Welcome to the North American Subaru Impreza Owners Club Sunday April 22, 2018
Old 04-17-2018, 12:18 AM   #1
kctqnoah
Member#: 411461
2004 Subaru WRX
Default 04 WRX Overheating Concern?
Hey all! I was hoping somebody could give me some peace of mind here. Im assuming I am fine but I tend to over think things and would like a second opinion. All is appreciated!
So a week ago I was driving my 04 wrx to my buddies house when I started to notice a little white smoke up front at a stop sign. I didnt think too much of it but I was keeping an eye on my coolant gauge. I should also clarify first I live in NH and it was about 25 degrees this day. Well after about another minute of driving I notice the coolant temp starting to slowly go up. My buddies street was probably another 1/4 mile down the road so I decided to wait to get to hit road to pull over as I was on a pretty busy main road.
When im approaching his road my temp gauge is just starting to get out of its normal marked zone, however his road is very steep at the start and when I went up the incline my temp gauge started climbing FAST. This freaked me out and I pulled over before it got too high but the gauge probably got about 3/4 of the way up. For sure not in the red zone but a little bit under it. Im not sure if being low/empty on coolant caused the thermostat to freak out when I went up the incline? If someone could clarify that it would be appreciated
Opened my hood and there was coolant pissed all over my engine, to which my friend and I believe is a crack in the stock radiator (car has 160k on body). I let the car cool back down for about 30-40 mins, but since I was on a steep incline on this road and needed AAA to tow my car I needed to get back out onto this main road. I coasted to the bottom of the hill and started to drive the car again driving slow at 15mph watching the gauge, got about 1/2 a mile before the gauge started to rise again out of its normal zone and thats when I pulled over for good and called AAA.
I guess my question is do you think I could have ****ed up my heads/head gasket/engine components or damaged other things from this? The gauge did not reach into the red zone although it got pretty high to about 3/4 of the way up. I checked the coolant fill points in both reservoirs the next day and they were both pretty much completely dry. Im worried that I may have damaged something from driving it back onto the main road after noticing the leak, because I probably had little to no coolant in the system. I did start the car up for just a second and the engine sounded normal as it always does, although I doubt you could tell anything by noise. Car is in good shape otherwise, had heads resurfaced/valve job and headgaskets at 100k. Would appreciate some opinions on this. Sorry for my rant! Cheers
kctqnoah is offline   Reply With Quote
Old 04-17-2018, 12:47 PM   #2
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Fix the issue and see if you lose coolant. How much did you need to add? The temperature sensor is the highest point in the system (or pretty close to it), it will overheat LONG before the engine is in serious trouble.
Could you have damaged something? Sure. Everyone on here will be guessing if they tell you that you did, or did not cause damage, however.
mrsaturn7085 is offline   Reply With Quote
Old 04-17-2018, 02:06 PM   #3
berge56
Member#: 56754
2004 Hybrid 2.5XTR
RIP [email protected]
What they said ^.
Replace the radiator, burp the cooling system and see if you lose coolant or overheat.
My guess is that you are fine.
berge56 is offline   Reply With Quote
Old 04-17-2018, 06:57 PM   #4
kctqnoah
Member#: 411461
2004 Subaru WRX
Thank you for the info. I'm gonna be replacing the radiator with a Koyo and replacing some of the smaller coolant lines. When you say the sensor will overheat before the engine is in serious harm, are you talking about the temp gauge rising in the car? Will the sensor itself be damaged from reading that high of a temp out of its normal range?
Old 04-17-2018, 07:07 PM   #5
White_Wagon_
Member#: 457564
2006 Wrx Wagon
I think you should be fine as long as you didnít do any kind of serious driving or pulls without coolant. I had a cracked radiator once and i ran into that problem you did going up hill. Nothing serious though as the guage rose above normal temps for about 30secs or so. So I think you should be good. But as the others said, replace the radiator burp the system and see from there. Also I would replace the thermostat just for safe measure. Just a couple more dollars with the gasket wonít hurt.
White_Wagon_ is online now   Reply With Quote
Old 04-17-2018, 07:10 PM   #6
mrsaturn7085
Member#: 375462
WR Blue
I'd recommend the Koyo stock replacement rather than the aluminum one. Regardless of whether you have a 5MT or 4AT, buy the auto transmission version. You'll have an extra pre-plumbed cooling circuit at the bottom of the radiator that you can cap off if you don't use it, but if you need it for anything, it'll be right there for you.
The sensor will not be damaged - once the coolant falls below the level of the sensor, the sensor is reading the temperature of the steam above the coolant level. This is why the needle moves so fast in the car when you overheat - when you're reading the temperature of a gas rather than a liquid, the temperature quickly spikes.
Old 04-17-2018, 07:22 PM   #7
kctqnoah
Member#: 411461
2004 Subaru WRX
Great thank you for clarifying Why would you recommend the Koyo OEM replacement vs the aluminum? Ive had people tell me the aluminum is much better and that the Koyo OEM replacement will still crack eventually because of the design. Granted my car is still mostly stock, td04 with turbo back, fuel pump, intake, pro tune
Old 04-17-2018, 07:27 PM   #8
kctqnoah
Member#: 411461
2004 Subaru WRX
Definitely no pulls or anything while this happened. This is good to hear, I appreciate the insight!
Old 04-20-2018, 12:18 AM   #9
subaru_gc8
Member#: 29292
2004 WRX wagon
why do you think its a crack in the radiator, usually come uncrimped. especially whey you start to push more power
