Welcome to the North American Subaru Impreza Owners Club Sunday May 31, 2020
Old 08-06-2009, 08:09 PM   #26
SuperHawk
Member#: 1036
2006 WRX Wagon Ltd.
I was just wondering if the formula was figured out for the install of an 08 STI intercooler into a 02-07 WRX. It seems like some people are having a hard time with the install etc... I currently have an 06 WRX and would like to install an 08 STI intercooler if it will bolt in.
Dennis
SuperHawk is offline   Reply With Quote
Old 08-07-2009, 09:29 AM   #27
littlewhitewagon
Member#: 103068
11 STI sedan
You will need the Passenger side brackets from the 08 or modify your 06 brackets. The problem is around the turbo area. The 08 is so much bigger that it makes contact with the wastegate bracket and actuator. Otherwise, it bolts up without much fuss. Use your 06 breather lines, bypass valve is the same, driver side bracket is close enough to fit.
littlewhitewagon is offline   Reply With Quote
Old 08-08-2009, 03:37 AM   #28
SuperHawk
Member#: 1036
2006 WRX Wagon Ltd.
Thank you so much! What about the splitter for the hoodscoop, should you have one for an 08 or get one for a 06-07 STI?
Dennis
Old 08-10-2009, 10:29 AM   #29
littlewhitewagon
Member#: 103068
11 STI sedan
Neither splitter is a bolt on afffair. You will need to modify something. You can start with your stock one and go from there.
Old 08-27-2010, 12:58 PM   #30
cmatthew1978
Member#: 246523
2006 WRX Wagon
SGM
I have a couple of questions:
A) I just bought a 2008 USDM STi TMIC, do they ALL have STi logo(mine doesnt )?
B) Is there any additional parts needed to bolt on to a 06/07 WRX(in my case wagon)?
cmatthew1978 is offline   Reply With Quote
Old 08-27-2010, 03:33 PM   #31
bad mutha
Member#: 106747
04 forester xt
crp
08+ sti intercoolers dont have sti on them!
bad mutha is offline   Reply With Quote
Old 01-21-2017, 12:39 AM   #32
Nalva
Member#: 461335
Quick question
Are the 08 and 15 sti tmic the same size?
Nalva is offline   Reply With Quote
Old 12-31-2018, 02:02 PM   #33
ERMAHGERD SURBARRUR
Member#: 455314
2006 WRX wagon
Originally Posted by Nalva View Post
Quick question
bump for answers
ERMAHGERD SURBARRUR is offline   Reply With Quote
Old 04-29-2019, 02:24 PM   #34
00redobs
Member#: 325233
1999 Impreza
Quick question<br>
Originally Posted by ERMAHGERD SURBARRUR View Post
bump for answers
According to perth-wrx.
VA2 TMIC
20.87" x 7.6" x 3.54"
00redobs is offline   Reply With Quote
Old 12-27-2019, 02:20 AM   #35
mihael
Member#: 296973
2007 Forester XT
Does anybody know the weight of any of these intercoolers including the y-pipe and hoses?
mihael is offline   Reply With Quote
Old 12-27-2019, 04:44 AM   #36
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Default STi TMIC size/specs comparo. (I.E. is the 08 an upgrade?)
Here is a picture showing a 2017 STi top mount installed on a JDM STi ver 7 motor. Required extending the left side bracket and a longer throttle body coupler. A Grimspeed diverter sits over the core area perfectly.
D-Rodman is offline   Reply With Quote
Old 05-22-2020, 01:01 PM   #37
Joe_Dirt5
Member#: 514894
2013 WRX
Sorry if this has been asked before but I can't seem to find the answer to this question. Can you install a stock STI TMIC from a 2012 on a 2013 WRX non-STI? If not what needs to be changed in order to do so? I would assume that an STI intake manifold would be required to do so but is there anything else?
Joe_Dirt5 is offline   Reply With Quote
JDM V7 STi TMIC size lh0628 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 04-29-2009 04:40 AM
FS: STI TMIC/ GT-Spec Splitter/ OEM Parts of 2003 WRX gfulk1661 Engine/Power/Exhaust 43 08-19-2008 09:07 AM
STI TMIC Size I LOVE SIU MAIS Interior & Exterior Modification 7 06-08-2005 02:12 PM
STI parts for sale (TURBO, exhaust, injectors etc.) and an upgrade going on Pipercub Mid Atlantic Impreza Club -- MAIC 8 12-14-2004 11:56 PM
Is this considered an upgrade? RotarFreak Interior & Exterior Modification 7 01-29-2002 08:53 PM
