Welcome to the North American Subaru Impreza Owners Club Thursday October 18, 2018
Old 11-13-2002, 12:15 PM   #1
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Default What do you think about running a UniChip and a S-AFC together?
Currently, I will be having a UniChip mapped for STG4.
Right now, I am only running a S-AFC - Which is why i bought some kind of engine management.
(I put down some terrible numbers with the S-AFC only and too much timing was being pulled.)
My question is, would it be ok to run both units together?
I am going to have the car dynoed with the UniChip, and then use the S-AFC to "fine" tune the car.
Any pros/cons to this? Or do you think I should just sell the S-AFC? Thanks!
Need4Boost is offline   Reply With Quote
Old 11-13-2002, 12:30 PM   #2
jmott
Member#: 6713
2007 Prius
brown
Default Re: What do you think about running a UniChip and a S-AFC together?
you would end up using the unichip for timing only, and SAFC for fuel.
this would allow you to mess with the air/fuel ratio on your own, but not the timing.
there could be some weird issues using both together. Unless being able to fiddle with the air fuel ratio yourself is of great importance to you, Id sell the SAFC
jmott is offline   Reply With Quote
Old 11-13-2002, 12:48 PM   #3
NotoriousWRX
Member#: 9026
IMO, you have to go with one or the other. The chip will alter the timing to what the tuner feels it should be, but when you change the AF, you will then cause the timing to be altered from what that tuner intended. The results would not be optimal in any sense and could actually be downright dangerous.
I know that you weren't happy with your dyno results, but you have to realize that they were not really that bad, given the entire set of circumstances under which your car was tuned that day.
NotoriousWRX is offline   Reply With Quote
Old 11-13-2002, 01:01 PM   #4
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Thanks guys!
Looks like i will be selling the S-AFC soon.
Old 11-13-2002, 01:17 PM   #5
norseone
Member#: 16350
2015 M3
1971 521
Default SAFC
I was told that people use the SAFC to lean out the car(WRX) which inturn advances the timing. Which then inturn equals bad news.
Does anyone know anything about this? Whether I shoud even use the SAFC on my car. My mods are VF23, TXS turboback, K&N, Profec-B, among other things and now a SAFC. But I am hesitant to put it on because of what I have been told about it. Is there any truth to this? Any help would be appreciated.
TIA
-NORSE
norseone is offline   Reply With Quote
Old 11-13-2002, 01:52 PM   #6
NotoriousWRX
Member#: 9026
If tuned properly, an SAFC can yield good results.
Old 11-13-2002, 02:38 PM   #7
norseone
Member#: 16350
2015 M3
1971 521
No engine management besides SAFC? Any help would be appreciated. My local tuner basically said they will not install one on a WRX. Because of the fact that it advances the timing so much.
TIA
-NORSE
Old 11-13-2002, 02:40 PM   #8
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Has proved what a properly tuned S-AFC can do. I think you should post some dyno charts.
Old 11-13-2002, 04:26 PM   #9
Z1 Performance
Member#: 9327
Agreed...you MUST know what you are doing. The SAFC only affects timing too greatly if you let it..use it for incremental changes, and it does wonders...we have several 13 and 12 second customer cars with just a SAFC...
Adam
www.z1auto.com
Z1 Performance is offline   Reply With Quote
Old 11-13-2002, 04:45 PM   #10
DJWRX
Member#: 10340
I ran with a guy who was running both this weekend. He had a turboback, Vishnu stage 1 and an intake. It seemed redundent to me...
Tim
DJWRX is offline   Reply With Quote
Old 11-13-2002, 06:53 PM   #11
NotoriousWRX
Member#: 9026
I have no other engine management. Just an SAFC.
Like Adam wrote, the SAFC will affect timing, but that can be controlled to an extent. You will not have the same level of control as a standalone or chip, because of limitations in resolution. The SAFC has a lot less adjustment points.
I think that any car can produce higher, smoother power using a fully programable EMS, but an SAFC is a good and viable option for those of us that choose to use it. There are other people on here that are making good power and are only using an SAFC as their form of engine management. You just have to understand that there are limitations to what you can do, based on the rest of your entire setup and the SAFC.
Old 11-13-2002, 07:01 PM   #12
norseone
Member#: 16350
2015 M3
1971 521
Adam
www.z1auto.com
Thanks Adam. It kind of shocked me when the guy said that he would not install it because what it would do to my car. But I know there a lot of people running it here.
I just called them and talked to the other owner and he said no problem. They would install it. Go figure.
So with the VF23, full exhaust, profec-B, and the SAFC I should golden. Should be right around my target HP.
--NORSE
PS Does anyone have any baseline information for the WRX and SAFC?
Old 11-13-2002, 08:58 PM   #13
NotoriousWRX
Member#: 9026
There are no baseline settings for the SAFC. They will vary from car to car, even if the cars have the same exact mods. Tuning should only be done by someone who knows what they're doing while using the appropriate monitoring tools.
I suggest that you post in your regional forum to see what tuner(s) other people in your area have used successfully. Good luck.
Old 11-13-2002, 10:17 PM   #14
Jon [in CT]
Member#: 2992
02 WRX Sedan
I suspect you've already met your fair share of Cons in Jersey (especially if you've shaken hands with a politician ). Why not consult a pro in New Jersey, www.rallispec.com?
Jon [in CT] is offline   Reply With Quote
Old 11-14-2002, 01:30 AM   #15
norseone
Member#: 16350
2015 M3
1971 521
Yeah I hear that but THE tuner here in Salt lake is the one that said that he would not install it. Oh man this is weak.
Thanks though.
NORSE
Old 11-14-2002, 08:54 AM   #16
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Default Re: Re: What do you think about running a UniChip and a S-AFC together?
Please don't remind me. Ugh..
I e-mailed Rallispec and we shall see how that goes. Thanks for the heads up! I forgot about them too.
What do you think of running this lean? akira02rex Commercial ECU Reflashes 18 11-13-2006 09:16 AM
What to go with a crazy set up!!!!!!! What do you think about this. siliversti06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 07-21-2006 06:03 PM
What do you tip and what do you think about it? sonicsuby Off-Topic 58 10-29-2003 06:16 PM
what do you think ill run? NateDogg Normally Aspirated Powertrain 18 09-17-2001 03:59 AM
what do you think about these rims??? pics!! shinestreetBen Bay Area Impreza Club Forum -- BAIC 3 11-22-2000 04:52 PM
