Welcome to the North American Subaru Impreza Owners Club Sunday May 31, 2020
Old 03-11-2020, 05:17 PM   #1
gt58
Member#: 483720
2004 sti
jbp
Default 2004 STI Fuel Pressure Regulator Install HELP!
tried searching with no avail.
Does anybody have a good writeup/DIY or video for FPR install/replacement. pretty sure this is only for side feed style fuel system...
Using OEM part 22670AA351
Thanks in advance!!
gt58 is offline   Reply With Quote
Old 04-28-2020, 10:03 AM   #2
gt58
Member#: 483720
2004 sti
jbp
anyone?
Old 04-28-2020, 03:38 PM   #3
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Here is a youtube link for a 2002 wrx, dont know if it will help. Just take out you rear seat, disconnect the hoses from the fuel pump and replace it. Its easier then you think. Also added a how to Install 04-07 STI Fuel Pressure Regulator from Legacygt.cum
https://legacygt.com/forums/showthre...se-263825.html
Removed useless video.
Old 04-28-2020, 06:14 PM   #4
danger1138
Member#: 279525
06 Fxt
I think for 04 sti, the fuel pressure regulator is by cylinder 1 injector. Close to turbo inlet.
danger1138 is offline   Reply With Quote
Old 04-29-2020, 09:25 AM   #5
BlackFighter
Member#: 193940
2004 WRX STI Black
https://www.subarupartsdeal.com/part...2670aa351.html
You know what, you might be right. I was thinking of the Fuel Pressure Damper Regulator, there are two on the the right side. Looking at the diagram yes the fuel pressure regulator is on the passenger side. Sorry for the fake news.
Old 04-29-2020, 03:36 PM   #6
BoostedBlobEye
Member#: 504010
2004 STI
I believe it's bolted to the underside of the intake manifold passenger side.
BoostedBlobEye is offline   Reply With Quote
Old 04-29-2020, 04:02 PM   #7
BlackFighter
Member#: 193940
2004 WRX STI Black
Yap it is, you can see that in the pictures of this fuel thread of a 2004 STi manifold and the fuel lines.
https://forums.nasioc.com/forums/sho....php?t=1462667
Old 05-03-2020, 10:44 AM   #8
gt58
Member#: 483720
2004 sti
jbp
Thank you guys!
Still on the hunt for a good diy video
Old 05-03-2020, 02:04 PM   #9
awnetve
Member#: 464787
2005 STi
Fuel pressure regulator is on the driver side on 04-05 sti. These models are side feed.
If you have your top mount intercooler, then it's under, close to the starter.
Once you find it, you'll see it's pretty easy, just remove the hoses (mark them or take a pic before), then remove bolt from bracket to release the FPR, then replace for the new one and revert steps.
awnetve is offline   Reply With Quote
Old 05-04-2020, 03:33 PM   #10
gt58
Member#: 483720
2004 sti
jbp
does the intake manifold have to come off to remove the FPR??
Old 05-05-2020, 09:44 AM   #11
BlackFighter
Member#: 193940
2004 WRX STI Black
If you look at the pics in this thread, yes it looks like the best/easiest way would be to remove your intake mani.
Old 05-05-2020, 01:08 PM   #12
gt58
Member#: 483720
2004 sti
jbp
thanks for that link!
Old 05-18-2020, 04:21 PM   #13
Blackbox
Member#: 68457
02 wrx
black
I just replaced mine a couple of months ago. Removing the intake manifold was the only remotely practical way of getting to the fuel pressure regulator.
Blackbox is offline   Reply With Quote
Old 05-19-2020, 04:53 PM   #14
gt58
Member#: 483720
2004 sti
jbp
how did the install go? any hoses break etc etc?
