Welcome to the North American Subaru Impreza Owners Club Tuesday April 13, 2021
Old 12-14-2004, 04:51 AM   #1
legacy2003
Member#: 38338
2003 Outback Sdn H6
Impreza GC8 wiper problem
i went out last night and my wipers were working fine. tonight i went out and turned on my wipers because it was snowing a bit and the passenger side wiper works fine, but the driver's side wiper comes about halfway up. its much slower than it used to be and because its slow and doesnt make it to where it should be the passenger wiper hits it, making an x formation. i checked the bolt holding the wiper arm on and it was tight. however, when i try to move the wipers by hand the passenger side arm is stiff and wont budge, and the driver's side one moves freely.
what do you guys think the issue is? i really hope its just something simple, but it has never done this before.
im going to give the dealer a call tomorrow and have them look at it, but i was really wondering if any of you have had this happen before.
-mike
legacy2003 is offline   Reply With Quote
Old 12-14-2004, 05:02 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Are you sure the nut is tight?
If it truely is, maybe remove the nut, pull the arm, lay a piece of thin cardboard on the tapered pin the arm mounts to and then reinstall the arm.
It is "possible" the hole in the arm is a bit big from getting stressed, and the cardboard will take up some of the slop.
Also follow this thread, it is similar... http://forums.nasioc.com/forums/showthread.php?t=676373
Old 12-14-2004, 02:51 PM   #3
legacy2003
Member#: 38338
2003 Outback Sdn H6
i figured it out. bolt was loose :C) thanks man.
Wiper Problem ImprezaVA Service & Maintenance 178 01-02-2021 05:07 PM
Wiper Problem cg333 Service & Maintenance 2 03-23-2008 09:53 PM
06 STi wiper problem Flipgod Interior & Exterior Modification 15 08-22-2007 07:25 PM
Bizarre windshield wiper problem elijahwrx Service & Maintenance 7 04-03-2007 09:21 AM
Windshield Wiper Problems molehill84 Warranty Issues & SOA Problems 3 02-24-2007 02:41 PM
