Welcome to the North American Subaru Impreza Owners Club Saturday April 10, 2021
Old 05-11-2018, 10:58 AM   #326
fleezy
Member#: 436768
2004 WRX
can i make a 4 port catch can instead of 2 2 ports?
fleezy is offline   Reply With Quote
Old 05-11-2018, 12:09 PM   #327
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
V4 GF8 White
Question
Originally Posted by KCRS01 View Post
when you use a closed loop system the oil just recirculates in the system, meaning, if it has dirt/contaminants it just go back to the engine.
while vent to atmosphere AOS vents the oil going to the pipe and going to the street. the dirty oil in the system is then completely removed and not recirculated.
Ummm.... there appears to be some sort of confusion here. Venting (or not venting) the PCV system to the atmosphere has nothing to do with where collected oil goes. These are two separate variables. The catch cans I use do not drain back into the crankcase, and it's a closed system... as Subaru originally intended it to be.
Vancouver98STi is offline   Reply With Quote
Old 07-20-2018, 09:45 AM   #328
VinceS2
Member#: 353338
2005 EVO 8 WRX + STi
gold
Because of the length of this thread, I started a new thread with a guide on what the smartest way to do the catch can mod is on a standard TMIC setup. See https://forums.nasioc.com/forums/sho....php?t=2879743
Just figured it was appropriate to cross-reference this thread back to that one, for completeness.
VinceS2 is offline   Reply With Quote
Old 01-27-2019, 01:48 PM   #329
edmartin81
Member#: 439201
Thanks for the post. I've been debating whether to install one on my EJ. I knew catch cans were needed to keep the FA ports from gumming up, but I didn't consider oil vapor condensing in the intercooler.
edmartin81 is offline   Reply With Quote
Old 03-01-2019, 11:42 AM   #330
GK1707
Member#: 373868
'04 STi
Anyone know the hose sizes? I'm reading 3/8 between and 1/2. I'll be running a 3 port catch can.
PCV and breather IN to catch can and OUT to turbo inlet
GK1707 is offline   Reply With Quote
Old 03-01-2019, 08:06 PM   #331
pcampbell
Member#: 437670
2005 2.5 SC OB
On my valve breathers 1/2” work great. Snug and No hose clamps needed.
pcampbell is offline   Reply With Quote
Old 11-18-2020, 03:52 PM   #332
sebastian323
Member#: 510671
2006 WRX
Gray
how about this idea - I run a three port catch can with two inlets , one inlet going to the PCV and the other inlet to the valve cover breather lines, and the outlet to the turbo inlet pipe.
EDIT: just read this :
WRONG WAY: Disconnect the PCV<->Inlet line as well as the Crank Vent<->Inlet line. "T" the PCV and Crank vent lines together, and run the remaining end of the "T" to a single nipple on the inlet pipe. Cap the remaining nipple on the inlet. You'll be sending boost into places that definitely shouldn't ever see any. Bad idea.
I don't understand how t-ing the lines together is bad if they both ultimately share a junction at the turbo inlet pipe (which is under suction and not boost from the turbo) can someone elaborate.
also , as I understand vented catch can is not a god idea as it will allow unmetered air into the system
sebastian323 is offline   Reply With Quote
Old 11-18-2020, 05:13 PM   #333
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
Might as well put this here ADD W1 CC on 2019 Impreza Sport
https://photos.app.goo.gl/rNGgBQvBkKaiYtjA6
Peaty is offline   Reply With Quote
Old 11-22-2020, 01:00 PM   #334
pcampbell
Member#: 437670
2005 2.5 SC OB
Default Catch Can FAQ
Blast from the past— I used to work with Kastle (in real life). Do you keep up with him?
Old 01-23-2021, 11:39 AM   #335
relic48
Member#: 408588
Just in case anyone is interested in 1957 "unmetered air" and emissions, scroll down to the 3rd paragraph in the article and look at the picture below it.
https://www.chevyhardcore.com/news/t...c-small-block/
relic48 is offline   Reply With Quote
Catch can maybe reduce oil use? leighton1245 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-05-2010 06:38 PM
Oil catch can...or catch canS?? BoXinWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-28-2009 05:01 PM
Installed OBX catch can... (another catch can thread) txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-10-2008 01:00 AM
WTT(HR): Greddy Oil Catch Can with Perrin Oil Catch Can scooby_wooby MAIC Private Classifieds 1 03-24-2008 09:01 PM
WTT: Cusco catch can for a perrin catch can sti charles Engine/Power/Exhaust 10 11-29-2007 01:04 AM
