Welcome to the North American Subaru Impreza Owners Club Sunday May 31, 2020
Old 05-17-2020, 11:09 PM   #1
hawkeyes7i
Member#: 514579
Default 07 STI valve cover bolts
So I was changing my Shift linkage bushings on a 2007 STi today at a friends shop on lift kit and I randomly was looking underneath the car to see if anything looks unusual or anything out of place since I haven't had the car jacked up in a while.. I noticed the valve cover bolt was loose on the driver side obviously oil was leaking through it and also a bolt was missing on the front of the valve cover or there isnt suppose to be a bolt there.. looks like it should.. What could of caused this? Anyone run into something like this. Weird
hawkeyes7i is offline   Reply With Quote
Old 05-18-2020, 07:29 PM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
**** happens. Things vibrate loose. Have you had the car since new?
Replace, torque to spec and check all others.
Old 05-18-2020, 11:45 PM   #3
hawkeyes7i
Member#: 514579
Yeah I had the car since 30k miles, i'm the 2nd owner. I order new valve cover bolts. I guess i will do that once the new bolts come in.
