply With Quote
Old 02-15-2013, 03:14 PM   #139
Novtec1
Member#: 13641
just did this... heat and a pair of vicegrips made it wasy used the 49477 kit... now just gotta wait till it rains to really test it out. My old bushings were shot!!!!
Novtec1 is offline   Reply With Quote
Old 02-17-2013, 08:06 PM   #140
mark342
Member#: 284693
1999 Impreza 2.5 RS
STM
Just did this, kept two clips on with a zip tie, it's better but probably not quite perfect.
mark342 is offline   Reply With Quote
Old 02-27-2013, 09:38 AM   #141
Kthunder
Member#: 228724
2010 Wrx 2010Limited
What would you guys consider to be the best wiper?
Kthunder is offline   Reply With Quote
Old 02-28-2013, 12:39 AM   #142
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
PIAA silicon! I've had them on for 6 years now! Rubber is still soft and swipes just fine. Gonna get new ones cause the black has faded but other than that, they're awesome. O I also live in So Cal and the "wet" weather isn't that significant, but the heat is and they have held up. All my cars have them and I highly recommend them.
recce02 is offline   Reply With Quote
Old 03-06-2013, 02:19 PM   #143
doubledribble
Member#: 42912
2003 Outback Sport
nope. back to slapping. i'm going to buy a new assembly and call it a day...not worth my time or effort anymore to try and fix it on the cheap.
EDIT: $85 and 20min later my wipers are back to normal as good as new. Perfect timing since it is pouring like crazy today.
Old 03-11-2013, 11:31 PM   #144
wyleb2
Member#: 206217
2006 WRX
Arrest me red
If anyone is keeping track the 49447 worked on my 06 WRX. Will see how long it lasts but it seemed like it was in there pretty good. I trimmed one of the ears in my effort to figure out how to get it in, but could have gotten it without trimming if i was more persistent.
wyleb2 is offline   Reply With Quote
Old 04-12-2013, 04:39 PM   #145
silverton
Member#: 331131
2001 2.5RS-T
Silver..thorn Metallic
Here's my take on the whole thing... such a PITA this was! If I never have to do it again, it'll be too soon. I forgot to add grease so I'll probably have to pull the wiper motor again and apply liberally.
http://i.imgur.com/hB3dh1p.jpg
silverton is offline   Reply With Quote
Old 04-17-2013, 06:52 PM   #146
fastphil
Member#: 230199
2005 Saab 92x Aero
I just started googling wiper linkage issues and i found this thread. Seems like a common issue! I have an 05 Saab 92x. I don't have the 4-5" of slop you guys mention, but my linkage has popped off twice where it connects to the motor in the last few weeks. The second time happened half a wipe after I repaired it!
I'll probably just buy all 3 of the kits mentioned in this thread and keep the ones I don't use as backup.
fastphil is offline   Reply With Quote
Old 05-18-2013, 02:29 AM   #147
JesseJames92x
Member#: 265972
2005 9-2x Aero
I'm having this issue on my '06 WRX wagon, hoping to fix it this weekend. Which method did you end up using?
PS I also have a 9-2x but since I bought the WRX the Saabaru will be up for sale sooon... Great car though, plus making the transition from a '05 9-2x to the '06 WRX is well... not too bad, haha.
- James
JesseJames92x is offline   Reply With Quote
Old 05-18-2013, 08:28 AM   #148
fastphil
Member#: 230199
2005 Saab 92x Aero
- James
I haven't gotten around to fixing it yet, but I bought the 49447 kit. The car isn't being used right now, so I'm in no hurry to fix it, but I'll just follow the directions the others have posted in this thread.
Old 05-30-2013, 09:10 PM   #149
fastphil
Member#: 230199
2005 Saab 92x Aero
I did mine the other day, I just had the one that was on the back of the motor that was popping off. I did it quick and dirty, but I did notice that one of the other cups had been swapped out sometime in the past by a previous owner. With a little futzing, you can get the new cup through the rod with all the small tabs intact, but I broke one off. there's still some play now with the cup on the ball, but I'll try it like that until it fails again. Then I'll put more effort into repairing it next time.
Old 06-11-2013, 06:52 PM   #150
fastphil
Member#: 230199
2005 Saab 92x Aero
As such things always go for me, my first attempt at repairing this didn't work. Worked fine when I tested it, but it lasted a wipe and a half once I got in to drive it (in the rain, naturally).
I just repaired it again by putting a tie wrap around the new cup on the backside of the tab. It's tighter than it was, but I still don't have high hopes.
Wiper Problem cg333 Service & Maintenance 2 03-23-2008 09:53 PM
06 STi wiper problem Flipgod Interior & Exterior Modification 15 08-22-2007 07:25 PM
Bizarre windshield wiper problem elijahwrx Service & Maintenance 7 04-03-2007 09:21 AM
Windshield Wiper Problems molehill84 Warranty Issues & SOA Problems 3 02-24-2007 02:41 PM
wiper problem legacy2003 Service & Maintenance 2 12-14-2004 02:51 PM
