Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 06-07-2007, 08:23 PM   #51
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Originally Posted by cdigerlando View Post
Have any of you 3.0 builders considered sleaving, deck closing, or semi-closing?
I would imagine they'll hit a certain HP level where they will have to sleeve them.
Nice build BTW!!!
99RSTurbo is offline   Reply With Quote
Old 06-08-2007, 01:41 PM   #52
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default sleaving
Nice build BTW!!!
Sure. I'm just wondering what they are using as a rule of thumb as to when we should abandon the cast iron and go to ductile iron. Ductile iron has the added advantage of not only being stronger, but also being slicker, so that less frictional heat is produced. When subaru goes to a solid aluminum/silica alloy block like the new M3, I'm going to that motor!
cdigerlando is offline   Reply With Quote
Old 06-08-2007, 01:54 PM   #53
IllNastyImpreza
Member#: 36333
98 RS
GT30R, closed deck madnes
silica aloy?? crazziness ! when is this going to happen? where can one find some more info on this crazziness !
IllNastyImpreza is offline   Reply With Quote
Old 06-08-2007, 02:19 PM   #54
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default M3
I'm not sure about the percentages used, but silica is used in a lot of aluminum forgings to achieve different properties. Google it. The block I am talking about is the new V-8 M3 motor. Google it too. It is a fantastic motor.
Old 06-08-2007, 02:29 PM   #55
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
I want to see the numbers on this bad boy!
domestic_abuser is offline   Reply With Quote
Old 06-08-2007, 02:36 PM   #56
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
Don't hold your breath
2002WRXSTi is offline   Reply With Quote
Old 06-09-2007, 11:59 PM   #57
SaabTuner
Member#: 67608
Ductile iron conducts half the heat of gray iron. The main reason is that the carbon does most of the heat conduction. Gray iron has conductive "flakes". Ductile iron has non-conductive "nodules". Compacted Graphite Iron has something in between, closer the Gray.
Also, "silica" isn't the same thing as "silicon" (or silicone, for that matter"). Mixing aluminum with "silica" wouldn't make an alloy, it'd make a Metal Matrix Composite because "Silica" is Silicon Dioxide, IE: glass.
Subaru and BMW probably already BOTH use silicon as one of the elements in their casting matrix for their blocks.
-Adrian
SaabTuner is offline   Reply With Quote
Old 06-10-2007, 12:32 AM   #58
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Waiting for video. You can never get enough H6 loving.
silver arrow is offline   Reply With Quote
Old 06-12-2007, 11:37 AM   #59
sumfoo1
Member#: 82146
2005 Legacy GT
carbon is to steel
as _____ is to aluminum
SILICONE!
sumfoo1 is offline   Reply With Quote
Old 06-14-2007, 08:12 AM   #60
Legacy_H6TT
Member#: 137502
1990 Legacy GT-t
Blue over silver
Originally Posted by sumfoo1 View Post
carbon is to steel
SILICONE!
Slightly off the topic, but interesting never the less...
Great build Jeff, and awesome to see you photo-documenting it! My report on my (slowly-progressing) build will be online shortly.
Legacy_H6TT is offline   Reply With Quote
Old 06-14-2007, 03:52 PM   #61
sumfoo1
Member#: 82146
2005 Legacy GT
sorry i posted it in the wrong thread i think
someone was talking about the high silica content bmw motors somewhere on here and people were confused why there was silicone in the alloy.
doh!
my fault.
Old 10-02-2007, 05:59 PM   #62
S L O W W R X
Member#: 95109
Any updates on this
S L O W W R X is offline   Reply With Quote
Old 10-06-2007, 06:35 AM   #63
qtr_wrx
Member#: 109567
Waiting for video
qtr_wrx is offline   Reply With Quote
Old 11-21-2007, 08:51 AM   #64
rsuba
Member#: 116129
2002 sti Prodrive
black
Any news or updates??
rsuba is offline   Reply With Quote
Old 11-22-2007, 07:19 AM   #65
SaabTuner
Member#: 67608
carbon is to steel
SILICONE!
Here's the real irony (and sorry for the continued OT): cast iron, ductile iron, white iron, etc ... ALL HAVE MORE CARBON THAN STEEL. I know that makes NO sense, since steel is pure iron + carbon + (multiple alloying elements, like molybdenum) .... but here's a phase diagram for iron and carbon alloying: http://www.sv.vt.edu/classes/MSE2094...es/kimcon.html
Note that anything above 2% carbon, is "cast iron", while less than 2%, which is closer to pure iron, is "steel". Go figure.
Also, Aluminum has MANY varied alloying constituents, silicon being one of the most common, along with copper, and zinc.
edit: p.s. When the right alloying elements are added, steel undergoes a phase change into martensite. While the austenite is shown in the steel portion of that phase diagram, if it were to show the martensite, it would have to note that austenite is "meta-stable" in the martensitic region until well below 0 degrees Fahrenheit. That's why many steels are cryo-treated. The austenite, which has larger grains, and is much less wear resistant, is almost entirely converted to martensite by the extreme cooling as it becomes less and less stable in the martensite region as the temperature drops.
Old 12-13-2007, 05:19 PM   #66
SPPerformance
Member#: 166000
aka xdrian
updates updates please!
SPPerformance is offline   Reply With Quote
Old 12-24-2007, 01:49 AM   #67
nutcase_sammy
Member#: 161262
NEWS PLEASE!!!!!
I plan on doing a similar build but for a VERY different car..........'92 Legacy, total sleeper. have been planning it for some time and should be able to start when I get home from Kuwait. I have spent a lot of time with the guys at Pacific Import Auto gathering info but want as much as I can get before I start the project.
nutcase_sammy is offline   Reply With Quote
Old 12-25-2007, 01:08 AM   #68
Legacy_H6TT
Member#: 137502
1990 Legacy GT-t
Blue over silver
Check out Jeff Perrin's very detailed build up report. May have to do some searching, or it might be on his website still, www.perrinperformance.com.
Also, I have a write up on here as well, http://forums.nasioc.com/forums/show...highlight=twin
Old 01-29-2008, 06:59 PM   #69
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Update:
http://forums.nasioc.com/forums/show....php?t=1437246
Cheers,
Jeff
Also, I have some H6 parts for sale for those looking to do this conversion themselves:
http://forums.nasioc.com/forums/show...7#post21111277
sponaugle is offline   Reply With Quote
Old 02-08-2008, 10:18 AM   #70
R & H Garage
Member#: 139767
Jeff,
From the pictures it looks like all the mains are fed oil from one side and a crossover tube on the bottom supplies oil to the head(via the block) on the other side, is this correct? Do the rods all get fed from their own main? Or are there shared oil passages on the crank like on the 4cylinder engine? Makes me wonder how well these things oil up in the RPM range.
-Dominic
R & H Garage is offline   Reply With Quote
Old 02-13-2008, 01:33 PM   #71
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Originally Posted by KitoAutoSport View Post
Jeff,
-Dominic
I have a block out and in the garage, so I'll snap some good pictures and post them up.
Cheers,
Jeff Sponaugle
Old 04-21-2008, 09:50 AM   #72
dj.rowland
Member#: 177662
2006 WRX STi
WR BLUE
That's what dreams are made of
dj.rowland is offline   Reply With Quote
Old 04-22-2008, 09:42 AM   #73
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
drooling..excuse me while i go to the bathroom..
where did you get your supertech goodies?
Old 05-08-2008, 09:29 PM   #74
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
holy hell, i want your job...whatever your doin, its definitely right...much props, where is that video? im impatiently waiting
2.5rsTurbo is offline   Reply With Quote
Old 05-08-2008, 10:11 PM   #75
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
also. i tried pm'ing you but your inbox is full...since your a swapper, any suggestions on my build? im currently in the middle of the build and small improvements i could make on the way to completing it is more or less what im lookin for...plz take a peak ;]
http://www.rs25.com/forums/showthrea...=78047&page=14
"ej257 shortblock w/ jdm ej20k heads"
It has begun: GC4 EJ22 to EZ30R swap. Slack Subaru Conversions 1584 01-14-2014 04:54 AM
FS: EZ30R H6 Buildup Parts.. sponaugle Engine/Power/Exhaust 4 02-24-2008 06:47 AM
H6 Turbo EZ30R tear down/build up for BE Legacy PHATsuby Subaru Conversions 2 07-04-2005 03:27 AM
Running EZ30R with Hydra? Slack Other Engine Management 16 04-07-2005 05:29 AM
B9X: EZ30R Engine, Price North of $35,000 Jon [in CT] News & Rumors 168 11-20-2004 11:32 AM
