Welcome to the North American Subaru Impreza Owners Club Sunday April 18, 2021
Old 09-14-2007, 08:45 PM   #126
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
I replaced the gasket, but since then minor rough idle started to develop. I used a MAF sensor cleaner to clean it out...
Old 09-20-2007, 07:15 PM   #127
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
i cleaned it, but my idle is stilll high. it also sounds like a lawnmower when it is idling at 2500.
do i need to buy another IACV?
distorto is offline   Reply With Quote
Old 09-24-2007, 10:38 PM   #128
rcy
Member#: 160124
Did this today. Worked like a charm. Used Castrol Super Clean and THAT worked like a charm. Couldn't believe the amount of black bits of crap the came out (carbon? grease? dirt?). Anyhow, this is an easy DIY that makes a big difference.
rcy is offline   Reply With Quote
Old 10-05-2007, 12:19 AM   #129
wrxrex
Member#: 130196
Old Stage 4 bugeye
Did anyone open up the sensor instead of just spraying with the cleaner?
wrxrex is offline   Reply With Quote
Old 01-07-2008, 11:21 PM   #130
NYSTI
Member#: 115021
335i TurboXs~juiced
AnDrEwTeCh~BuIlT
NYSTI is offline   Reply With Quote
Old 01-08-2008, 07:10 PM   #131
SPOOLME
Member#: 91210
2004 WRx
bumping an old thread..
But for allof you guys who tried this.. were your idling problems like gradual like it was always bad at idle?
Because in my situation, the cars been running fine and then all of a sudden it started to idle at 2k. Wasn't like it had messed up idles from before, it was just out of no where. Could this sti be the iacv?
SPOOLME is offline   Reply With Quote
Old 02-17-2008, 08:56 PM   #132
seherman
Member#: 172084
Question 02 legacy outback idles down
What a thread! Our 02 Legacy outback wagon 2.5 L idles down at a stop to under 500 rpm, then bounces back up. It cycles every 5 to 10 seconds. Should I do the GM engine cleaner treatment as described?
seherman is offline   Reply With Quote
Old 03-02-2008, 03:12 PM   #133
mostasz
Member#: 170512
2012 WRX
Ice Silver
Thanks scooterforever!! Good job!!
I had no problems with mine, but did it anyway. At least it is clean!!
Also no problems with screws, just used flathead, pushing it downwards, when twisting, and worked fine.
I got mine bolts from Ace Hardware, was like $3 for bolts, flat washers and lock washers. Whole thing took me about 20 minutes.
mostasz is offline   Reply With Quote
Old 03-03-2008, 06:35 PM   #134
1904WRX
Member#: 162547
2003 WRX
Sedona Red Pearl
I did mine over the weekend.
Be very careful when you tighten down the machine screws. I managed to strip out both holes. Luckily I had the correct size helicoil and I was able to fix the damage.
Still, I would have rather not ****ed things up.
1904WRX is offline   Reply With Quote
Old 03-04-2008, 12:58 PM   #135
SubieRon
Member#: 64485
2004 GGA
i need to do this...my car doesnt idle at a stop like it used to.
SubieRon is offline   Reply With Quote
Old 03-04-2008, 08:18 PM   #136
1904WRX
Member#: 162547
2003 WRX
Sedona Red Pearl
So not only did this not improve my idle, now my boost gauge doesn't top out where it used to. I used to max out at 100kpa(14.5psi). Now it falls just short of that. I didn't install the gauges, but there is a difference between now and last week.
Everything feels fine. WTF?
Old 03-05-2008, 06:29 AM   #137
mostasz
Member#: 170512
2012 WRX
Ice Silver
Your gasket is not sitting well, so You got air leak there...
Old 04-02-2008, 08:20 PM   #138
Rawker
Member#: 176402
can i do this with my automatic 2.5 01 legacy sedan, i've been having this issue quite a bit and my car stalled today while fully stopped. I know nothing about cars, i assume i'm supposed to look near the air filter for IACV?
Rawker is offline   Reply With Quote
Old 04-04-2008, 09:05 AM   #139
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
It's on the throttle body.
bucket7788 is offline   Reply With Quote
Old 04-07-2008, 08:43 PM   #140
Rawker
Member#: 176402
well i got some intake cleaner spray and tried it out but now my car sounds like a 16 year olds honda when my rpm's are in the 3000-4000 range
Old 04-07-2008, 09:37 PM   #141
rexman2002
Member#: 140244
2002 bugeye
still rippin' hard
^^^ Did you use a new gasket, or did you resue the old one?
rexman2002 is offline   Reply With Quote
Old 04-07-2008, 09:47 PM   #142
Rawker
Member#: 176402
sorry i should have mentioned that i just tried the spray cleaner into the manifold not removing the IACV and cleaning. the noise comes from the front, not the back so it's not the exhaust and it's a plastic sound not metal.
forgot to mention that i got a check engine light as well lol.
Old 04-07-2008, 10:26 PM   #143
mostasz
Member#: 170512
2012 WRX
Ice Silver
Only reason come trough my mind is that some deposits removed by cleaner got to MAF sensor, and blocked it stuck closed... or preventing it to open beyond some angle.
I would say to take sensor out, clean it using 90% alcohol and Q tips, like I did. Soak it in alcohol is good idea. Then put it back, replace gasket with new, reset the ECU, and try again.
Old 04-08-2008, 03:54 PM   #144
Ekeenan86
Member#: 155493
1999 Legacy Outback
Hey this is a great write up and I'm definitely doing this once things start to warm up, however I have two questions. Can I take out the IACV completely, or do I need to clean it while its still attached to the car. Also, to reset the ECU do you recommend detaching the battery and letting it sit for a little? Thanks for your help, you're the man.
Ekeenan86 is offline   Reply With Quote
Old 04-08-2008, 06:00 PM   #145
mostasz
Member#: 170512
2012 WRX
Ice Silver
You can take it out completely. Disconnect battery before You start cleaning, connect after finish. It will be long enough. Usually 30 sec do the job.
Old 04-08-2008, 11:16 PM   #146
rexman2002
Member#: 140244
2002 bugeye
still rippin' hard
Like mentioned in the original post, remember to get a new gasket when doing this. In my case the old gasket didn't rip, but still it is a precaution to put in a new gasket. I just finished cleaning it about 20 minutes ago. I used a flat screwdriver to take out the 2 screws, pressed it hard, and the screws gave way, without destroying them. Take your time it took me 45 min. from start to finish. I used some wd-40 and alcohol plus q-tips to clean it.
To the OP, great write up!
Old 04-11-2008, 06:43 PM   #147
Rawker
Member#: 176402
my engine looks like this, where is the IACV?
note this is not my picture
Old 04-12-2008, 06:24 PM   #148
Don851
Member#: 177311
Pulled the IAC out of my 96 Legacy 2.2 and was wondering do I remove the bolt on the bottom? Or do I just leave it intact and spray cleaner into the opening where the gasket sits over and let the dirty stuff drain out the same opening?
Thanks!
Don851 is offline   Reply With Quote
Old 04-16-2008, 09:44 AM   #149
Siper2
Member#: 1134
2015 Outback H-6
Awesome thread. This was suggested to me, after I posted on LegacyGT.com regarding my wife's '01 Outback H-6 LL Bean:
http://www.legacygt.com/forums/showthread.php?t=83882
I have the gasket on order, and picked up some carb cleaner and PB Blaster, last night at the auto parts store. Going to the hardware store today, to get the 5x20mm hex bolts. (Though I guess they don't have to be hex-head...)
Siper2 is offline   Reply With Quote
Old 05-19-2008, 12:35 PM   #150
WC LATHE WERKS
Member#: 175549
2007 Forester STi
1965 Shelby Cobra (F5)
going to try this soon
WC LATHE WERKS is offline   Reply With Quote
WTB: IACV (Idle Air Control Valve) JasonF Private 'Wanted' Classifieds 1 07-29-2009 01:40 PM
WTB IACV (Idle Air Control Valve) Tical Private 'Wanted' Classifieds 2 05-22-2009 02:31 PM
wtb- IACV (Idle Air Control Valve) BrettS Private 'Wanted' Classifieds 2 05-03-2006 10:57 AM
IACV Idle Air Control Valve jvcastillo21 Private 'Wanted' Classifieds 6 02-10-2006 10:02 PM
How To Replace The IACV Gasket (Idle Air Control Valve) scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-21-2005 05:52 PM
