Welcome to the North American Subaru Impreza Owners Club Sunday May 31, 2020
Old 05-18-2020, 11:02 PM   #1
warhammerjr
Member#: 224461
2008 Forester XT
GRP
Default 2008 Forester XT P0011, AVCS, OCV Duty Help
I bought an 08 Forester XT just over a year ago. Gotten the oil changed at regular intervals. About a month ago I would notice slight a pulsing or loping acceleration if I held the throttle at a steady 50%. Only happened every now and then and wasn't too bad.
Last week it threw code P0011. Reset the ECU and it hasn't come back. I did some datalogging after googling about the code. My Left OCV Duty is about 10% less than the right consistently while under load. Did one log and then a second only a mile later and my Right AVCS Intake is at 0 all of the sudden and wouldn't change at all.
I live in an apartment that doesn't allow me to work on my car unfortunately. Does anyone have an idea of what it might be so I can have the shop check it out first?
warhammerjr is offline   Reply With Quote
Old 05-19-2020, 03:24 PM   #2
danger1138
Member#: 279525
06 Fxt
Inspect the crank position sensor. Its located middle of block right beneath alternator. Wipe off the sensor with clean rag if it has bits of pieces accumulated.
Also, that code could have been triggered by the oil screens in the banjo bolts going to/from * AVCS solenoids and to/or from * turbo, getting gunked up.
This^^ situation tends to starve some components of oil. A common mod is to simply remove and get rid of these oil screens.
danger1138 is offline   Reply With Quote
Old 05-20-2020, 09:19 PM   #3
warhammerjr
Member#: 224461
2008 Forester XT
GRP
Replaced the crank position sensor in the O'Reilly's parking lot. Old one was pretty clean but I figured it couldn't hurt to replace it anyway.
I'm going to drop it off on Tuesday at the shop and let them work their magic.
Old 05-22-2020, 06:13 AM   #4
bp05obxt
Member#: 459799
These codes are common on failing engines for various reasons.
The engine is worn and loses oil pressure and canít function the OCV properly.
The engine is worn and engine debris is pumped into the gallery feeding the OCV but the banjo bolt filter becomes clogged and restricts oil flow preventing the OCV from functioning.
Could just be a fluke though too
Compression test could be a good place to start to verify the condition of the engine in a basic premise.
bp05obxt is online now   Reply With Quote
