Welcome to the North American Subaru Impreza Owners Club Friday October 18, 2019
Old 05-31-2019, 05:13 PM   #1326
Cab0oze
Member#: 443914
2015 WRX
Originally Posted by mrco555 View Post
Tried the speaker grill fix but it didn't help. The creaking noise sounds like it is where the firewall and dashboard connect. Here is a video of the noise:
https://youtu.be/uPucLG8qCgo
Good video, but impossible to tell where it's coming from. Lucky for you, it's pretty regular. Try holding the A-Pillar trim and gauge cluster trim one at a time to see if that stops the sound.
Cab0oze is offline   Reply With Quote
Old 05-31-2019, 05:40 PM   #1327
mrco555
Member#: 252184
Tried both, didn't help. The passenger side does it too. Seems to be worse with higher temperatures outside.
mrco555 is offline   Reply With Quote
Old 05-31-2019, 05:55 PM   #1328
Cab0oze
Member#: 443914
2015 WRX
Well... I'm out of ideas. Try pressing on everything lol
My trim around the radio made ticking noises as well when it was hot out, so make sure to try pressing on that too.
Old 06-02-2019, 01:32 PM   #1329
ImprezaRS dot com
over boosted again
Member#: 1458
2017 WRX Limited
2015 Forester XT, Tribeca
Hmmm, still makes me think of the speaker grill. Iím at a loss otherwise, but you could check any wires inside the grill that are loose, or something else loose in there.
ImprezaRS dot com is offline   Reply With Quote
Old 06-02-2019, 01:43 PM   #1330
ImprezaRS dot com
over boosted again
Member#: 1458
2017 WRX Limited
This reminds me that I have a rattle coming from a place different from where the cause is, because of the sound reflections in the car off the hard surfaces.
When I would turn up the bass on my 2x 10Ē subs, Iíd hear a rattle coming from the right side of my car, making me think it was the right front or rear passenger door. But after applying dynamat to the inside panel and inside of the outer metal door on all 4 doors it continued.
Then I thought, maybe itís a switch in the right door, but pressing and holding down the switches had no effect. And my son thought it was coming from the left side when I asked him to help me.
So my son and I started to press and hold on different things and it turns out to be the roof liner panel just rear-ward of the star link. Now I have to decide how I want to approach the issue.
Old 07-17-2019, 09:41 AM   #1331
Pantyraider
Member#: 178062
2017 STI Limited
CWP
Finally fixed my passenger door rattles. I was getting some from near the switches and also from the bottom by the speaker. When there were certain low frequencies coming from the speaker it would rattle the door car. It's been about a week and a half and everything is still silent.
2017 STI door card rattle, rear seat rattle - in case someone is searching
Here's what I did:
Lots of this tape - it's like a fabric tape that can be used in place of electrical tape
https://www.amazon.com/Tesa-Wire-Loo.../dp/B00EH6IZ6Y
I placed some on the back of every door car clip and folded it over the edges so that every part of the clip that rubs against the card or the door was covered
Then I covered the edge of the speaker outline with the tape, too
And finally I taped the **** out of the switches so they couldn't wiggle around anymore. There was a lot of play in them before
So far so good on this fix.
I also had a squeak/rub noise coming from the back seat. The driver's side rear seat back was rubbing in the top corner - so I dropped the seat back and then took a microfiber towel and shoved it in the top corner near the door and then closed it. That seems to have resolved that noise, too.
Pantyraider is offline   Reply With Quote
Old 08-10-2019, 01:00 AM   #1332
BeAboveAverage
Member#: 505128
Hello everyone, this is my first time posting on here and I apologize if this is the incorrect forum or place to be putting this. I just recently got a 2018 sti and every time Iím in 1st or second gear and start accelerating WOT after about 3k RPMs I hear this really loud rattle sound. It sounds like itís somewhere under the car towards the back or center. Very hard to pinpoint it. I canít replicate the rattle in any other gear besides 1 and 2. Please help 😭 Its freaking me out
BeAboveAverage is offline   Reply With Quote
Old 08-12-2019, 08:38 AM   #1333
Pantyraider
Member#: 178062
2017 STI Limited
CWP
Toss your phone back there and get a video/audio of it. Might help find it. Put your rear seats down, too - see if they are involved in the noise making
Old 08-13-2019, 09:50 AM   #1334
2016WRX_CT
Member#: 504527
2016 Subaru WRX
I get heat shield and/or drivetrain rattle like this anytime i'm over 3500 rpm. Especially noticeable if I'm slowly rising into that range rather then WOT.
2016WRX_CT is offline   Reply With Quote
SF5 forester thread doublej Member's Car Gallery 20 07-26-2012 01:30 PM
Can We Get a DIY Thread Going? STIckySTIfee General Community 17 04-03-2008 12:00 PM
Can we get another ice thread going? forced4 Texas Impreza Club Forum -- TXIC 0 01-17-2007 11:41 AM
Can we get an OT sing-a-long going? BEGIN! snvin Off-Topic 27 12-01-2005 01:15 PM
