Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Old 12-09-2005, 08:09 PM   #1
Devilchrist
Member#: 24135
2005 CGM 05 STI
3M certified
Default Can we get a "fix those rattles" thread going?
Seems liek there's a Lot of repeated questions of rattles.
So I'll just list what I got from various threads.
SOLVED
1. Steering column rattle - This seems like it's the Cruize control button.
Solution - Take stalk apart, remove button, spring and ball, stretch spring. reinsert. no more rattle
2. Rear window rattle - This seems to be the seat bracket
Solution - Take the reat seat back out. The center latch on the seat rattles against the hook bolt. Put some dynamat or some durable thick rubber on top of the bolt head. *note* i put dynamat, it worked for a few months.. but it wore through.. and started ratteling again.. next will be piece of thick leather.
3. passenger Door rattle - this seems to be wiring rattleing against the inner door panel or the cover. Use some sticky foam and wrap wires..
4. wagon spare tire rattle thanks "sjl1614" for solution
solution - Where the spare tire "cover" sits down and rests of the plastic trim, right under there, the trim sits on metal tabs. Which is the souce of the rattle. use some foam tape on the metal tabs and the noise is gone - sjl1614
5. Drivers side door handle thanks "Flat4 STI"
solution - Drivers side door handle,where you pull the door closed would rattle. 3m double sided tape on the bottom of it where the screw pokes through.
6. Steering column top plastic rattle thanks "Flat4 STI"
Solution - 3M double sided tape,Once you take off the top piece of plastic, nearest the steering wheel theres a piece of plastic that sticks up,I used two layers to touch the column plastic pieceAlso about the middle of the steering plastic piece i put another piece of 3M there also.Kinda hard to descibe.
7. Rear deck area rattle where third brake light is "Flat4 STI"
Solution - center seat belt plastic cover in trunk was loose,the piece that covers the retract part,Silicone around top edge to hold it in place.
8. high pitch rattle behind ear thanks "gh32"
Solution - Very faint metal-on-metal high-pitched noise that took me a while to identify. Turns out it was the zipper on the passenger seat on the top of the pass-through (roughly behind where your neck is). Easily fixed with a piece of tape.
9. glove box key hole
Solution - try using some thick silicone grease? if the problem is within the lock, if its outside then, remove the unit and add 3M windows seal
10. glove box rattle thanks "hank3"
Solution - I had the glove box rattle and what I did was wrap some black electrical tape around the U-shaped bracket the door latch attaches to. That fixed the rattle
UNSOLVED
1. Seatbelt top cover rattle - I put this on unsolved because to me removing outright is not a solution.
2. Driver side A Pillar, Vent cover - put puressure on the vent cover piece by the A-Pillar and rattle stops. -
Things I tried
- siliconing the white clips..
- taping the vent cover piece to the bottom piece..
- strips of fuzzy side of velcro (helped a bit but still there)
- removing the entire vent cover
*edit you can emulate this sound by pushing down on the vent piece. repeat until you have the right speed and pressure.. the only way i see to solve this it to jam some thick cloth to maintain the pressure, or take the dash apart... i have not done this yet...
3. Steering column rattle - left wheel goes over bumps - when only the left front wheel goes over the bumps the whole steering column shutters... I dont' think there's going to be a solution to this..
4. Rearview mirror - if you have warrenty left then it's all good but what if you don't? any one have a fix for this?
anyone else like to add?
Devilchrist is offline   Reply With Quote
Old 12-09-2005, 08:28 PM   #2
Ben Crowson
Member#: 71574
Thank you!!!!!!!! I have tried everything and had all but given up- I will try this and see if its a fix.........I always thought it was where the rear seatbelt ties into the upper panel but after tearing all that out it was still there. I did notice the sound disappeared when two people sat in the rear seat so I took out the rear seat and looked all over for something rattling....I ended up pulling out the plastic box that covers the middle seatbelt tensioner that hangs through the rear deck. This still didnt fix it!
Ben Crowson is offline   Reply With Quote
Old 12-09-2005, 08:32 PM   #3
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
Default Seatbelt Whine/Squeak
Most owners report that the seatbelt squeaks when you use it. It's the belt rubbing against small plastic ribs on the inside of the lower B-pillar trim piece.
Remove the piece and grind down the ribs...no more squeak.
02WHITEDUB is offline   Reply With Quote
Old 12-24-2007, 07:28 PM   #4
don's scoob
Member#: 165010
02 WRX
psm
Sweet! I have had my bug-eye for about a month and that squeak has been driving me bananas. Thanks a lot.
don's scoob is offline   Reply With Quote
Old 12-24-2007, 09:41 PM   #5
hella_sti
Member#: 139289
2003 WRX Wagon
Things I tried
I think to fix this you could cut the solid tube that comes up from the bottom of the dash board and connect the two pieces with a felxable connector. I think that the rattle is fromt he dash moving independantly of the vent and the vent tube (which is rigid hard plastic).
hella_sti is offline   Reply With Quote
Old 02-02-2013, 06:58 PM   #6
learfxr
Member#: 344548
2006 STi
Just picked up a 2006 STI and it has a high pitch squeak when I pull the seat belt out. Thank you so much for this info
learfxr is offline   Reply With Quote
Old 12-12-2005, 01:22 PM   #7
TreeSki
Member#: 58626
The rear window rattle is also caused by the seals around the window expanding/contracting with heat and cold. It happens primarily in the cold when the seals contract and the window is able to move a bit more with chassis flex...unfortunately, there's not a ton that can be done for this other than trying to keep the inside of the vehicle very warm or turning up your stereo more.
Another cause can be suspension upgrades. After a suspension upgrade the chassis is now under more stress as the stiffer upgraded shocks and springs don't react as much as the OEM ones, sending more street impact to the chassis. The chassis flexes, putting more stress on the seals that hold the window in...eventually causing it to rattle. Once again, it's a pain, but can be reduced somewhat by reducing body/chassis flex/roll with larger and stiffer sway bars and, to some degree, strut tower bars.
TreeSki is offline   Reply With Quote
Old 12-12-2005, 05:31 PM   #8
Zrex11
Member#: 94881
1989 Hoopty Stylez
Road Slipper
My rear view mirror rattles like a mofo also, so the dealership will replace that eh, im doubtful i will be able to get them to fix it, but hey worth a shot like you guys said its annoying as hell holding to mirror to stop it from rattling
Zrex11 is offline   Reply With Quote
Old 12-13-2005, 03:38 PM   #9
CyberVlad
Member#: 42985
2008 STI (BBS/Navi)
Anybody got a fix for rear view mirror (w/compass) rattle?
CyberVlad is offline   Reply With Quote
Old 12-13-2005, 04:52 PM   #10
wrxtreme2
Member#: 71896
Ditto !, its driving me nuts
wrxtreme2 is offline   Reply With Quote
Old 12-16-2005, 11:18 PM   #11
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
if the rattle is coming from where it attaches to the windshield, you need to either replace the u-spring, or remove the mirror and bend yours closed a bit then re-install the mirror.
DrD is offline   Reply With Quote
Old 12-13-2005, 02:06 PM   #12
Ben Crowson
Member#: 71574
Thanks for the info- this must be what it is because it seemed to start after I upgrades springs and struts. I have removed just about everthing in the rear of the car or tied it down- from the gas cap to the trunk tensioning system and nothing has helped! I have removed seatbelts and every trim peice and its still there so I chalked it up to something with the rear strut assembly or now I guess it could be the window rattle.
Old 01-17-2008, 10:39 PM   #13
GibsnSG
Member#: 143687
07 WRX TR
sand
yeah, i have this rattle and it annoys the living **** out of me. but oh well, i guess i have to wait till its warm again. until then, i'll bump my system hard and set off car alarms while i drive by
GibsnSG is offline   Reply With Quote
Old 01-03-2008, 09:14 AM   #14
rickr01
Member#: 149523
Does this apply to wagons also??
rickr01 is offline   Reply With Quote
Old 12-09-2005, 08:30 PM   #15
SXti
Member#: 73692
2011 Forester XT
Spark Silver
that steering shudder going over bumps, im glad to see im not the only one with that problem
SXti is offline   Reply With Quote
Old 08-10-2019, 01:00 AM   #16
BeAboveAverage
Member#: 505128
Hello everyone, this is my first time posting on here and I apologize if this is the incorrect forum or place to be putting this. I just recently got a 2018 sti and every time Iím in 1st or second gear and start accelerating WOT after about 3k RPMs I hear this really loud rattle sound. It sounds like itís somewhere under the car towards the back or center. Very hard to pinpoint it. I canít replicate the rattle in any other gear besides 1 and 2. Please help 😭 Its freaking me out
BeAboveAverage is offline   Reply With Quote
Old 08-12-2019, 08:38 AM   #17
Pantyraider
Member#: 178062
2017 STI Limited
CWP
Toss your phone back there and get a video/audio of it. Might help find it. Put your rear seats down, too - see if they are involved in the noise making
Pantyraider is offline   Reply With Quote
Old 08-13-2019, 09:50 AM   #18
2016WRX_CT
Member#: 504527
2016 Subaru WRX
I get heat shield and/or drivetrain rattle like this anytime i'm over 3500 rpm. Especially noticeable if I'm slowly rising into that range rather then WOT.
2016WRX_CT is offline   Reply With Quote
Old 12-09-2005, 09:02 PM   #19
suren27
Member#: 67464
05 Stock what?
Too Low #009
Im gonna try the rear window rattle cuz wow that pisses me off so much..
And for the vent rattle... press down a bit and it stops... have no clue i think its the clips in the a pillar... but cant really guarantee that is the sure fix for it.
suren27 is offline   Reply With Quote
Old 12-09-2005, 09:09 PM   #20
05WRXwagon
Member#: 78550
2005 WRX wagon 5 spd
My wagon rattles in the back some where. I thought it was the venetian blind luggage cover and/or some bungie cords on top of the spare. I took them both out and it still rattles. Sounds like it is coming from the spare tire area, but everything seems to be tight there.
Any ideas?
05WRXwagon is offline   Reply With Quote
Old 12-12-2005, 07:10 AM   #21
sjl1614
Member#: 56791
06 OBS
Any ideas?
I had this rattle for a long time also. FIXED IT!!! Where the spare tire "cover" sits down and rests of the plastic trim, right under there, the trim sits on metal tabs. Which is the souce of the rattle. I used some foam tape on the metal tabs and the noise is gone!!
http://tinypic.com/ighz7s.jpg
http://tinypic.com/ighzbk.jpg
sjl1614 is offline   Reply With Quote
Old 05-14-2007, 06:30 PM   #22
WickedGrip
Member#: 143151
2007 wrx
wrb
wow, totally speechless super useful thread
WickedGrip is offline   Reply With Quote
Old 02-08-2011, 12:13 PM   #23
carcassxd
Member#: 267468
2016 STI
BLACK
I've got a little rattle/buzz issue with my 2011 wrx hatch. Maybe someone can help. It's definitely coming from the passenger side and its more of a buzz then rattle. Not too loud but it's annoying. It almost sounds like it's coming from underneath the glovebox. I tried emptying out the box and ride with it open, same thing. More noticeable over bumps and rough road. I cant totally rule out the passenger door though, maybe its coming from there. Hard to tell in the car by yourself. I've only got 1700 miles but would like to avoid the dealer as they trashed the last car I brought them.
carcassxd is offline   Reply With Quote
Old 02-14-2011, 04:45 PM   #24
nobletea
Member#: 169623
2008 2.5i 5d 100k+
Dark Grey Metallic
You got a center console armrest extension?
nobletea is offline   Reply With Quote
Old 04-11-2011, 04:20 PM   #25
WR20X
Member#: 258187
2010 WRX Sedan
WR Blue
08+ wrx need to find a way to stop the windshield wipers from clicking every time the wipe.
WR20X is offline   Reply With Quote
SF5 forester thread doublej Member's Car Gallery 20 07-26-2012 01:30 PM
Can We Get a DIY Thread Going? STIckySTIfee General Community 17 04-03-2008 12:00 PM
Can we get another ice thread going? forced4 Texas Impreza Club Forum -- TXIC 0 01-17-2007 11:41 AM
Can we get an OT sing-a-long going? BEGIN! snvin Off-Topic 27 12-01-2005 01:15 PM
