Welcome to the North American Subaru Impreza Owners Club Tuesday October 16, 2018
Old 10-16-2004, 10:50 PM   #1
Robin2
Member#: 390
2018 WRX sedan
Dark Grey
Default Coolant leak from water pump (99RS)?
Can anyone confirm this from this pic.....
My friend in NH is looking at this used 99RS.... I have also a 99RS but haven't had this problem.....
Is this a coolant leak from the water pump as it failed (on the seal)?
Tks
Robin
Robin2 is offline   Reply With Quote
Old 10-17-2004, 09:39 AM   #2
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
It definitely has a leak in the water pump/thermostat housing area. What stumps me is that there is coolant all the way on the other side of the oil pump. Do you see coolant any further north than the area in picture (e.g. around the exhaust manifold)?
How many miles are on the car? Maybe someone botched a water pump install and the bolts worked loose or didn't install the seal properly.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 10-17-2004, 11:05 PM   #3
Foz
Member#: 1776
2000 2.5RS
BRP
Tks
Robin
Hey Robin,
Definately doesn't look good. I was losing coolant slowly due to a leak in my water pump as well. Didn't look that messy though as I couldn't even find any leakage. I was lucky to have it done before my 5 year warranty expired this week as it's a pretty pricey repair. If it is the water pump, try to get them to replace the timing belt while they're at it (I didn't know this until searching the forums after my water pump was replaced).
Good luck.
Foz is offline   Reply With Quote
Old 10-18-2004, 11:25 AM   #4
Robin2
Member#: 390
2018 WRX sedan
Dark Grey
Tks.....
I received this from subaru friend.... it seems it the thermostat....
"I got this leak before, and all I had to do was replace the thermostat and gasket around the thermostat.
The plastic inlet has a lip on it that prevents it from being tightened over the thermostat. After a few years the rubber gasket around the thermostat dries out and the water inlet / thermostat housing starts to rock."
Robin
FS (PA) Coolant crossover pipe, water pump, ac compressor [email protected] Engine/Power/Exhaust 4 08-03-2011 02:39 AM
Coolant leak, maybe water pump? KanosWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-12-2007 10:06 PM
Leak at Water Pump Gasket ITWRX4ME Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-21-2006 09:58 PM
where does my coolant leak from? haszlan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-31-2003 05:40 AM
coolant leak, from near thermo(pics) biggreen96 Normally Aspirated Powertrain 26 06-21-2003 01:53 PM
