Welcome to the North American Subaru Impreza Owners Club Tuesday April 13, 2021
Old 03-01-2006, 06:21 PM   #1
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Default DIY Closed-Deck
I was perusing random forums the other day and found this. I figure for someone with more time and blocks then they know what to do with, this might be an interesting thing to try...
http://www.honda-tech.com/zerothread?id=1444721
At first it had me 'ing, then I was 'ing, now I'm thinking it might actually be interesting to try.
End-result:
Old 03-01-2006, 06:45 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
interesting, however I wouldnt do that on any car besides a dedicated drag car. Since I have no idea of the thermal properties of that material or how it will hold up in the long run.
Def is a cheap solution though.
Ben
Old 03-01-2006, 08:27 PM   #3
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Aluminum epoxy is a pretty wonderful goo. The Aluminum it leaves behind is a fairly soft variety with a pretty huge co-efficient of thermal expansion. As long as the filler isn't actually touching the head gasket it would probably hold up for a very long time. Heads don't actually need THAT much coolant flow. Running completely closed deck blocks on street cars can be done with a bit of creativity (hint, use passages in the head, but feed it from an external source).
Very cool little DIY. Thanks 8complex.
no-coast-punk is offline   Reply With Quote
Old 03-01-2006, 08:30 PM   #4
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
very very interestin. now which one of us is gonna do this?? go go go!!
Bishop is offline   Reply With Quote
Old 03-01-2006, 08:37 PM   #5
rst4me
Member#: 108286
Looks like a good alturnitive to the drill plug method.
rst4me is offline   Reply With Quote
Old 03-01-2006, 10:16 PM   #6
SubyGC8
Member#: 70069
2005 Legacy GT
Satin Pearl White
The person that did that write-up is actually personal friends with my brother. He recently dyno'd his car and hit near 400whp with the factory sleeves. You can see the same write-up by Hotrex on turbooptions.com in DIY Fabrication under Block Filling Hotrex Style if you are interested.
SubyGC8 is offline   Reply With Quote
Old 03-01-2006, 10:52 PM   #7
rst4me
Member#: 108286
any updates on how its holding up?
is this his daily driver or just a 'play' car?
Old 03-02-2006, 08:15 PM   #8
SubyGC8
Member#: 70069
2005 Legacy GT
Satin Pearl White
The car used to be his daily but now I believe its just a project car. From what I've been told its holding you with no troubles.
Old 03-02-2006, 08:32 PM   #9
rst4me
Member#: 108286
oh yeah, it holds me real good, all night long.
but serriously, thats great that its not crumbeling or degrading over time.
Old 03-02-2006, 09:53 PM   #10
IllNastyImpreza
Member#: 36333
98 RS
GT30R, closed deck madnes
you know I was just thinking about something like that today...
I was thinking I could just weld in some "ribbs" to strengthen it...But that looks much easier/better
IllNastyImpreza is offline   Reply With Quote
Old 03-03-2006, 12:17 AM   #11
rst4me
Member#: 108286
Ive seen alot of people take a drill slightly larger than the with of the water jacket. drill a little off of the sleeve and inside block, then instert metal dowel slugs into the drilled area... they do that all around the sleeves.
this does look alot better simply because your not modifying any of the properties of the block metal, just simply adding on.
Old 03-03-2006, 11:21 AM   #12
[email protected]
Member#: 47261
I have to replace my crankcase so I'm thinkin I might try it out... we'll see...
soccer_freak_m@hotma is offline   Reply With Quote
Old 03-03-2006, 04:40 PM   #13
SubyGC8
Member#: 70069
2005 Legacy GT
Satin Pearl White
Whoops, haha! Its holding up with no troubles
Old 03-03-2006, 05:25 PM   #14
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Nifty! Thanks for the update, it seems like such a simple idea, that just MIGHT work.
I guess if I ever really get into it again (AFI) and feel the need to "build" a motor, I will give it a shot.
Old 03-03-2006, 06:46 PM   #15
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
Go figgure, you of all people would be looking into how to closedecking a block
DoctorNick is offline   Reply With Quote
Old 03-03-2006, 10:52 PM   #16
RallyBlue
Member#: 69323
2004 WRX
82 BRAT
There is a certian company that does this for Subaru blocks as well..
http://www.outbackmotors.com/block_pistons_rods.htm
Of course they are targeting the dung buggy market though.
RallyBlue is offline   Reply With Quote
Old 03-05-2006, 09:54 PM   #17
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Looks like they just filled it with a crapload of "liquid steel" epoxy and drilled out some tubes for coolant. Is that really durable enough to provide a substantial increase in sleeve strength?
2slofouru is offline   Reply With Quote
Old 03-05-2006, 09:57 PM   #18
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
i would be worried about the filler expanding too much and warping the cylinders as it expands, or warping the block itself. it just seems a little fishy to me, but if it works, a partial fill would be nice for some added rigidity.
~Josh~
Old 03-06-2006, 05:07 AM   #19
Silverpike
Member#: 92399
I have noticed that on Crawford's race block order page, they offer a fully closed-deck block. Is there a suby engine that was closed deck factory (the N/A maybe) ?
Wouldn't it be simpler just to get an OEM closed deck block than to do this?
Most Honda's only came with open decks, which is why this mod got attention. Of course it also helps that a D-series block is almost free, since you can get them anywhere.
Silverpike is offline   Reply With Quote
Old 03-06-2006, 06:52 AM   #20
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
The '92 - '94 Legacy Turbo came with a 2.2L fully closed deck.
Mike~~
N'CTRL is offline   Reply With Quote
Old 03-06-2006, 10:51 AM   #21
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I would assume that the stuff is just strong enough to help, but not strong enough to deform anything else when it expands. More than likely it just deforms when it expands, so it doesn't cause any damage.
As to how much strength it provides... well, probably not much, but how much does it really take to keep a cylinder from flexing a whole hell of a lot? But when you get up into that area where you're flexing cylinder walls, any little bit could help.
Old 03-06-2006, 08:18 PM   #22
ballitch
Member#: 74907
98 cam'd EJ251
true that. id just make sure you get enough coolant flow around the cylinder walls and you should be golden. the EJ22t from the 1990-1994 legacy turbo came fully-closed deck block, as well as some years of the EJ20G i believe.
~Josh~
Old 03-06-2006, 11:06 PM   #23
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I wouldn't think the filler material would conduct heat well, so it may hinder cooling more than calculated. The coolant is actually contacting the filler material more than the block and cylinder walls. Especially if it's some kind of epoxy, it will conduct heat way slower than an actual metal. What kind of material are they using anyway? I haven't heard any clear answers on that.
Old 03-07-2006, 12:14 AM   #24
LastResort
Member#: 99289
Spec sheet: http://www.devcon.com/techinfo/108.pdf
Gives the thermal conductivity of 1.58 [(cal x cm / (sec x cm(2) x C)] x 10(-3)
where water is 0.606 Wm-1K-1
Lots of units to convert there, and I'm headed to bed, so I'll pass.
MSDS: http://www.devcon.com/techinfo/10710.PDF
PHP Code:
Crystalline silica                       1%
Bisphenol A diglycidyl ether resin     20%-40%
Alkyl Glycidyl Ether                     1%-10
But that is only hazardous ingredients.
LastResort is offline   Reply With Quote
Old 03-07-2006, 09:30 AM   #25
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well, only where the material was contacting the cylinder walls would it not be getting coolant flow like normal. The coolant normally flows into the heads via smaller passages anyway, so as long as you bore out where you need to get flow through the gaskets, you should be fine.
Question on a DIY closed deck? jstam Built Motor Discussion 15 12-15-2008 08:48 PM
Open deck/ semi-closed deck/ closed deck in the STi? scoobybrande News & Rumors 11 10-23-2008 11:32 AM
open deck, semi-closed deck, closed deck jdiddy Newbies & FAQs 9 02-25-2006 12:25 PM
DIY semi-closed deck ej20? TexRex2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-10-2004 12:10 AM
What is the difference between closed deck, open deck, semi-closed deck? disc108 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-07-2002 08:23 AM
