Welcome to the North American Subaru Impreza Owners Club Sunday May 31, 2020
Old 03-31-2020, 10:13 PM   #1
boostedHULK
Member#: 235531
Default forester xt with vf39 swap, need tune feed back.
I have a log and i couldn't find a place just to post datalogs. I just swapped to vf39, but swapped put inlet, hoses and a bunch of other stuff at the same time. New intake and tgv gaskets, and now it's all back together, it seems to have a leak or something going on. Doesn't make more than 9 psi, when target should be 20. If this needs moved, please do. I just needed to get it up. I'm going to grind over all my gaskets and connections tomorrow...any feedback is appreciated. Oh and i'm running cobb vf39 93 octane map. love you,
https://docs.google.com/spreadsheets...it?usp=sharing
boostedHULK is offline   Reply With Quote
Old 04-01-2020, 01:38 AM   #2
mooshon
Member#: 431456
You did long log, you need to start log when you push it and finish when you lift you leg , all the travel from your home to wherever is not important.
mooshon is offline   Reply With Quote
Old 04-01-2020, 02:17 AM   #3
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Yeah seriously lol.. and change the timer too. You don't need that narrow of a window.
You need to do a boost leak test Wgdc is low. Do a full pull all the way to redline to.
spoolinsti05 is offline   Reply With Quote
Old 04-12-2020, 02:01 AM   #4
SlammedSix
Member#: 419926
Your fueling is horrible...the car is adding or subtracting up to 20% fuel and points when your driving. When your car is idling its pulling 15% fuel. That right there is already a problem.
What year Forester?
SlammedSix is offline   Reply With Quote
Old 05-17-2020, 05:50 PM   #5
boostedHULK
Member#: 235531
It's an 05. Ill do some shorter logs. I was waiting to get my exhaust to drive it more. It was super loud with dp dump
With the fuel being pulled at idle i was a little stumped. Its the ots stg 3 map from cobb, and im only seeing low boost also...maybe a boost leak but doesnt explain idle
Old 05-19-2020, 05:21 PM   #6
boostedHULK
Member#: 235531
HERE IS A LOG, SINGLE PULLS TO NEAR REDLINE.
LET ME KNOW WHAT YOU THINK. ANY FEEDBACK IS APPRECIATED.
