Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2020
Old 10-18-2008, 02:15 PM   #1
neko
Member#: 46500
So many I can't
remember anymore.
Default STi TMIC size/specs comparo. (I.E. is the 08 an upgrade?)
So i'm a big fan of keeping my car tmic. I'm also a big fan of the oem style tmics, i think they're better than the ginormous, and hard to fit in your car, aftmerket ebay TMICs.
So, now out comes the 08 STi tmic, and i look at it and go "wow, that looks wider than mine..."
For reference, i run a v7 STi TMIC currently.
What i need is some hard facts, some core measurements at least to compare to to other STi models. Also, when it comes to width, it seems the vertical rows are evenly spaced on all factory tmic's, wrx or sti. So counting them helps. I know those already. Also, seem to be almost identical in interior construction, so for now we'll assume they have about the same flow restrictions.
For comparison, the WRX TMIC data:
Rows: 30
Core dimensions: 16.5 x 6 x 3
Total cubic core space: 297ci
Option #1: USDM STi TMIC.
Rows: 34
core diemnsions: 18.5 x 6.625 x 3 (confirmed)
Total cubic core space: 368ci
Option #2: JDM V7 TMIC
Rows: 34
core dimensions: 18.5 x 7.25 x 3 (confirmed)
Total cubic core space: 402ci (9.2% increase over USDM 04-07 STi core)
Option #3: USDM 08 STI TMIC
Rows: 38
core dimensions: 20.75 x 6.85 x 3 (confirmed)
Total cubic core space: 426ci (for a 15.7% increase over USDM 04-07 STi core)
Of course, to take full advantage of the certain larger ic's, you must have a splitter that fits them fully, but thats another issue, and easily taken care of.
Ok, ladies and gents. we now have all our answers. The math is above. The numbers don't lie (as long as i was well informed. feel free to check n prove me wrong). Turns out the new 08 core is the biggest when it comes to overall core dimensions. Which is really the best performer? no clue. I don't exactly have the means to test that. But i can compare sizes and go off that. Of course, i'm also still assuming subaru continued to use the same 3" thick core for all its IC's. Never seen any evidence to the contrary of that.
Will i upgrade to the 08 core? maybe. it does offer more core space, but does sit further over the turbo. My IC already gets warm on the pass side quick when sitting.
neko is offline   Reply With Quote
Old 10-18-2008, 03:55 PM   #2
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
I just installed a Perrin FMIC Kit, I can tell you it hauls azz to redline! The temperature difference is just too great for me to go back to OEM.
The 08-09WRX's doesn't have the same setup as the old WRX's or the new STi's. The bypass valve is plastic and isn't directly bolted onto the intercooler correct?
tux121 is offline   Reply With Quote
Old 10-18-2008, 04:58 PM   #3
neko
Member#: 46500
So many I can't
remember anymore.
correct, the new "wrx" setup is different. i think the STi tmic's can be made to work, but its not as nearly bolt-on as the older ones. So i'll ignore those for simplicity.
However, the New STi's use the same layout as the previous GC/GD setups.
Old 10-18-2008, 05:05 PM   #4
unclemat
Member#: 114530
2005 LGT 6MT wagon
No, it absolutely cannot be made to work without swapping the sti intake manifold.
I also read 08 sti tmic is only 3.6% larger than previous ones.
unclemat is offline   Reply With Quote
Old 10-19-2008, 10:13 AM   #5
neko
Member#: 46500
So many I can't
remember anymore.
oh, ok, so STi only usage. works for me either way, its not like i have an 08 car or anything
Also, randomly stated facts (3.6%) floating around the board don't count in my post, i gotta see numbers. Unabombers post for instance has measurements, but there's some errors. (like the v7 is not 4" thick, and the width on most of them are off. they measured more than the core)
Basically, i'm thinking either the new 08 STi core is the same height as the older usdm one, just wider, or else its wider and longer in height as well. Depending on which one, it could be bigger than the v7 internally, or about the same. It's already an upgrade over the 04-07 USDM's, thats pretty much determined.
However, i did measure my v7 core last night. 18.5 x 7.25 x 3. Its tough to get a thickness measurement, but AFAIK, all the cores are the same thickness, so we're really only concerned with two dimensions. However, i'll try to confirm that hypothesis as well.
Here's proof on the height. (the only dimension that varies between usdm and V7)
Old 10-19-2008, 10:19 AM   #6
neko
Member#: 46500
So many I can't
remember anymore.
also, my new math effort is that 18.5" includes 34 vertical rows on the V7 core. If i break that down its approx .544" per row. That makes the WRX core 16.3" wide(which agrees with unabombers figures), and the new 08 about 20.6" wide. We'll list those for now, pending visual confirmation.
Old 10-19-2008, 06:12 PM   #7
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
The new WRX intake manifolds are plastic? Aren't those things under pressure? Alot of boost pressure?
Old 10-19-2008, 06:27 PM   #8
unclemat
Member#: 114530
2005 LGT 6MT wagon
They are. LGT has had the plastic manifold since the begining. It's actually better design than STI and withstands high boost without problem. People run big turbos with it and it's actually popular mod for rotated setup as it places the throttle body in better spot for fmic piping.
Old 10-19-2008, 10:17 PM   #9
TRooper
Member#: 62422
2006 Lotus Elise-
1.8L of Fury!!
This is false. Nasioc member "Its_just_yukio" ran an 08 STi TMIC on his 03 wagon at Subiefest3. He has a stock intake manifold and cable driven throttle body.
TRooper is offline   Reply With Quote
Old 10-19-2008, 10:27 PM   #10
unclemat
Member#: 114530
2005 LGT 6MT wagon
Read above again. This was about 08+ WRX/05+ LGT plastic intake manifold that cannot work with STI/pre-08 WRX style manifold.
Old 10-19-2008, 10:39 PM   #11
TRooper
Member#: 62422
2006 Lotus Elise-
1.8L of Fury!!
Read above what your asking me to read above. The OP has an 04STi. If you were replying to a post that was a bit off topic, you should of quoted it. Otherwise, we are to assume you were referring to the OP.
Old 10-19-2008, 11:48 PM   #12
Clark_Kent
Member#: 114299
Where did you "read' this?
Clark_Kent is offline   Reply With Quote
Old 10-19-2008, 11:56 PM   #13
unclemat
Member#: 114530
2005 LGT 6MT wagon
I "read" this here:
http://forums.nasioc.com/forums/show...9&postcount=38
Old 10-19-2008, 11:57 PM   #14
unclemat
Member#: 114530
2005 LGT 6MT wagon
It's possible that the comparision above is to jdm tmic, so the difference wrt USDM 04-07 sti tmic might be larger like the OP stated.
Even if it's 10% larger, tools pay 50% more for it...
Old 10-20-2008, 11:27 AM   #15
neko
Member#: 46500
So many I can't
remember anymore.
however, the "outgoing" model in japan is the same size core as our usdm IC's. The V7 is still bigger than that. So this kinda makes me think it sits in between. Slightly larger than the USDM, shorter n wider overall. Still smaller than the V7 internally, tho not by a lot either. The other advantage is that the previous models don't hang over the turbo as much as the new one does. interesting for sure either way. I'll be measuring a stock usdm if i can get a chance today perhaps, with pics. Then i just need to find an 08...
And yes, even tho fitment in various models was not on my list of things to determine in this thread, i think we've straightened it out. All these discussed IC's can be used very easily on 04+ STi's, and 02-07 WRX's. (also probably most GC-chassis turbo drivelines). Sorry you 08+WRX owners. out of luck...
Old 11-03-2008, 06:13 PM   #16
neko
Member#: 46500
So many I can't
remember anymore.
confirmation on USDM core dimensions. 18.5 x 6.625 x 3.
368ci core.
new math listed in entries on 1st post.
Now i just need 08+ core dimensions.
Old 11-05-2008, 12:55 PM   #17
neko
Member#: 46500
So many I can't
remember anymore.
bump, any one with 08 sti core dimensions?
Old 11-05-2008, 01:21 PM   #18
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
My 08 STI TMIC is 20.75" x 6.85"
Jeff Sponaugle
Surgeline Tuning
sponaugle is offline   Reply With Quote
Old 11-05-2008, 01:56 PM   #19
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Also, here are some part numbers to add to your list:
Code:
TMIC Part Number      Model
21820AA252            US STI 04-07
21820AA380            US STI 08
21820AA175            JDM Version 7
21820AA270            JDM Version 8/9
21820AA260            JDM Version 10
21820AA175            EU 2002 EJ207
21820AA270            EU 2003-2005 EJ207
21820AA252            EU 2006-2007 EJ207
Jeff Sponaugle
Old 11-05-2008, 11:31 PM   #20
neko
Member#: 46500
So many I can't
remember anymore.
oh good. thanks for the numbers Jeff. That should finally round out the questions here... fixed the info up top.
Old 11-11-2008, 10:50 AM   #21
Mighty E
Member#: 152553
2005 05 STI-Dom3
2006 B9 Tribeca Ltd.
Stock TMIC dimensions are correct in post #1
I just picked up an APS TMIC and the dimensions are as follows;
7.5 x 20.125 x 4.375
yielding 660 cid (56% more volume than the STi TMIC)
29 rows not counting the two outer-most as i cannot verify if they're functional or not (assuming not)
this may seem a little OT for the OP but might be useful for others considering a change
Mighty E is offline   Reply With Quote
Old 11-11-2008, 06:03 PM   #22
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
TMIC's suck.
cpunlamd is offline   Reply With Quote
Old 11-12-2008, 01:51 PM   #23
neko
Member#: 46500
So many I can't
remember anymore.
Originally Posted by cpunlamd View Post
TMIC's suck.
Only if you're a lag-lover
By shear physics, TMIC's have less lag than FMIC's. Some of us don't like big laggy turbo setups. But hey, you just do whatever you want. We'll keep comparing facts on proven performance solutions.
Old 08-04-2009, 09:12 PM   #24
SuperHawk
Member#: 1036
2006 WRX Wagon Ltd.
Do you have an update on this?
SuperHawk is offline   Reply With Quote
Old 08-05-2009, 08:04 PM   #25
neko
Member#: 46500
So many I can't
remember anymore.
on? what exactly? is there a question we didn't answer?
JDM V7 STi TMIC size lh0628 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 04-29-2009 04:40 AM
FS: STI TMIC/ GT-Spec Splitter/ OEM Parts of 2003 WRX gfulk1661 Engine/Power/Exhaust 43 08-19-2008 09:07 AM
STI TMIC Size I LOVE SIU MAIS Interior & Exterior Modification 7 06-08-2005 02:12 PM
STI parts for sale (TURBO, exhaust, injectors etc.) and an upgrade going on Pipercub Mid Atlantic Impreza Club -- MAIC 8 12-14-2004 11:56 PM
Is this considered an upgrade? RotarFreak Interior & Exterior Modification 7 01-29-2002 08:53 PM
